Question about GE DVLR223 Dryers
MY GE DRYER SOUNDS LIKE THE DRUM IS GETTING CAUGHT ON SOMETHING
WHEN I TURN THE DRYER ON IT SOUNDS LIKE THE DRUM IS CATCHING ON SOMETHING EACH TIME IT ROTATES. IF YOU LET IT GO IT IS A SCREACH
  • James Chandler May 11, 2010
    Doe the noise seem to be louder in the rear of the dryer about middle of it? post make and model too please. more help with that info
  • 193 Answers
The drum is supported in the front by two drum slides.You need to check them for visual damage
Posted on Sep 29, 2009
My dryer keeps getting lent bevingld the drum & catching on firem i changed the element & cleaned out all the lent & a week later it caught on fire again. Any ideas?
what's the brand name and model number?on some electric dryers like ge or frigidaire that have the heater element on the back wall of dryer the drum has a metal ring around the back of it and the lint builds up in it,you have to remove the drum and clean the lint out,if you open the door and look through the holes in the back wall of drum you sometimes can see it and it gets thick,you can try to vac it out through the holes,if you have a stinger vac or shop vac set it to blow and blow through the holes and vac it some more but the best way is to remove the drum and clean it.you should do this at least once a year,clean out the inside of dryer,the duct where the lint filter slides down into and the vent line,if you do this your clothes will dry on time,the parts will last longer like the motor,usually is covered in lint and you won't have a dryer fire.
Dec 04, 2017 | Dryers
Model de08-us1
-The seal is shrink so every gap is over size.
-The only thing will eliminate this problem, replace new seal.
Good Luck
Mai
Dec 19, 2013 | Fisher and Paykel DEGX1 Electric Dryer
My Gallery Series dryer makes an intermittent noise when i turn on the dryer. It sounds like the drum is getting caught up on something. It sounds like grinding gears. The noise comes and goes
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 08, 2011 | Dryers
Our cloths are snaging between the dryer door and the front wall on the handle side of the door (left side). There so stuck that they rip a hole in them when we free them.
Sounds like you front drum support / bearing is wearing out. When the support wears out, a gap occurs between the drum and drum support, That is where the clothes are getting caught, Does your dryer squeak when running? If so, then replace the front drum support / bearing. Cost about $35 - $40.
Jan 24, 2011 | GE DCVH515EFWW Electric Dryer
I have a GE DX4500EE1WW electric dryer. Over the weekend it stopped working. If you turn the start dial you can hear it hum so I know it's getting power but the drum won't turn. I've tried it on every...
MOST LIKELY A BAD MOTOR OR SOMETHING CAUGHT IN THE BLOWER WHEEL. UNPLUG UNIT, TAKE TOP PANEL OFF AND THEN FRONT PANEL. PULL THE DRUM AND BELT OUT AND LOOK INTO BLOWER HOUSING FOR RESTRICTION AND SEE IF YOU CAN TURN MOTOR BY HAND.
Oct 06, 2010 | GE Dryers
GE profile electric dryer, sounds like something is stuck in drum
Heating problem is most likely caused by one strand of your heating element is burned out. Heating element will have to be replaced if that's the case. Noise you are hearing is most likely coming from worn front and / or back bearing. Dryer has to be completely disassembled for either repair.
Aug 28, 2017 | GE Profile Harmony DPGT750EC Electric...
I have a GE DSXH47EG0WW dryer and clothing is getting caught along the edge between 2 parts of the drum. This is causing fabric to tear. Any way to stop this from happening?
if its in the front of dryer you need the front brg and felt replace and the 4 slides . if in rear of drum replace rear barg and do the front . may also need a belt and idler . dryer sounds like if done a few loads .. hope this helps mm
Dec 03, 2009 | GE DSXH47EGWW Electric Dryer
Clothes are getting caught in the felt around the
sounds like your front bearings are worn turn of power remove front panel and replace hope this helps
Nov 12, 2009 | Washing Machines
GE dryer, black grease stain on cloth
I have the same problem, I haven't resolved it but it seems to be due to the drum of the dryer being able to move more than it's supposed to and things getting caught in between the drum and whatever it sits in, at the front of the dryer. I have found things caught in there before and when I've pulled them out they had a brown/yellow grease stain on them. Other times something in the dryer will have this same stain - although no longer caught it seems it must have been caught at some point then became free again, with the stain. I'm thinking something is loose or if the drum is supported at the back by a bearing of some sort, this bearing may be worn down and the drum isn't sitting right.
Dec 19, 2007 | Dryers
Drum not turning
Have you recently lost a sock or a pair of drawers? Something mught be stuck in the impeller blower fan) attached to the motor. Very common problem
Dec 08, 2007 | GE DCSR483EA Electric Dryer
GE DVLR223 Dryers Logo
91 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
