Question about Canon PIXMA MP600 all-In-One InkJet Printer
Changing ink cartridge
I don't know how to get the ink cartridges in the middle to change
    President:
  • 2,692 Answers
Download you product manual for the following CANON website. It has very good drirections.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13800
Posted on Jan 06, 2009
How do i change the cartridge ?
901 is the cartridge what is the printer model?
Jan 31, 2015 | HP Two 901 Black ink cartridges
Ink holder will not stop in middle to change ink
Hi, normally when changing ink cartridge, once you open the cover the printer head move from home to the center of the printer and halted,if in case this not happen something wrong with the sensor, if the printer move from home to center just pull off the power cord to stop the printer at the middle or nearly at the middle just to remove the cartridge and replace it. Upon replacing the ink cartridge, just power on the printer and it will return home to its position.
Jun 17, 2011 | Office Equipment & Supplies
I am out of several of the color inks, but the Canon says "Check Printer" and the cartridge won't move to the middle so that I can change the ink.
If you are gentle you can manually move the print head to the middle by hand. You don;t want to force it or push very hard. There will be a bit of resistance but it should just move smoothly. You may find it works when the printer is unplugged.
When you power it back up after changing the cartridges it will return to the side and print normally.
Apr 21, 2010 | Canon MultiPASS F50 All-In-One InkJet...
Changing Ink Cartridge
Easy solution:
Press The index sheet button and the scan button at the same time.
In the printers window 'set up' will appear. using the left right arrows proceed to 'Ink cartridge replacement'.
Press 'start'. The ink cartridge holder will align itself in the middle of the space where it is easy to remove the cartridges.
I am disgusted with Epson making this so diificult to figure out. Once you know..then you know. but no amount of guesswork would have come up with the solution
Please rate!! Thanks, Prem
Jan 28, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How to change the ink cartridge?
lift the lid while the printer is on and the catridges should bring themselves to the middle so you can access them easily. If they dont, try pressing the button which indicates low ink (it may be flashing if they need changing) and this will bring them to the middle.
Once you have the cartridges in the middle they will either clip out by pressing down on the side nearest to you or there will be a catch keeping them in place which needs lifting and then unclip them. Just do the reverse to place the new ones in.
If you need any further help or I have missed anything then please let me know and I will do what I can :D
Nov 28, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I just want to change the black ink cartridge - how do i do it
I needed to know that to get to the ink cartridges the MP240 had to be switched ON before lifting up the whole scanner bed from the front.The ink cartridges will then slide to the middle and can be clicked out and a new ones clicked back in.
Aug 07, 2009 | Canon PIXMA MP240 All-In-One InkJet...
I changed ink my printer showing wrong cartridge
Make sure you are using factory new Canon ink cartridges.
If you purchased re-filled cartridges or third party cartridges that is most likely your problem.
Don
Jun 14, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Out of ink. Can't get cartridge to stop in middle to change
hi turn off the printer open lid move cartridge carrier to the middle, this should allow you to change the cartridge, then close the lid and turn on printer this should reset carrier to home position.
Jan 15, 2009 | HP DeskJet 810c InkJet Printer
Installing a new ink cartridge
After working with the copier for over an hour, my husbband discovered quite by accident where the ink cartridge was located. It is inside on the left hand side, above the try that holds paper, and is next to impossible to see. It pulls out to the middle of the tray, and the cartridge can then be changed. Thank you so much for you time.
Sincerely,
Becky LaCour
Mar 03, 2008 | HP OfficeJet D135 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
155 people viewed this question
old marine
old marine
