Question about Mitsubishi VS-45607 45" Rear Projection Television
Rear projection tv mitsubishi vs-5005r
The resistors are not burnt the board looks as if it got hot. they are loose again they are r791 and r 792 i have no picture but i do have sound. do these resistors have anything to do with picture? also i am wondering if they do get hot and if they could be bad? i have not been able to find a schematic for this tv anywhere. the menu works just fine to so i am thinking that the bulbs are good.thanks. my e-mail is
i would really like to get this fixed soon as it is my only tv.
  • 240 Answers
Ok ill give you the proper value but you also need to change IC71012 volt regulator r79 and 792are 12 ohm 3 watt resistors
do not go down in wattage or change value in resistors as sum peole like thinking thay can do this it makes for bad thing to happen.
hope this helps
Posted on Jan 13, 2009
Color distortion, hazy snowy screen with thin red lines, suddenly happened had perfect pic 24 hours ago
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 01, 2011 | Mitsubishi VS-50705 50" Rear Projection...
Burnt smell blush picture
Maybe High Voltage Transformer, you can have a board replaced easier than buying a new set.
Dec 22, 2007 | Samsung PCN5425R 54" Rear Projection...
My picture is almost 3-D like and is red, green and yellow.
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Mitsubishi VS-60609 60" Rear Projection...
I have a mitsubishi VS-50801 rear projection TV that has a very distorted and glichy picture
Ur tv convergence are dead.Ur tv convergence board require changing the 2 STK convergence ICS,and some or all it resistors.The shop will cost u $300-$350 for parts and labors.
May 19, 2010 | Mitsubishi VS-50805 50" Rear Projection...
Where are the fuses for mitsubishi 50111 located and what do they look like?
There is only one user serviceable fuse on the TV set on the PC board, near where the power cored enters the TV (you will need to remove the back to check this fuse (it is labeled F9D00).
The other five fuses look like small resistors and will require desoldering to replace -- I wouldn't recommend doing this without testing the fuses with a Ohmeter first, to determine if they are bad.
Jun 29, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi rear projection tv
"r" usually means resistor if they are burnt it will be hard to identify the band colors on them for thier rating. Depends on if they are quater watt, or 1 watt the diameter size and where they are locted in the circut if its afffecting your picture power. If they are loose from the board means it over heated, resolder may help.
Jan 05, 2009 | Mitsubishi WT-46809 46" Rear Projection...
you have a problem on the chassis. either the FMT, DM, or the terminal board have gone bad. the quickest most effective way to repair would be to repair the chassis. check out
Dec 26, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi VS-5005R big screen
I just finished fixing one of this units and there a few thing that i changed, the voltage regulator and 2 capacitors and as prevention repair i did some resoldering in the power supply and horizontal ckt
good luck
Oct 29, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi VS-5071 rear projection turns on, has audio but no video
That is a VZ3 chassis, similar to Mitsubishi models Ts-4545, Ts-5045, Ts-5545, Vs-4543, Vs-4544, Vs-5043, Vs-5044, Vs-5047, Vs-6043, Vs-6047 and has common failures in the vertical circuit, specifically vert Ic401 which is a La7845 which is usually caused by defective C402 100uf 50v and/or open 1.2 ohm 2 watt R510 next to FBT.
If not that check C268 off Q215 on signal board 22mf/50v and Ic200 on signal module Cxa2025s. However the vertical failure is more likely.
Sep 10, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Burnt Resister
where are these resisters located and whats the part location number on the board
Jan 08, 2008 | Mitsubishi VS-6047 60" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
78 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
