Question about LG WM-2277HW Front Load Washer
Water leaks out of the bottom area of the door
Is it hard to change the large rubber around the door. I have a live in handy man thanksss for your help
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
There is a ring that holds the door gasket in place on the outside of the front panel and another ring inside the drum (the ring has a spring on it that allows it to be stretched.
There are 2 tools that LG has that make the ring clamp easy to install/remove, but you can also use 2 pair or needle nose pliers (one to hold the ring at the spring and another to stretch the ring). Just be careful not to damage the gasket.
Also, when ordering the new door gasket, make sure you have your serial number handy. There are 2 versions of the door gasket (depending on the serial number).
Hope this helps, please rate my solution.
Posted on Jan 11, 2009
Water leak from front loading machine
at a guess i would say there is a cut in the rubber seal around the door sometimes its hard to spot it but if you pour a cup of water on the seal and see if the water comes down under the machine if so you wil need a repair man/woman it a hard job
Oct 14, 2014 | Maytag MHWE201YW Laundry : Front Load...
Water leaking
At a guess i would say there is a cut in the rubber seal around the door sometimes its hard to spot it but if you pour a cup of water on the seal and see if the water comes down under the machine if so you wil need a repair man/woman it a hard job
Oct 14, 2014 | Washing Machines
Water leaking out of front of washer
Oct 14, 2014 | Maytag MHWE200XW Washer
During wash or rinse cyle, water leaks from the bottom
open the door,check the rubber boot for any holes,ussually that's where it leaks,also wipe the inside of the door,i've found hair and lint stuck on the inside bottom of the door and water leaks out but pull open the rubber boot and run your fingers all around it to check for any holes.you can remove the bottom panel and then run the machine to see where the leak is coming from.
Apr 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How to change door seal on Zanussi ZJ1218 washing machine
I hope you have small hands,and you are pretty handy with them cos these seals are tricky if its your first.
First remove the nylon clip around the front of seal it will pull off from bottom.then release outer rubber,then you have to just get your hand or fingers to pull at inner rubber,there is a spring around inner rubber lip but to make things awkward there is also a concrete counterweight around this.Once you have old seal out get new one and wipe some fairy liquid around inner lip to refit make sure pointy arrow is at the top.This is the tricky bit and hard to explain but you can only do it by feel and keep trying to get a part of inner lip over casing lip once it starts it can go easy or hard you may have to try a couple of times until you can feel it is on all the way round.Once on the spring has to be fitted its also tricky,start by door switch and put a long screwdriver thru. hole for door catch try to hold with knee or get help.Work it around keep screwdriver in until spring is nearly on keep hand on spring then gently try to remove screwdriver make sure spring on fully,now fit outer seal lip and fit nylon clamp.You may find it easier to tilt machine back slighty.I do this for a living and it can go easy or hard.Best of luck.
May 04, 2010 | Zanussi ZJ1217 Front Load Washer
Dishwasher is leaking in front onto floor. Water level during washing seems too high. Float is not obstructed by any object. What can I do next?
if it seems to be coming from the front it may be the rubber door seal they are not to expensive and not very hard to change if it is leaking under machine it may be the seal that sits on top of motor if water is leaking around motor the seal in the bottom of the washer is damaged
Dec 17, 2009 | Washing Machines
Whirlpool duet washer leaking water
If the washer is leaking around the door area, more than likely the bellow (rubber seal) is ripped or torn. If you pull back the rubber folds in the bellow and inspect, you may find a rip or tear causing your leak.
Another cause can be the rear bellow clamp (clamp that is affixed to the front of the wash tub) can come loose causing a leak between the bellow and tub. All you may have to do is tighten the clamp if this is the case.
The dispenser tube on the left hand side of the door, if not seated through the rubber correctly, can also leak during the fill or rinse cycles. The tube should be inserted through the rubber in the bellow to the flange on the tube. If not, water can fill behind the rubber and drip into the bottom washer casing.
The following link explains how to access and/or replace the the door bellow on a Whirpool Duet:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com and repairclinic.com carry the bellow. All these sites offer competitive pricing, so shop all of them for the best deal.
If you have any questions, or require addtional assistance, please let me know. I hope this helps you. NOTE: The bellow can also become mishapened over time after frequent use. This can also cause leaks around the door. Look to make sure the bellow is sealing around the door glass. If not, it should also be repalced.
Jul 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front loader washer leaks from bottom center of door osmetimes
Check inside the door on the bellows gasket to make sure the inlet area (normally at the 10 o'clock position) is properly positioned around the water inlet, sometimes these work themselves off the inlet nozzle and can casue a leak when the washer is filling up.
Also, carefully run your hand around the bellows gasket to see if you can find any small holes that cold be letting water leak out. You'll need a flashlight to make this easier. It is hardly ever the hinges that causes a leak since the hinges are mounted outside of the door seal gasket (bellows gasket) and aren't ever exposed to the water.
Jul 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaks from bottom of machine
is the gasket on the filter in one piece or has a line come off the pump? mine it was the output of the pump.
Feb 02, 2009 | Kenmore Elite 45986 Front Load Washer
LG WM-2277HW Front Load Washer Logo
230 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
