Question about Hitachi VTMX4510A S-VHS VCR
Tape "was" stuck and now it's worse
I came to visit my folks who own this VCR type/brand... to find my sister had had a 'stuck' video tape. Rather than remove the cover, she poked and pulled the tape out... however... the main tape carriage does not reset, it keeps trying to start then powers down and the main carriage does not reset to 'load' position but grinds the gear track before it can make the turn forward. I took off the cover and face plate but had no success at getting the main carriage assembly to properly track/reset. Wondered if there is a default position or way to re-adjust the gear assembly.
    Novelist:
    Champion:
  • 254 Answers
What may have happened is, that in the process of forced removal, gear timing has been fouled up, assuming the cassette carriage is gear driven. Proper gear positioning is critical, and if it is off by one or more teeth, it won't load the tape properly. Often, there are marks or pointers on the gears which must be lined up, in a particular mode, as specified in manufacturer service literature. If there are gear teeth broken, or cracked gears, then they must be replaced. Servicing in such a case is questionable, as VCRs of the past 10+ years are poorly made, prone to break, disposable. Early units, like back in the '80s, were much higher quality, especially mechanically. Unless this is a high $$ rig, you will probably be better off trashing it, and purchasing something else.
Posted on May 25, 2007
I GOT THE TAPE OUT, BUT THE ARMS WILL NOT RETRACT?
The mechanism of a VCR is very complex. The incorrect removal of a tape will not only have caused the tape arms to be out of sequence, but also caused the electronics to be confused. Inside the VCR is a device called the Mode Switch. This tells the electronics which position the VCR is in. This Switch rotates with every movement of the VCR. When parts of the VCR mechanism are moved out of sequence to the rest, the mode switch will be in the wrong position. So the VCR electronics might think it's in the eject mode when parts of the mechanism are still in play mode.
If the mechanism was working normally the arms would have been retracted as soon as the VCR was powered up. So it's now out of sequence. Pushing a tape into the holder might cause the mechanism to reset, but I suspect that what will happen is that the VCR will either show a fault code or just power off. It does that to prevent the motors causing any damage when it gets stuck.
The only way to solve this problem is to have the mechanism set up in the correct way. This can only be done if you have performed the operation on several VCR's of the same type or have the service manual. The reason you need the manual is because it tells you how the different cogs, wheels and the mode switch need to be positioned. They often have holes are marks on them to aid in the set up. To make matters worse VCR's are rarely set up in the eject mode. Without knowledge of how to set up the video or the manual you will never get it to work properly.
One further thing you will need to check that the removal didn't damage any plastic parts. Plus clean the tape head and any surface that the tape touches.
Jan 02, 2014 | Sony SLV-765HF VHS VCR
My VHS tape will not eject from the VCR. I have a message flashing stating ERR. What can I do to eject the tape?
Hello
The mechanism of your VCR has jammed with video casette tape. If tape ribbon has got twisted around the drum motor head, or the belt that connected to eject [capstan] motor has elongated, this type of fault will occur. Either it will play, rewind, fast forward of eject. Just replace the belts first. In most VCRs the user can replace the belt from underside. Let the tape is there, if it is in, replace all the belts. Belts can be bought from most of the electronic spare part shops at your town. It will come as kit type, each model has its own belt kit, and you have to give them the exact model number of your VCR. Just open the cover of the VCR, and look for tape ribbon twist if any. If it is there, remove it carefully without making damage to any other internal parts, especially to video head. If necessary, cut the tape film. If tape twist is only the problem, it will be rectifed as this twist has been removed. If this also doesn't help you, replace all the belts. OK.
Jul 11, 2011 | GoVideo Go Video DVD/VCR Combo
We recently connected to Direct TV...I want to transfer some old western TV Shows I recorded on my Direct TV DVR Recorder to VCR Tape. I was told by the people at Direct TV that I would need to contact you...
You can try this: Connect your DirecTv to VCR with Red/White/Yellow cables. Then the VCR to your TV with the same type of cables. Make sure the VCR is set to the video input, not the tuner. Turn your TV to the correct video input. Get the program ready on the DVR as if you were going to watch it. Press record on the VCR and then play on the DVR. At the end of the program, press stop on both. You may have a problem with the video recording properly. Some stations broadcast with copyright protection.
Apr 12, 2011 | Emerson Televison & Video
I have a vhs video cassette stuck inside my vhs. Is their any way I can get it out without breaking the vcr. It is an older vcr, but I would like to get my tape out.
You might be able to unbolt the two halves of the VCR to remove the tape, but it depends on the VCR type and how it's stuck. You might end up having to get it serviced, or just getting a new VCR, as I can almost guarantee the tape is probably damaged beyond recovery, unfortunately.
Mar 16, 2011 | Video Game Consoles & Games
Tape stuck in vcr. when you press the eject button vcr starts to work but shtuts off the power Model number DVR-3034N. I have only taken the front and back covers off. Turned slanted roller untill the...
It sounds like the tape is jammed in the vcr, remove the top cover of the machine this will expose the tape. If the tape is spewed in the mechanical section and around the video head, get a pair of scissors and start cutting the tape and carefully remove all tape particles, when all tape debris has been removed, plug in vcr turn on and eject. If the tape looks good, you may have a loading basket problem, bad idler ***. or broken drive belt. "Lets hope for the best"
Jan 25, 2011 | Emerson Televison & Video
My VCR won't play my movies! The tapes are fine its just when I put the tape in it just shows a scraggly screen. Everything is plugged in but my movies won't play. What do I do?
If the vcr is running the tape, your video head is probably dirty, try using a cleaning tape if you have one. The second option is use a brand new blank tape T120 and set the the machine to sp speed (2hr running time) and let the tape run the full course. The third option is to remove the lid of the vcr and carefully clean the video head with a swab dipped in rubbing alcohol rotating the head by hand as you proceed allowing several minutes to dry before loading your tape.
Dec 21, 2010 | Sharp VC-H810U VHS VCR
A video tape has become stuck in my Mitsubishi VCR
Hi, Suggest call a local tv repair shop. Thanks.
Sep 22, 2009 | Televison & Video
Video tape stuck
Unplug the VCR, take the cover off, find the motor (probably on the right side of the mechanism) and turn its shaft with your fingers until you have run the tape back out. Now plug it back in and try it again with a scarificial tape. If it continues to fail, replace all the rubber belts in the mechanism.
Hope ya fix it!
Jan 05, 2008 | Panasonic AG-1330 VHS VCR
VCR stops, ejects, eats tapes
clean the heads and retime the gears.
Nov 24, 2007 | Symphonic WF802
Recording problem on Sony SLV-R1000
The deck needs a good cleaning. Try using a brand new tape and run it on playback for 20 min or so. You could try using a cleaning tape, but many of them are abrasive. If this doesn't work, you need a deck re-alignment which will cost more than your set is worth.
Nov 13, 2007 | Sony SLV-R1000 S-VHS VCR
Hitachi VTMX4510A S-VHS VCR Logo
145 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
