Question about Samsung SC-L906 Camcorder
I need to have microphone connected
I have to connect the camera to the telivision with the a/v cables and have the microphone headet connected to the camera in order to hear sound.
    Scholar:
  • 125 Answers
Can you rephrase the question?
Posted on May 25, 2007
SOURCE:
Where is/are the mic(s) on an Acer H233H display?
The Acer H233H does not have a microphone built into the monitor. Thus you do not have to put tape over the microphone. It does have integrated down-ward firing speakers; the speaker jack is next to the power cord on the back of the monitor. Make sure to connect the included audio cord to the Lime Green audio (speaker) out jack on your computer. All of the jacks on the monitor point down.
If this monitor had a microphone and the blue 3.5 mm audio port, you could keep the microphone disabled simply by not connecting the cable between the monitor and the computer's microphone port.
Acer has the documentation for the H233H monitor in their support section. The direct link to the manual is http://global-download.acer.com/GDFiles/Document/User%20Manual/User%20Manual_Acer_1.0_A_A.zip?acerid=633765057605336286&Step1=MONITOR&Step2=H%20SERIES&Step3=H233H&OS=ALL&LC=en&BC=ACER&SC=PA_6 . This file has the manual in a PDF inside of a compressed folder. You'll need to open the folder to read the manual.
I hope this helps. Web cameras often have microphones. Some laptops often have an integrated web camera; thus they have a microphone mounted on the bezel of the laptop. Blocking that microphone with tape might be useful. I'd block the camera too. For USB connected web cameras, simply unplug the data cable from the computer when you aren't using the camera to disable the microphone.
Jun 07, 2016 | Acer Computers & Internet
Sennheiser md 42 microphone not being picked up on camcorder help please.
This would require a special cable to work. The mic is MONOAURAL with BALANCED output and the camera is STEREO input. This means a special cable is needed and you would probably have to make it yourself as I haven't seen one on the market.Pin 2 of the XLR of the mic would go to BOTH the tip and ring of the plug into the camera. Both pins 1 and 3 of the XLR at the mic would tie to the sleeve of the plug to the camera. If you tried an XLR to 1/8 adapter, no audio would be heard other than from the buillt in mic.
Mar 08, 2013 | Sennheiser MD 42 Professional Microphone
Can a Behringer C-1microphone connect directly into a computer and record? What other equipment will I need? Thanks
you could get away with getting a small behringer mixer that has +48V of power for the mic. Put your mic cable into there and then run straight out using 6.5 (guitar) cable to your computer. you may need some connectors to convert your jack.
Jan 27, 2013 | Behringer C-1 Microphone
Can i connect z5600 to my telivision
Hi Stephen,
You should be able to connect this to your television quite easily ,
there should be a port on the side or back of the screen that has 15pins and is blue this is the VGA, DSUB connector.
you will need a VGA cable which can be bought quite cheaply from ebay connect it to this port and to the same port in the back of your tv.
you can also use Svideo connection which is the circular one , once connector go to display properties and choose display and connect to remote display or something similar on different versions of windows.
hope this helps . allways here to help.
Dec 29, 2012 | Acer Aspire Z5600 PC Desktop
No picture when i turn on console
Change the yellow maybe is bad function, or check the problem with this, like this guy bigo93
Dec 15, 2009 | Sony Playstation 3 (PS3) Console
Trying to connect laptop to 46 in sony bravia, will show desktop but will not show the internet or anything else. please help
When you have the laptop connected to the telivision are you running both displays? In other words is the screen on for the laptop and the telivision at the same time? Sometimes if both displays are on you cannot run programs on both. When you use the FN key and press the display button(usually F5) it should cycle thru each time you press it. Try pressing it until you only have the display showing on the televison only. Doing this should make the telivision the main display.
Sep 08, 2009 | IBM ThinkPad X41 Tablet PC
Rode NTG 2
You'll want to connect it to any mic input using either an XLR cable, or an adaptor cable or transformer appropriate for your input, e.g., 1/4" or 3.5mm.
Aug 03, 2009 | Rode NTG-2 Professional Microphone
Can not install to telivision, need help with wire connections,do not know what hookups go where lost manual,have three connections on wire,red,yellow and white, where do they go on dvd player and to where...
This is very simple
First on the back of your dvd player there should be the holes with the same colors as the cable you have, yellow (video in) in the yellow, red (left audio) in the red e.t.c.
Then either on the side or the back of your tv there should be the same sorta thing, depends if you have a HD TV or a regular freeview/analog tv. With hd there should be green blue red white and yellow, just the same as the DVD player, plug the cables into the right colors as i said,
Same goes for the regular TV, just do exactly the same as you have done with the dvd player,
Switch your channel to dvi or av1/2/3 and your dvd player should be working
Regards
Jul 25, 2009 | GPX D1816 DVD Player
Skype headphones dont work
donmore,
check your microphone settings. first, be sure it is plugged in and on. next, in skype, connect to a call. in my version (3.8.0.188) you can check you mic and speaker settings by pressing the headet icon at the lower part of the screen. i use windows default settings but try others to find one that will work. you can chat with your contact to hel ptroubleshoot the call.
good luck
Dec 28, 2008 | Dell Inspiron 1525 Notebook
How to cconnect my video camera to my telivision to watch my recordings on the telivision
You have not specified the camera you are using, if you are using Canon and with most of the camers a separate cable is supplied in the box for TV attachment, use this cable it is a stereo pin male jack one end and and a audio and vedio on the other side.
Warm Regards,
Manoj Joseph
+91 9352008418
Jun 18, 2008 | Panasonic Cameras
Samsung SC-L906 Camcorder Logo
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
