Heller air conditioner ach25rcr model. it wont work. i have a red and a green light flashing when it is normally only a green light. i've gone through trouble shooting in my manual to no avail. i hope you can help me.
  • 19,396 Answers
Try cutting power to the AC by tripping circuit breaker, if the problem comes back after reconnecting, then it may be a faulty part inside , as fan, compressor, circuit board or gas in need of recharge, as both lights on means call service.
Call the service number listed on the owner manual.
Posted on Jan 06, 2009
  • 1,800 Answers
Does the fan run ?
  • Jalal Sordo
    Jalal Sordo Jan 06, 2009
    • Control is in a timer mode
    • Control is in heat mode in summer or cool mode in winter.
    • One of the controller functions is waiting for something to happen before starting. The delay could be due to 'defrosting', 'delay after restart', 'delayed fan start on heating' or some other function.
    • The thermostat not calling for heating and air conditioner has a 'fan off when temperature ok' mode
    • A safety device (usually high pressure) has tripped out.
    • Internal fault in the air conditioner.
I have an old Carrier N1340 air conditioner that works when switched on, green light flashes 4 times, for a few times then it shuts down. There is also a flashing red light inside that unit.
There will be a list of flash codes in your manual or on the inside cover of the unit indicating what the problem is eg. low pressure or high pressure alarm
Nov 15, 2016 | Carrier Heating & Cooling
When the unit is off there are 5 red and 1 green light flashing simultaneously followed by 1 green flash. what could be the cause
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. If you need any other AC Advice. Check us out online. WPB AC Repair .
May 23, 2016 | Heating & Cooling
I've got a Heller 10-fin standing oil heater, H-2400T. I would love it if someone can show me where to find the online instruction manual for this. Or just explain how to make the timer function work....
G'Day
I have one of these Heller H-2400T heaters. To operate the timer try this: Plug into power and turn on. Set power control to either Low/Med/High. Set temperature control midway between Low & high.Rotate timer dial to the right to align time of day to the reference point. Ensure all of the red tabs are pulled out. Then push in the ones for the period you want the timer to operate. Works for me. Good luck
Jun 13, 2011 | Heating & Cooling
Need manual for a heller portable air conditioner. Model: GUSTY10CO
I have a Heller Gusty10c0 Portable Air Con. When It hasn't been used for a while. I turn it on and it last about 10 minutes then just stops. Then when ever I turn it on it cuts out after about 30 secs to a minute. Can anybody help me please?
Dec 12, 2010 | Heating & Cooling
Ihave a fujitsu air conditioner model asta18lcc about 2 yrs old when I turn it on fan works but room wont get cold or hot,red operation light does not stay on but green timer light flashes on. thanks...
The lights on the front panel indicate fault codes dependent on the amount & intervals of the flashes. Fujitsu units carry a 5 year warranty so check with your local Fujitsu store for the agent in your area.
Aug 13, 2010 | Fujitsu 24C1 Air Conditioner
HELLER MOBILE AIR CONDITIONER
that's the way it should work, after you set temp to 20 degrees, display jump to the inside room temp in your case 25 or 29
Jun 10, 2009 | Haier Heating & Cooling
Amana AC
Hi, the aircondationer compressor was stuck , the thermal control open the red light on , you may call fixya authorized repair service near you you just enter zip code .
Jan 30, 2008 | Amana AP099R Air Conditioner
Heating & Cooling Logo
80 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
