Question about Philips GoGear SA3245/37 Digital Media Player
File system error
After I attempt to turn on my mp3, the screen says "file system error". It wont let me turn it on at all. After error screen the power shuts down immediately. What do I have to do to fix this?
  • Anonymous Jan 18, 2009
    system cleared no files
  • ajamale Feb 04, 2009
    with me its just bad
    so, it shuts down after the splash, then, i'm like **** it i'll put in the USB, then you HEAR THE SYSTEM RECOGNIZE IT but it DOESNT SHOW IT., ANYWHERE!!!!!
    man, i hate this ****. It won't appear anywhere in my computer, but the sound does go pum'pum!- but yeah. Oh yeah, and as for the screen it shows the "ok to disconnnect" thing, and when i do, it just freezes there, like stays with that picture. And NEVER did the green lights pass the 4 circles.
    this is some ********.
    HELP
    please email me, briankicksyoass_247@yahoo.com
  • 928 Answers
If its possible plug the unit in your computer and it should come up in My computer under removable storage. Right click it then cilck format.
Posted on Jan 06, 2009
  • 22 Answers
That might not work though, so, if it doesn't show in My Computer, you need to have the software CD it came with installed or get it from (www.philips.com/support) and use the device manager to restore it. You'll lose all your music and anything you had on the player. I had the same problem (my fault) and I did just that. Lost everything but it still works today.
Posted on Feb 06, 2009
Imac powerpc g4 will not shut down or restart properly and will not recognize external hard drive
1. Press the power key and immediately press and hold shift-option-p-r until you hear a second startup ****. (This resets the parameter RAM).
2. Press the power key and immediately press and hold command-S. The screen should go black and show a verbose listing of the boot process in white type. When it stops, you will see a flashing cursor at the end. Type the following: fsck -f, then return. This will start a check of the file system, and the fsck program will attempt to repair any errors found. Wait until the program displays the results (it can take a while if you have many files). Post your results here. If it finds errors and corrects them, your problem may be solved.
3. (Don't do this unless the file system comes up OK and you are still having problems.) With the computer off, press and hold Shift-Cntrl-Option+Power for 5 seconds, then press the power key. This should reset the power management unit.
Feb 12, 2012 | Computers & Internet
Philips gogear 8gb mp3 file system error
m8 that happens to minebut i cant fiqure it out
Oct 22, 2011 | Philips GOGEAR SA6045 MP3 Player
Just bought a new LG Axis smart phone today and after loading some applications from the application market on the phone, whenever I went to view an application I kept getting an error message that the...
A Hard Reset might help. it will bring lost file/folders back.
Also to turn on phone in safe mode, but not if cannot get passed initial Android screen.
Pull Battery to power off phone.
Hold Up Volume button, and power on button simultaneously until green android guy and DOS window open.
If Home key is solid button, then also hold
up vollume button, home button, power button.
use volume up and down to scroll.
Scroll down to Reset Manufacure Settings.
Use power button to select OKay.
Then select reboot system.
Mar 27, 2017 | Cell Phones
The screen is stuck on a screensaver and it will not turn off or do anything
It often happens when it doesn't a file is corrupted. If it gets stuck on "Refreshing database", turn it off by holding the power switch until it shuts down, then plug it on a computer and when the sansa logo appears, unplug it. It will skip the datebase refresh and you'll be able to reformat it.
Dec 26, 2009 | SanDisk Sansa Fuze MP3 Player
Player shuts itself off
There could be a damage or corrupted file in the sansa clip. I suggest to reformat the player. To reformat the player. First turn off the player. Then slide the power switch down it will be showing red, now press and hold the center or the middle button on the player while connecting the player to the computer. It will be detected as a drive on your computer, now right click on it and choose FORMAT, make sure the file system is FAT32 then click start to continue formatting the player. This will erase or remove all the songs on your player but this will fix the problem that you are having
Aug 22, 2008 | SanDisk Sansa Clip MP3 Player
The Sony NWZ B105F Music player
download the nwd-b105 firmware 1.1 (google it) and once you have it connect your mp3 player to an usb port of your pc. run the firmware file you downloaded and check the "delete files" option and run the firmware. you will lose all your files but your mp3 should be functional again. remember that when you do a firmware update you must keep your mp3 connected to the pc, also a if there is for some reason a power failure you may brick your mp3 player. my mp3 player had teh same problem as yours and i fixed it this way. the reason this happens is that sometimes the antivirus delete some system files from your mp3 and thus it cant access its database causing an error and shutting down the mp3 unit. hope this helps!!
Apr 01, 2008 | Sony Walkman NWZ-B105F MP3 Player
Sansa e260 screen not working
does the dial stay on and won't shut off?
Jan 27, 2008 | SanDisk Sansa e260 MP3 Player
It says file system error when i try to turn it on then it automatically shuts off. what can i do to fix the error?? It says File system error when I turn it on and then it turns itself
it says file system error when i try to turn it on then it automatically shuts off. what can i do to fix the error??
Nov 26, 2007 | Creative Labs MuVo V200 MP3 Player
Unable to shut down device - "Bad Track" error msg
You may need to hold down the button for up to 30 seconds in order for your MP3 player to turn off.
Sep 17, 2007 | SanDisk Sansa E280 MP3 Player
Error
Make sure the files your trying to put on there are compatible with your mp3 player. Some files wont go on because they aren't the right file type and so you need to convert those files to mp3s
Aug 07, 2007 | SanDisk Sansa e250 MP3 Player
Philips GoGear SA3245/37  Digital Media Player Logo
267 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
