Question about Canon PowerShot A75 Digital Camera
Picture is pink and appears to be running paint downward
Entire picture is pink and looks like paint running downward
  • DonnaLee5 Jan 26, 2009
    I have the same problem with my camera. Just happened a week ago.
  • barbhil Feb 02, 2009
    I have the same problem of screen being pink and appears to be running down the screen. When tested three out of twentry six pics turned out ok.
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Jan 09, 2009
How can i get the right touchup paint match for my car
Hi Robert:
Apart from trying to get a dealer colour code, Here's what I would do.
1) Take a picture in bright sunlight.
2) Download the picture to my computer.
3) Print the picture on my Canon printer.
4) Take the picture outside and compare to the car (on a sunny day)
5) Take the picture to my local Canadian Tire or Lordco or Napa store, and match to the "rattle can" paint selection.
Ta Da!
Jan 21, 2016 | Cars & Trucks
The picture looks fine and there is no funny noises but pink lines or blotches will appear and disappear with the changing pictures on the tv.
A picture - or a video - is worth thousand words in this case.
it will also help to know what is the TV model.
Dec 09, 2010 | Televison & Video
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
How do I start printing material shown on monitor?
Do want to "print the screen"? On the upper right on your keyboard there is a Print Screen button. When you want to capture a picture of the screen you are looking at, press Print Screen. Now you have a picture of the screen in memory. To print it, you have to run a program like Word or Excel or Wordpad or Paint, or almost any other editing program. Once you are ii, click on Edit and then click Paste. Your picture will appear for you to print. Good Luck.
Apr 12, 2008 | Computers & Internet
Vertical Lines / Color Differences at edge of Analog vs HD Picture
EXACTLY-YOU HAVE THE USUAL "AGING" CRT PICTURE.THIS WILL ALWAYS HAPPEN WHEN YOU WATCH THE TV W/BLACK BARS ON THE SIDE,THERE IS NOTHING SHORT OF ALL 3 CRTS' REPLACEMENT TO FIX IT. JOE TV
Oct 31, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Pink picture with wavy green and blue lines
start with convergence ic's probably stk 392-130 big black chip's on an alluminum heat sink. mark ALL connections with majic marker. check for bad solder connections. for god's sake be carefull
Oct 19, 2006 | Sony KP-53S65 53" Rear Projection...
Pink screen
Is your grey scale or Black and white programming pink?? Thats an indication that the green and blue grids on the picture tube are week or that the red is over driving. First thing is take off the back of the set. Find the end of the picture tube and look at the printed curcuit board there. see if you can find and red drive controls there. Put on a black and white pic and ever so slowly rock that red drive control a little at a time till the picture looks almost normal.. If you get it to be a little \less pink then stop right there but if it starts to get a bit green or blue then try rocking those controls all back and forth till you get the bese B&W picture you can BUT BE VERY CAREFULL as there is alot of voltage on this picture tube and if your not carefull it will bite ya. Now dont be too critical as the tube is a bit weak so you probably wont get a perfact grey scale so if after a while live with it or get a new set. Good Luck.
May 02, 2006 | Jensen Q2749J 27" TV
Canon PowerShot A75 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
