Question about Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator
Fan turning on and off , not sure about compressor
The fan turns on and off repeatedly and I can hear a click which I assume is the compressor trying to kick in. This pattern is almost continuos bit ocassionally I will hear the compressor actually start and go through a normal cycle. It seems to be cooling fine .
    Sergeant:
  • 311 Answers
Its the compressor relay thats clicking[its a little unit connected to compressor with at least two wires]it could be that its [relay]going bad or the compressor could be failing,but it dose cool once it gets started so thats a good sign.the relay has two parts.one an over load,thats like a curcit breaker,it cuts power to compressor if its drawing to much amparage.the other part is a swith that goes fro start winding to run winding.as a repairman i would pull relay and use volt meter to check winds before replacing relay.its been alittle while but depending on age of refer,start winding around 2.7+-.5run winding 1.1 +- .5 new box use less energy so lower resistance older higher.hope that gives you a start ps fan goes off on because its starts with compressor.God bless ,tom
Posted on Jan 06, 2009
I have a Honeywell thermostat. The thermostat clicks to turn the air condition on but the outdoor unit does not turn on. The fan clicks on though.
I assume you are referring to the indoor fan coming on. If the fan on the outdoor unit is coming on, and the compressor is not, you have a control problem with the outdoor unit, I recommend calling a service man. Make sure you have power to the outdoor unit. There should be a service disconnect on the outdoor unit, connect and disconnect the power, you should hear a hum when the power comes on, put your ear to the housing of the outdoor unit and you will hear the power come on when it is turned on. If no power, or hum, check your breakers in the house electrical panel, see if any are tripped. Next step call a service tech.
Jul 20, 2014 | Heating & Cooling
Compressor fan mtr hot, hear it try to energize for approx 2 seconds then stops aproximately 1minute later cycle repeats, removed coil voltage and manually acuated coil did not hear anything trying to...
The motor bearings have siezed up and the motor needs to be replaced...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 22, 2010 | Goodman CPLE24-1 Air Conditioner
Fridge question
Sounds like you mad have a bad relay or overload on the compressor. I would also check your condenser fan motor to make sure its running and blowing air on the compressor to cool it. If its not running the compressor may be overheating and shutting off on its overload. If the condenser fan motor is running I would assume that you would need a new relay and overload it will come in a kit. Usually it will make a clicking sound when the compressor is TRYING to start and then shuts off on its overload if the start components are bad.
Hope this helps _MJ_
Feb 07, 2010 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Can hear motor working turned up fully stillnot
Be sure what you hear is not the fan instead of the compressor. Unplug the unit, wait 10 minutes, and plug it back in. Listen for the compressor to start up, or even listen for a faint "hum and click" sound. That would be the compressor trying to start.
Jan 06, 2010 | Frigidaire FRS26ZSG
I can hear the motor running and the lights are on. But the refrigerator is warm and the freezer has thawed everything.
By motor, I assume you are referring to the compressor underneath the refrigerator. Close by the compressor toward the rear of the refrigerator, there should be a compressor fan. This should be turning. If it's not, the refrigerant coils will not be cooled adequately. This results in inadequate cooling inside the unit. Check also to make sure the coils are not covered with dirt and grime. If they are, clean them.
If the compressor fan is not turning, you will need to replace the fan motor.
Oct 18, 2009 | Amana ABB1927DE Bottom Freezer...
Freezer is not staying cold. The freezer is on but its not staying cold enough to keep the food frozen. The Ice maker switch is turned on but ice is still melting. Turned the control to coldest but still...
Sounds like the evap. fan motor is not turning. What is the freezer temp. have you measured it ? What about the fresh food section, (fridge compartment).
Anyway, try this. Hold the door switch in the closed position with the freezer door ajar and see/listen for the fan coming on. If you can't be sure, the best way to do this is to first turn the thermostat all the way to the "off" postion, and with the freezer door ajar and holding the door sw. closed (pushed in). turn the thermostat back on. (you may need to turn off then back on first if your arms aren't long enough) You should hear the fan motor start.
NOTE; you may hear the compressor overload "click" off if trying to start it right after shutting down, this is normal (under short cycles or manual restarts). You may also hear the condensor fan motor run (under the fridge by compressor) this too is normal. try to indentify the freezer fan (evaporater fan motor) running or not.
good luck.
Sep 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refridgerator fan motor will not stop running
you might of pushed something into the fan blade and now its overheating the compressor. Thats usually the clicking that you hear
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
ED5SHEXKQ01 is 7 years old. Stopped cooling. Fan is running.
It could be your compressor trying to kick in. Or it could be your defrost system trying to start or stop. The least expensive thing to start is to replace the start kit on the compressor. Call or email us and we'll be sure to get the right part to you asap. You need to turn it off NOW before you burn the other parts up and don't turn it back on until you install new parts.
Sep 09, 2009 | Refrigerators
Whirlpool refrigerator (top mount freezer) model ET8FTKXKQ00
I feel sure you will find the compressor start relay is probably bad unless it is a Frigidaire manufactured refrigerator. If it is a Frigidaire then if may very well be a bad compressor.
I hope I have helped, supertechks
Mar 28, 2008 | Refrigerators
Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator Logo
124 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
