Question about Uniden Cordless Phone
Flashing 1 on twin Uniden cradle base window.
What does a flashing "1" on the base window of the phone cradle mean?????
  • 3 more comments
  • abcclancy Jan 05, 2009
    Yes, the phone does have a built in answering system.
  • Brad Dunn May 11, 2010
    does your phone have a built in answering system?
  • Anonymous Mar 13, 2014
    solution remove flashing base 1 phone
  • Anonymous Mar 27, 2014
    base is flashing between 88 and 8 will not turn off phone is searching when in base
    Problem Solver:
  • 10 Answers
More than likely the flashing one is letting you know that you have one new message.
Posted on Jan 06, 2009
Uniden dect 6.0 base is flashing 88
I spoke to the manufacturer this morning because I was having the same issue ... I was told that the flashing 88 means that the base unit is has gone kaput and is no longer working. period.
customer service said that this can happen due to electrical issues and the company will send me a new base unit and handset to replace the one that no longer works.
Feb 29, 2012 | Uniden Cordless Phone
Tip
How To Reset and Re-Register Your Uniden Handset and Base
<b>Clear the Handset's Base Data<br /></b>1.To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.<br />2.It will now be de-registered from the base.<br />Note: This requires that the base and handset can communicate with each other.<br /> <br /> <b>Clear the Base Handset Data</b><br />1.To de-register all handsets from the base, remove power to the base, and remove the handset from the base.<br />2.Press and hold the 'flash/find hs' button while applying power.<br />3.Wait for the beep and release the button.<br />4.The charge light will now flash.<br />5.Sit any handset in the cradle.<br />6.When the flashing stops, re-register the handsets to the base.<br /> <br /> <b>Re-Register a Handset to the Base<br /></b>1. Remove Handset Battery.<br />2. Reconnect battery while holding down "*" and "#" key.<br />3. Then press the right upper key under the LCD.<br />4. Press the "End" key.<br />5. Wait a few seconds and then the phone will be ready to register to the base.
on Feb 14, 2011 | Uniden DECT 6.0 Cordless Phone ID
My uniden DSS7855 with 1 base station and 3 handsets wont connect when i dial a number and hit the talk button it tries to connect and then comes up "'out of range" much appreciated for any help...
  1. To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.
  2. It will now be de-registered from the base.
  1. To de-register all handsets from the base, remove power to the base, and remove the handset from the base.
  2. Press and hold the 'flash/find hs' button while applying power.
  3. Wait for the beep and release the button.
  4. The charge light will now flash.
  5. Sit any handset in the cradle.
  6. When the flashing stops, re-register the handsets to the base.
Nov 12, 2010 | Uniden Lands Phones
I just bought another handset (DCX150) to use with my Uniden DECT1580 phone and cannot get it registered for use. The phone is completely charged but after holding down the # key for 30 seconds (as...
I had the same problem with the same equipment and I found this on the web. It worked well for me.
* Remove the base unit's phone from its cradle.
* Unplug the power from the base unit.
* press and hold the FIND button on the base unit, then, while continuing to hold down the FIND button, plug in power again. The CHARGE light should then be flashing. You can release the FIND button.
* press and hold the # (pound) key on the accessory phone you are attempting to register to the base unit and hold this phone OVER and NEAR the cradle/charging prongs until the phone goes through the registration process. (again, don't set the accessory phone in the unit, but just hold it near the unit).
Sep 11, 2010 | Uniden DCX150 1.9 GHz 1-Line Cordless...
My att digital keeps flashing "CL" what does it mean and how do I stop it?
Problem Why is CL ( or C ) flashing in the base message window?
Solution(s) This indicates that you need to set the time and day on your answering system. During initial setup and any time there is a loss of power to the base, you will see this flashing indicator. Consult your User's Manual for instructions on setting the day and time. Manuals for most models can found on this site. Go to our MANUALS section, then search for your particular model.
http://telephones.att.com/telephones_ui/support/dsp_faq_gen.cfm?faqid=233669
Dec 01, 2009 | Uniden Cordless phone EXS9950
Uniden dx18560 in use light keeps flashing-how do i stop it ?
IF LIGHT KEEPS FLASHING IT MEANS YOU HAVE A NEW VOICEMAIL THROUGH YOUR PHONE COMPANY, IF YOU DONT THEN SIMPLY PRESS AND HOLD THE "FIND HS" BUTTON ON THE BASE FOR 10 SECONDS.
Jun 27, 2009 | Uniden 5.8GHz Cordless Phone
New Idelt phone system not ringing on incoming calls
I had placed the base unit where the telephone line enters our home. When I swapped it to the extension all worked properly
Jan 18, 2009 | Uniden Cordless Phone
My base won't stop flashing it just start it today
Our handsets and base are flashing and the base is lit up constantly.
My model is Power Max 5.8ghz.
span.jajahWrapper { font-size:1em; color:#B11196; text-decoration:underline; } a.jajahLink { color:#000000; text-decoration:none; } span.jajahInLink:hover { background-color:#B11196; }
Nov 29, 2008 | Uniden Cordless Phone
Power went off last night and our phone stopped working
I had power outage last night now corder at&t 1855 led's keep flashing keeps telling me about power outage before every new message. How do I get rid of the flashing?
Apr 14, 2007 | Uniden CLX485 Cordless Phone
Uniden Cordless Phone Logo
110 people viewed this question
Top Uniden Lands Phones Experts
Dave Ellis
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
