Question about Kenmore 98702 Stacked Washer/Dryer
No Motor Action / No Tumble or Spin / Kenmore 417 4405240
The friendly Sears repairman just departed. I'm extremely disappointed by repair estimate of $396.69 to replace the MAIN CONTROLLER of Kenmore Model 417 4405240 (Frigidaire manufactured). Out-of-warranty; 2+ years old. What rubbish quality! Problem: during a heavy towel load, the washer tumbler action stopped. According to repairman analysis, both the MAIN CONTROLLER and MOTOR CONTROLLER are not powering -- which most likely means the MAIN CONTROLLER is the primary problem (as main controller feeds power to motor controller). If motor controller may also need to be replaced, estimate cost will escalate. Originally new apppliance cost $475 ($600 minus $125 utilities rebate). I've decided it is UNECONOMICAL to repair. Anyone else outraged by uneconomical repair estimate for young appliance?
  • 15,935 Answers
Yes, I am!!
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Kenmore elite E3t F11 error code
The "F11" fault code will display if the Motor Control Unit (MCU) has an internal failure; repeating under or over voltage, or over current conditions. If failure occurs during high speed spin the door unlocks after 3 minutes. The MCU (Motor Control Unit) is located beside the motor. See images below. Key #13 is the CCU and key #1 is the MCU.
The CCU (Central Control Unit) is located under the top along the side panel.
I recommend checking for loose wire connections at the MCU, CCU and motor. If you do not get any motor action at all, the MCU has likely failed.NOTE: Disconnect the power cord from the power source before removing the top and lower access panel. I recommend calling a service technician to diagnose and repair your washer.
Parts can be looked up and ordered at Sears PartsDirect
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website:Sears Home Services .
Dec 16, 2012 | Kenmore Elite 45986 Front Load Washer
I have Kenmore Series 70 using about 4 years. I realized that my washer won't empty out the water and won't work any of spinn either. Someone told me that need to switch time click and others? How can you...
Assuming that this is a basic Kenmore / Whirlpool direct drive, top load, neutral drain washer.
If the machine fills with water and goes through its' agitate cycle, the motor is working as is the transmission (At least in one direction.
The timer on type of machine reverses the motor to drive the pump and run the spin cycle.
If the machine.
Check this Sears parts site and the Whirlpool Installation and maintenance document to see how the machine works. It appears that you do need a timer.
Sears parts:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components.
Whirlpool document:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Sep 22, 2009 | Kenmore Washing Machines
Kenmore front load washer #44072 drum banging noise
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
Mar 29, 2009 | Kenmore 44072 Front Load Washer
Kenmore Tumble Action Washer won't go to spin cycle
im a repairman,lets reason this out.if washer wont spin because the tub is so warped that when it spins its so out of balance then ok new tub.or the tub welds are broken and some part is dragging and not letting it spin then ok new tub.or spin bearing has failed and ruined tub support shaft,ok new tub.but why else would you need a new tub for a no spin problem,not sure,and to answer your other question , can you fix the tub if any of the above problem exist.no you would have to replace tub.i hope that helps,God bless ,tom....ps if i have been helpful please remember to help me with my ratings,tom
Jan 06, 2009 | Kenmore 43142 Front Load Washer
Flashing F6 Error Code
motor controller board in bottom
Nov 11, 2008 | Kenmore Elite 45986 Front Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Gearcase woes
Okay...after working on these model washer numerous times, it is NOT uncommon for a gearcase to fail. At least, it wasn't in my area of the country. It's also not as big of a job, nor an expensive one. A new gearcase runs about $163 at searspartsdirect.com. Just type in your complete model number and locate item number 9 under the "Brake/Clutch/Gearcase/Motor/Pump" heading. The part number is 3360629. If you decide to replace this on your own, the following link explains how to replace the gearcase step-by-step:
http://www.fixya.com/support/r699497-replacing_gearcase
You would be amazed at how easy it is to perform this repair. I've personally done many of them. I don't know where the DIY estimate came from, but this repair should not cost you $300. I would recommend, however, that if you replace the gearcase, to replace the motor coupling as well. I hope you find this information encouraging. Let me know what you decide.
Oct 08, 2008 | Kenmore 22622 Top Load Washer
Kenmore Front Load "tumble action washer"
Our Sears repair guy says the tub bearing needs to be replaced. Get a new washer? Don't buy another Frigidaire...
Jun 20, 2008 | Kenmore 43142 Front Load Washer
90 series top loading Kenmore washer
if it fills and drains but no agitate no spin it is likely the motor to transmission coupling easy fix 10 dollar part. chat can talk you through it let me know if you need help
Mar 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore front Loader 41729042990
remove motor, check carbon brushs,replace if short,the manual may help.motors that have brushs are the principle,sole motor is Italian,yours is German,anyway thats beside the point ,its the brushs.buy ,eire
Dec 11, 2007 | Kenmore 44102 Front Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
448 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
