Question about LG WM-1832C Front Load Washer
Wm0532hw front loader starts then has an error of de i have made sure the door is closed but do not have any manuals to review. can you help?
  • 640 Answers
I checked you have a defective door latch,,replace
Posted on Jan 06, 2009
What does the code de stands for
On front-load washers, it can stand for "door error", meaning the main control board thinks the door is open. If the door is actually closed and the de error won't clear, the electric door lock could be shorted, giving a false signal to the main control board. On the Samsung top-loader, it means a "child lock error" has happened. On that washer, you will see "CL" or "DE", the washer will auto-drain and an alarm will sound. To clear the error, close the door, turn off the power, then turn it back on.
Aug 21, 2015 | Washing Machines
What does dE mean on the samsung sw5asp top loader washing machine
dE means the door its detected as closed
a quick look at THE USER MANUAL
tells you the error codes
http://downloadcenter.samsung.com/content/UM/201409/20140922144717463/WD8704RJ-02718A-07_EN_XEU.pdf
here is the link
if the door closes firm
then you get the DE error then the door interlock has failed
and will need to be replaced
Feb 07, 2015 | Samsung Washing Machines
Bosche front loader de error message help
dE is a door error, check switch, door alignment and wiring harness
May 28, 2014 | LG WM-2277HW Front Load Washer
How to fix a EHE error code
1. Start the drier normally
2. Before the "EHE" error appears, open the drier door!
3. Because the door was opened during program, "dE" error is shown
4. Close the door and press "start/pause" to continue
5. Program will continue normally; problem fixed!
Apr 30, 2014 | LG WM3431 Front Load Washer / Dryer
I have a front loader samsung j1045.it just wont go on most cycles,so i was just using it on colours.now its showing the error de after a few minutes and beeping..please help?? Nan T
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
May 14, 2011 | Washing Machines
Hi, we have a lg wm0532hw tromm front loader washer, the latch on the door seems to be broken, it slides all the way back into the door frame and washer will not lock. Can this be fixed? thank...
I'm sure it can but you will need to call a local service engineer to do it. Sorry we cannot call one for you.
John C
Mar 10, 2011 | LG WM-0532HW Front Load Washer
Lg tromm front loader washer wm0532hw shows oe error
that's draining error. check the filter cleanout behind lower left panel on front of machine; of course drain 1st via small drain hose. if thats o.k the drain pump itself may be jammed with debris or the drain hose could be clogged.
Jun 24, 2010 | LG WM-2277HW Front Load Washer
Have DE progamme fault...
dE - Door (Front Loader) or Lid (Top Loader) Open Error = Close Door / lid
If error persists, check:
  1. Make sure the load is not too large - try taking some laundry out and see if the error persists.
  2. Wiring harness
  3. Door / lid switch assembly
  4. Unbalance switch
  5. Circuit board for defects.
  6. Check Drum retainer springs are situated correctly and are correctly tensioned.
  7. Make Sure Drum stabiliser struts are not misaligned or broken.
Repair / Replace faulty part.
Nov 06, 2009 | Samsung Washing Machines
LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Sep 11, 2009 | LG Washing Machines
LG Washer dryer error dE
Unplug the machine.
Plug back in (maybe 10 seconds later).
Mine had several dE messages. Unpluged, waited 10 seconds, when pluged back in, it remembered which cycle and parameters I had it on, then locked the door and continued with no problem.
Mar 17, 2008 | Washing Machines
LG WM-1832C Front Load Washer Logo
132 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
