Question about RCA D61W20 61" Rear Projection Television
  • Willie Howell May 11, 2010
    The itc222 rca chasis. likes to shut itself down. It for safety. DOes the front panel green led flash?. THe processor when it detect one of about 25 different conditions it shuts it down. As a technician i have a computer that reads error codes generated by the processor. in general its mostly high voltage issue, flyback, horizontal output transistor a tube. DOes it make any sounds. chirps. static.
  • RCA Master
  • 5,138 Answers
There is several reasons why tv shuts off/on It could be in Deflection board,SSB board is well know to cause muti problems cost of that board if you can find one starts at $252.00 - Deflection board $197.00 Ck all capacitors cp150,cp114 cp120. if cp150 is puffed up on top it is bad so replace all 3 caps.
Posted on Jan 07, 2009
Tv is a haier model#l42b1180 tv comes on left side not as bright then cuts off after afew minutes
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 19, 2016 | Haier Televison & Video
Sylvania CT202SL8 comes on and cuts off
if as indicated here a combo unit problem can be in player (mechanism) or in the TV section itself----power supply or sweep circuits.
Nov 04, 2012 | Televison & Video
Tv wont turn on
how was the pix on your tv befor it shout off if it look like a 3d piix you have bad con.v ic to see f you do open it up and look for two big ic or stk. and look for the power suppy line and unplug it now tv should come if it do come on you have bad con.v stk 392-120or 110
Dec 07, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Tv cuts off by itself . I turn it on using a cable digital box. Blue light comes on, tv operates for a short period, then an orange light comes on and tv cuts off.
i think its a problem with a lose cable or something inside it
sorry i couldnt be of more help
take it to a repair man for diagnostcs at any point its not something you can fix
Sep 19, 2009 | Vivitek Televison & Video
Tv cuts on and off
This sounds like the flyback on the main circut board needs replaced (part is in 70.00 range!
Dec 12, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
TV powers on, then cuts off by itself. After many on-off tries, tv goes to menu and through it, then cuts off.
TV powers on, then cuts off by itself.  I have no picture, and will not let me control the tv. with remote, or manual.
Jul 20, 2008 | Philips 60PP9202 60" Rear Projection...
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
RCA D61W20 61" Rear Projection Television Logo
32 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
