Question about Lexmark X1150 All-In-One InkJet Printer
Change ink cartridge on a lexmark x1150
I need to know how to change the ink cartridge on my lexmark x1150
  • Leighton Taylor Jan 24, 2009
    lost instructions.not sure how to change ink.
    President:
  • 2,692 Answers
When I try to print from my Lexmark X1150 it says that the wrong ink cartridges are installed but I am using Lexmark 27 and Lexmark 17 - I thought these were the correct ones - can you advise...
The 17 and 27 cartridges are compatible with your Lexmark X1150 printer. Try to manually wipe the cartridge nozzles with a soft moistened cloth. This will help clean the nozzles from dirts and clogs. Unplug and replug the printer into the power outlet in the wall to reset it. When the printer turns on, reinsert one cartridge first. Close the cover. If no error, open the cover and reinsert the other cartridge. Replace whichever cartridge is causing the error to appear. You can also try to insert a different known working cartridge to determine if the other is faulty.
May 19, 2011 | Lexmark X1150 All-In-One InkJet Printer
Got a lexmark x1150 both black color ink been replaced not reading black ink and text is blurry
Hi. The cartridges may have not
been seated properly in the
carrier or just needs cleaning. Here's an article in the Lexmark website to give you instructions on how to clean the nozzles of the cartridges. It has some graphics to help you better understand the instructions. Just click on this link: http://bit.ly/ceuET7 . Hope this helps.
Mar 17, 2010 | Lexmark X1150 All-In-One InkJet Printer
I just changed my cartridges for my lexmark x1150 and my blues are now showing pink.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 03, 2010 | Lexmark X1150 All-In-One InkJet Printer
I have a Lexmark X1150 printer that is printing purple only.
Try the "better" or "best" print options - They give more ink - might do the trick - (beware it also prints a lot more slowly....)
I have not had that type of problem as such as both my ink slots work, but I did have purple/bluish print instead of black once - It worked for me -
Hope that helps -
I have also found that despite cartridges being new somethimes they are not as full as they should....
May 03, 2009 | Lexmark X1150 All-In-One InkJet Printer
Changing ink cartridges
Make sure the printer is ON.
Open the top of the printer.
The cartridges are inside the cartridge carrier. You need to squeeze the tabs on the carrier which will flip up the lids to reveal the ink cartridges.
For reference, here are links to the setup sheet and the user guide. The setup sheet has pictures that should help.
X1150 Setup Guide
X1150 User Guide
Nov 17, 2008 | Lexmark X1150 All-In-One InkJet Printer
Leaking Ink Jet Cartridge.Clogged Up My X1150 Printer
No Solution Found.Get Lexmark Customer Services To E Mail Me Or I Take It Back To Trading Standards. C>Craske
Oct 07, 2008 | Lexmark X1150 All-In-One InkJet Printer
Pictures coming out yellow
The "Print Head" needs cleaning or replacement. It's the part that delivers the ink from the cartridge tank to the paper itself.Mostly caused by air entering the lines and making any residual ink cure.
Most newer printers only ever use 95% of the available ink before reporting tank is empty,and will not allow any printing to resume, preventing air being introduced to empty lines in the head.
Without Removing Anything
There's commercial products available, I guess a bit like using a head cleaning cassette in your VCR - I Have not tried any of these yet.
Use an empty ink cartridge Refilled with hot water and run the print head cleaning function.
( Dont worry , The paper will absorb the minute amount of water being dispersed.)
If that fails you should remove the print head cartridge most are pretty easy ,
LexMark X1150 X1185 and other similar models with the sensor strip running through the cartridge instructions are located at the following FixYA topic
http://www.fixya.com/support/t181337-piece_fallen_out_printer
Immerse it in warm-to hot water for a while or try using rubbing alcohol or similar Non-solvent based liquid.
Inspect the small rectangle shaped metal print head & surrounding copper track for dried ink , remove any with very gentle wiping taking care not to damage anything.
If it's beyond cleaning it will have to be replaced .Try ebay or the local print shop.
May 12, 2008 | Lexmark X1150 All-In-One InkJet Printer
Colour Ink
1. On your PC, go to Start, Programs (Windows XP: All Programs), Lexmark series.
2. Select the Solution Center.
3. When the Solution Center appears, click on the Maintenance button.
4. Select the option to Install a new print cartridge. The carrier should slide over at this point and allow you to insert and/or remove cartridges.
5. Make sure the correct cartridges are installed inside the printer first, then inform the software which cartridges have been installed. Note: This applies also to installation of a single cartridge.
6. Print the Print Alignment page to ensure the print quality is satisfactory.
7. Close the Solution Center.
Mar 23, 2008 | Lexmark X1150 All-In-One InkJet Printer
Black ink
Did you remove the tape from the cartridge when you installed it?
Has it ever printed black from this cartridge before?
You may need to wipe the cartridge with a moist paper towel at the place where the ink comes out. If there is dried up ink the nozzles could be clogged. Try running the Lexmark Solutions Center from the Windows Start menu (Start -> Programs -> Lexmark 1100 Series) and make sure the black ink level is good. You can also select "Clean Nozzles" in there and that may help.
Oct 15, 2007 | Lexmark X1150 All-In-One InkJet Printer
Lexmark X1150 All-In-One InkJet Printer Logo
102 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
