Question about HP PhotoSmart 7760 InkJet Printer
Have tried printing from computer and tried printing test page from printer. both times the pages come out blank.. how do I check the toner levels in printer. thank you
  • HP Master
  • 1,121 Answers
The draw back of inkjet technology printers are, if it is not using quite long period of time,cartridge nozzles will dry up, result printer will act just like a printing some thing but nothing will come on paper(blank page) even ink levels are showing full.
Try to recover the both cartridges through 'clean print cartridge' process from the system,if not better consult cartridge re-filler to clean the nozzles..Replace new cartridges if above said methods are not worked out.
Posted on Nov 10, 2012
SOURCE:
jaylex
  • 417 Answers
SOURCE: HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Posted on Jan 28, 2008
SOURCE: printer prints blank pages
Check to make sure the photoconductor grounding spring on the left hand side of printer in the toner slide black plastic has not popped out of it's slot. Just fixed one a couple of days ago doing this.
Posted on Feb 03, 2008
agnelkj
  • 210 Answers
SOURCE: prints extra blank page for every one page of printed material
hi,
try this
> unplug the usb cable from the computer
> click on "start--> control panel--> printers and faxes"
> select the printer icon associated with your printer and delete it.
> now plug the usb cable to the printer
> wait for few minutes while all the drivers are installed.
thats it... now try to print... it should be resolved
thanks and regards
agnel
Posted on Mar 17, 2008
Joed911
  • 4338 Answers
SOURCE: prints test page every time the printer is turned on
The product aligns the print cartridges every time at cartridge installation or replacement to ensure the highest-quality prints. The alignment page continues to print when the product is turned on or off, or when a print job is started, for any of the reasons below.
  • The automatic alignment process is not complete.
  • The ink cartridges are not properly installed.
  • One of the ink cartridges is defective.
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
Read the info on this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01336397&cc=us&lc=en&dlc=en&product=1146336
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Feb 07, 2009
PeteG0429
  • 34 Answers
Ok, I too have HP Photosmart 7280 and it was spit'g out a blank page after each print page.
I went into the Control Panel/Printers - Right click on the HP Photosmart 7200 series icon and choose delete. Don't worry...just delete it.
Right above (Vista) click on Add a Printer - it's going to ask you if you want to add a local printer which is connected via USB connection or if you are set up wireless then choose Network
It will find your printer click on the printer hit next - then this is the most important step
It will ask you to find the manufacturer it shows Hewlett-Packard and underneath it shows HP - Do not click on HP - you'll have the same problem with that driver - choose Hewlett-Packard and find this driver HP Photosmart C7200 series Version 61.71.244.0 [3/23/07]
Hopefully they are all digitally signed with this information.
Click on that driver and click next - then click on replace the current driver and click next.
Print a test page and problem should be solved. Hope it helped!
Posted on Apr 01, 2009
Why won't it print test page?
If the test page placed face down on the glass does not contain text, you will get blank copies.
Jan 08, 2016 | Office Equipment & Supplies
Color ink problem
Solution one: Check the ink levels To allow for full use of the cartridges, some printers continue to print even after the cartridges are completely out of ink. Follow these steps to check the ink levels in the Toolbox . The Toolbox is part of the standard printer software. Depending on the version of Toolbox on your computer, the appearance of the Toolbox features might vary.
NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, consider having a replacement cartridge available to avoid possible printing delays. Print quality deteriorates as cartridges run out of ink.
  1. Click Start (c01827528.gif ), click All Programs , click the HP folder, and then click the icon for your HP printer (c02053172.gif ). The printer software opens.
  2. In the printer software, double-click Estimated Ink Levels . The Toolbox opens.
  3. Click the Estimated Ink Levels tab to display the estimated ink level of each cartridge. Figure 1: Estimated ink level indicator c02752297.gif Image: Estimated ink level indicator.
