Question about Brother MFC-8460N All-In-One Printer
Mfc 8460n paper jam
I have a mfc-8460n with 17000 page count on it and seem to get a paper jam every time i go to print or copy. the printer will pull paper from the tray, runs 3/4 of the way through the drum and stops about 1/8 of the way through the fuser and then jams. any help will be greatly appreciated.
thanks
robert
rmooney@consolidated.net
Check to see if this happens when you use the drop down manual feed tray. If your printer works fine using the manual feed tray the problem is with your paper tray. Check to make sure it is set to letter size. I've found that sometimes the 'teeth' holding the paper stop on the paper tray wear out and when the printer goes to pick up paper, it pushes the paper stop out of position causing the printer to think it's using a different, much longer size paper thus preventing it from feeding all the way through. You'll probably need a new paper tray if this is the case.
Posted on Jan 12, 2009
HAVE REPLACE THE DRUM AND TONER CARTRAGE AND NOW WILL ONLY PRINT ONE COPY AND SAYS PAPER JAM. OPEN FRONT PANEL AND REMOVE DRUM AND CLOSE PANEL AND THIS ALWAYS SOLVES THE PROBLEM BUT WILL ONLY PRINT ONE...
Welcome to fixya
I have a solution for this
Content
It sounds like you need to remove the toner cartridge and check for half broken pages below the toner. Some of the parts inside will be hot to the touch so take caution when attempting to remove the pages while the system is still hot.
Your pre-solution is located above. More information is available in the comments
My name is Bruce
Jan 20, 2011 | Brother MFC-8460N All-In-One Printer
Paper jamming while printing
The printer could be having issues with the rollers not pulling it through the paper path. You may need to have a certified technician replace or clean the rollers.
May 28, 2010 | Brother MFC-8460N All-In-One Printer
Overheats when printing pictures on transfer paper and now it will not print anything.
hi
i have problem with my brother prinetr MFC-8460N
IT SHOWS DOCUMENT JAM
ALSO MESSAGE ON SCREN
CLEAR THE SCANNER JAM THEN PRESS THE STOP KEY
STATUS SHOWS RED LIGHT
WE ARE NOT USING SCANNER WE ONLY USE FAX AND COPY
RIGHT NOW BLUE LIGHT IS ON FAX AND WHEN I PRESS COPY BUTTON IS NOT ALLOWING ME
PLEASE ADVISE
Nov 10, 2009 | IBM Infoprint Color 1357 Led Printer
Hi , My 4 in one printer get message Paper jam. MFC-8460N MFC-8460N
hello! i need to know where the jam is so that i may help you. brother tech
Jan 21, 2009 | Brother MFC-8460N All-In-One Printer
Printing problems
If it is approx 3-4 smudges down the page. Replace the drum cartridge.
Oct 30, 2008 | Brother MFC-8460N Laser Printer
Document jam brother mfc 8460n
you cannot clear this unless there is still a presence of paper inside the machine.
or you can open and close your machine once you are cleared of any paper jammed, be sure not to leave and removed all residual paper in the paper path, the tiny sensor would recognize any sort of this and thus make your machine unoperable.
Jul 25, 2008 | Brother MFC-8460N All-In-One Printer
Brother MFC 8460N Paper Jam
paper jams alway in the same spot- just as it's about to exit the bottom tray
Feb 08, 2008 | Brother MFC-8460N All-In-One Printer
Brother MFC-8460N All-In-One Printer Logo
567 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
