Question about Philips Magnavox 51MP392H Rear Projection Television
WHAT DO I BUY TO CHANGE THE FLUID IN THE PROJECTION LENSES
  • 32 Answers
The steps for changing the fluid on rear projection televisions are generally the same.
You will need new fluid (Can be purchased from http://www.mcmelectronics.com/product/20-4275 MCM Electronics)
Denatured alcohol (basically, rubbing alcohol)
Something to scrub the inside with (I prefer good ol' pipe cleaners, available at any craft store)
You'll have to remove the CRT, and take off the lense assembly. NOT THE SEALED ONE
The fill hole for the fluid is usually just a big flat phillips head screw. Remove it.
Drain out the old fluid
Using the alcohol and pipe cleaners, try and remove as much buildup as possible.
Clean thoroughly and let dry.
Refill with new fluid, replace the plug and clean the CRT.
Reassemble the whole deal, being extremely careful not to disturb the yokes (this will put the red/green/blue pictures out of alignment, causing more work) and fire it up. You should be good to go!
Hope that helps!
Posted on Jan 06, 2009
Recycle Projection tubs
The fluid is probably glycerin
The lenses are glass
The tubes are leaded glass
check your local best buy
toshiba has a take back program
and
http://search.earth911.com/?what=Television+Accessories
Jan 19, 2015 | Toshiba 43HX70 43" Rear Projection...
Bluish screen whites really bright background really dark it was fine untill some one messed with the color
Their is a CRT fluid that keeps the three lenses cool ontop of the tubes. The fluid goes bad after a few years and causes what you describe.
Read this.. http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 25, 2011 | Philips 60PP9202 60" Rear Projection...
I have a PTV916 Model # 60P8341A. I cleaned the lenses and the mirror inside the TV however, I can see alot of dust inside the actual lens. Is it possible to clean the inside of the lenses?
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 13, 2011 | Philips 50P8341 50" Rear Projection...
Color is cloudy. the picture is far from being sharp.
The fluid in the lenses has clouded over. This is common. You can get a CRT fluid repair kit from www.TvRepairKits.com .
Jan 03, 2011 | Philips Magnavox 9P6034C 60" Rear...
Colors ore dull and blurred. how do i tune up
First start with cleaning all 3 lenses on top of tubes,then clean mirror,If picture is still blurred you may need to change projection Fluid in Tubes.
Aug 07, 2009 | Toshiba 43H70 43" Rear Projection...
Hazy yellow spot in the left lower corner of the screen
It could be a cob web inside the tv or something laying on one of the guns, like a dead bug. If it's a cob web, you should be able to move the tv a little side to side and see it change from the moving air current. I would remove the back and vacuum off the lenses of the guns and look for cob webs. It's safe to touch and clean the lenses, just don't touch any electronics.If this doesn't fix it, it's probably fluid starting to cloud up in the guns or IC chip problems.
Jan 08, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Foggy picture
That is your coolant projection fluid make sure you clean up any that may have went on chassis ect.....refill fluid in lense make sure it does not leak and try again, tube should be same as before, when chaning fluid in lenses always turn set on look into lenses if clear it is ok if dirty looking then change fluid.
Dec 24, 2008 | Philips Magnavox 51MP392H Rear Projection...
Color & sharpness problem
Sounds like you need Coolant fluid change, this is the fluid under the Lenses. If you have not done this before I suggest that you get some one who is qualified. Because if the coolant leaks and get to the circuit board, there goes your tv. You need new fluid in the 3 CRT's. If you look down with the back off and looking in the lense, you would see contamination in the fluid, this needs to be taken out and cleaned and replaced with new fluid. The fluid can come from places like MCM electronics corp.
Mar 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 55" rear projection screen
you need to take off your back cover take a can of air you can buy at electronics store and blow off the projector it probably has dust on it
Feb 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 51MP392H Rear Projection Television Logo
71 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