  4. If the ink level indicators show that a cartridge is low or empty, replace the cartridge.
  5. Try printing again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Reset the printer Resetting the printer might clear the issues and allow the printer to function correctly again.
  1. Press the Power button (c01602202.gif ) to turn off the printer.
    NOTE: Pressing the Power button might not turn off the printer. This might happen if the printer is in an error state. Continue with these steps regardless.
  2. Disconnect the power cord from the rear of the printer. Figure 2: Disconnect the power cord from the rear of the printer c01869581.gif Image: Disconnect the power cord from the rear of the printer.
  3. Disconnect the USB cable from the rear of the printer. Figure 3: Disconnect the USB cable from the rear of the printer c01850063.gif Image: Disconnect the USB cable from the rear of the printer.
  4. Wait 30 seconds.
  5. Reconnect the USB cable to the printer. Figure 4: Reconnect the USB cable to the printer c01868577.gif Image: Reconnect the USB cable to the printer.
  6. Reconnect the power cord to the printer. Figure 5: Reconnect the power cord to the printer c01869582.gif Image: Reconnect the power cord to the printer.
  7. Press the Power button (c01602202.gif ) to turn on the printer.
  8. Try printing again.
Solution three: Restart the computer Restarting your computer might resolve the issue.
  1. Save the latest changes to your files, and then close all your open programs.
  2. Click Start , and then click Shut Down . A dialog box opens.
  3. Select Restart . Most computers turn off, and then turn on again automatically.
    NOTE: If a dialog box opens with a message that it is now ok to turn off the computer, press the power button on the computer to turn it off. Then press the power button again to turn it on. After a few minutes, the computer is ready to print again.
  4. Reopen the file that you want to print, and then try printing again.
Solution four: Check for blank pages in the print preview If the printer prints all pages correctly, but it adds blank pages to the printout, check for blank pages in the print preview.
  1. In most programs, click File , and then click Print Preview . If the program you are using does not have this option, consult the program manufacturer.
  2. Review the print preview for blank pages.
  • If the print preview reveals blank pages, delete the blank pages in the document, and then try printing again.
  • If the preview contains no blank pages, continue with the next solution.
Solution five: Check the USB cable If the printer connects with a USB cable, a faulty connection might cause the issue. Follow these instructions to check the USB cable.
  1. Make sure that the USB cable inserts all the way into its port on the rear of the printer. Use some pressure to push it in all the way. Figure 6: Insert a USB cable into the rear of the printer c01868577.gif Image: Insert a USB cable into the rear of the printer.
  2. Make sure that the USB cable inserts all the way into its port on the computer. Use some pressure to push it in all the way.
  3. If the issue persists, try replacing the USB cable with a known good cable.
Solution six: Check the printer settings on the computer Issues with the printer settings on the computer might cause the printer to print blank pages. Follow these steps to check the printer settings on the computer. Step one: Check the default paper settings Make sure that the default paper size matches the width and length of the paper loaded in the tray. If the paper loaded in the tray is different from the paper size setting, the printer might print blank pages. For instance, the issue might occur if legal size paper (215 x 355 mm (8.5 x 14 in)) is in the tray, and the paper size setting is letter (215 x 279 mm (8.5 x 11 in)). Follow these steps to check the default paper settings.
  1. Click Start (c01827528.gif ).
  2. Click Printers and Faxes . The Printers and Faxes folder opens.
  3. Right-click the icon for your printer (c01532298.gif ), and then click Printing Preferences . The Printing Preferences window opens.
  4. Click the Paper/Quality tab, and then compare the settings in the Paper Size drop-down menu with the paper in the tray. If the size of the paper in the tray is not the same as the setting in the Paper Size drop-down menu, change the setting:
    1. Click the Paper Size drop-down list, and then select the size of the paper that is in the tray.
    2. Click Apply to save the settings, and then click OK to close the Printing Preferences window.
Step two: Print a test page Follow these steps in the order presented to print a test page. A test page might help determine if the printer installation caused the problem.
  3. Right-click the printer icon (c01532298.gif ), and then click Properties . The Properties window opens.
  4. In the General tab, click Print Test Page . The printer prints the Windows XP Printer Test Page. Figure 7: Example of Windows XP Printer Test Page c01532301.gif Image: Example of Windows XP Printer Test Page.
  • If the Windows XP Printer Test Page prints successfully, you do not need to continue troubleshooting.
  • If the page is blank, continue to the next solution.
Solution seven: Print from an alternate program Follow these steps to try printing from an alternate program, such as Microsoft Notepad or WordPad, to determine if the current program is causing the issue.
  1. Browse to the location of your saved document, right-click the file, and then click Open With . A window opens with a list of programs.
  2. Select a program other than the program you are currently using to print the document.
  3. Open the file in the program, and then check the contents.
    NOTE: Most files open in plain text applications, such as Notepad or WordPad, even if the contents include unusual symbols or text that does not make sense.
  4. Try to print the file:
    1. Click File , and then click Print . The Print window opens.
    2. Select your HP printer from the Select Printer drop-down menu, and then click OK .
    If successful, the printer prints exactly what displays in the program window.
    • If the document prints successfully in the alternate program, you do not need to continue troubleshooting. The issue is likely specific to the program you are trying to print from. Consult the program manufacturer for assistance.
    • If the document still prints blank pages in the alternate program, continue to the next solution.
    • here are a couple things you can try hope this helps you
Apr 19, 2013 | HP Deskjet 2050 All-in-One Printer
Magenta toner spots pages
Step 1:
Print out about 10 blank (all white) sheets and see if the spots clean off.
Step 2:
Check to see if the toner is Dell type brand, if not try installing Dell brand and run 10 blank copies then run color test print using menu key.
Press menu, press arrow down key till 'print reports' is displayed, Press 'check key' then press down key till 'color test print' Press check key to print color copy.
Apr 10, 2013 | Dell 3010cn Laser Printer
We changed the toner on the printer and it prints a blank page. What do we do
If new toner was installed and it prints blank pages, please try to print a menu settings page to determine if the problem is part of the printer or an issue external to the printer.
If the menu settings page prints correctly, the source of the problem is external to the printer. To find out if the problem is only with a program, try printing from a different software program. To find out if the problem is only with a particular computer, try printing from a different computer.
If the menu settings page is blank as well, this will narrow the source of the issue to a part on the printer. Please contact Lexmark Technical Support for further assistance.
Aug 12, 2011 | Lexmark E260dn Laser Printer
We understand that your problem is: Sir, iam jithesh from india,kerala.I have one printer samsung ml1210 printer .give the one print blank page coming automaticaly picking second papper blank page coming...
hello ,
first check your toner cartridge. some time your toner cartridge is damage then black print out is coming.
then check your machine printer and faxes ,check print pages status.sometime their have early print outs.
didnt solve your problem you have to replace main board
Jan 18, 2011 | Samsung ML 1210 Laser Printer
Printing blank pages on Lexmark C510 printer. Throws a 34 Short Paper error first, prints out a blank page. I have replaced the black toner, but problem continues. Demo page printed colors successfully but...
For 34 Short Paper error, reseat the tray guides and make sure it is set properly. Also, set the correct settings in the computer. For blank pages, always double-check the paper settings and again the settings in the computer. For not printing black, print the Print Quality page and see what color is not printed or not showing. If Print Quality shows black, try printing any document from any application in the computer. Check if you still have the problem. If problem is not resolved, leave a comment so I can get back to this.
Apr 09, 2010 | Lexmark C510 Laser Printer
Lexmark 640 series
Try printing something from the "utilities" menu. If you can print from any of the menus directly on the machine, then the issue is related to connectivity with your computer. If not, then it may be best to try a new toner cartridge.
Jul 10, 2008 | OKI C5100n Laser Printer
HP PhotoSmart 7760 InkJet Printer Logo
161 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
