Question about Trendware TEW-432BRP 54Mbps Wireless Firewall Router
Wireless is not secure
I would like to secure my wireless with a pass word
  • 43 Answers
Step 1 Log into the Router
A device which forwards packets between networks. The forwarding decision is based on network layer information and routing tables, often constructed by routing protocols.'); return false">Router
by entering it’s IP address into a browser. The default IP address is http://192.168.1.1. At the login, enter your username (admin) and password (admin).
Step 2 Click on “Wireless” on the left hand side then click on “WEP” at the top of the page.
wireless is not secure - tew-432brp_f_1.jpg Step 3 Enter in the desired encryption values then click “Apply”.
Examples:
Authentication type:WEP WEP
Type: Open
System Mode: Hex WEP
Key: 64-bit Key 1: 0000000000
Note: For WEP you can choose ASCII or HEX modes.
64bit ASCII = 5 digit ASCII key.
64bit HEX = 10 digit HEX key. (Can only use letters A~F and numbers)
128bit ASCII = 13 digit ASCII key.
128bit HEX = 26 digit HEX key. (Can only use letters A~F and numbers)
You can also choose WPA
Wi-Fi Protected Access (WPA) is becoming the wireless security standard. It is a higher level of security than WEP that combines encryption and authentication to create an unbreakable level of protection. For small office and home users the WPA preshared key (WPA-PSK) is the easiest set up and does not involve a Certificate Authority Server, which is recommended for small and large business customers. Once the preshared key is set-up on each network device, every packet sent over the wireless network will receive its own encryption key under the Temporal Key Integrity Protocol (TKIP). A key benefit to WPA is that it is backward compatible with WEP-only devices. For those users looking to ensure those who share keys are who they claim to be a Certificate Authority Server or RADIUS Server can be added. This requires a more complicated set-up and is not recommended for smaller networks. Also, one thing to note is that WPA adds to the packet size, typical transmissions will take longer.'); return false">WPA
-PSK. The key must be between 8~64 digits.
Authentication type: WPA
-PSK
Passphrase: omg laserbeams pew pew pew
Confirm passphrase: omg laserbeams pew pew pew
Posted on Jan 06, 2009
Wpa2 pass phrase
You'll have to connect to the router through a wire, log into ints web-based configuration page (192.168.1.1 by default) and see the wireless security from there in the "Wireless Security" section.
good luck,
Majdi
Dec 28, 2011 | Linksys WRT150N Wireless Router
What is the security code for 2wire870, wifi
1. USER :Admin
PASS : Wireless
2. USER :Admin
PASS:1234
3. USER:Admin
PASS :Password
May 10, 2011 | Computers & Internet
Need to secure my router
Try the following procedure on a computer that's directly connected to one of the router ports with an ethernet cable. This procedure will not work if you're connected wirelessly. Open a web browser, such as Internet Explorer, and type in http:192.168.1.1. A window should pop up asking for a user name and a password. Don't enter a user name and type admin for the password. Hit ok. The router setup screen should come up. Click on the Wireless tab and then the Wireless Security sub-tab. You can set up encryption on your wireless network using this screen. First select the security mode you want to use. I believe WPA gives better security but I've had some trouble using it on older computers. I use WEP. I've been able to get this encryption scheme to work with all of my computers. Next select the type of encryption. I like 128 bit 26 hex digits. Next enter a pass phrase and hit generate. The pass phrase is like a password. It should now generate four 26 character keys made up of various letters and numbers. Write down the first key and make sure you've checked the 1 box for default transmit key. Save your setting and exit. You wireless network is now secure. If you try to connect to it using a wireless device you will be prompted for a security key. Depending on the operating system you're running, you may just be able to enter the pass phrase or you may need to enter the 26 character key you wrote down. You should only have to do this once for each of your wireless computers. After the first time the computer connects to the secured network it should automatically remember the security code. I hope this advice helps you out.
Apr 19, 2011 | Linksys Wireless-G WRT54G Router
Security lock has vanished, how do I make my system secure again?
you will need to browse to the following location 192.168.0.1 on internet explorer or another browser.
the default login/pass is
  • Username = admin
  • Password = password
  • or pass = 1234
  1. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
  2. From the center screen, select your encryption type from under the Security Options heading.
    • If the wireless network passphrase is visible, review it and use it to log devices onto your network.
    • If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
Mar 27, 2011 | NetGear WGR614 Wireless Router
What if i want to secure it. do i need the cd?
Im not sure what you are saying is your problem.
To secure your wireless network you first need to log into your routers configuration settings to do that in your address bar of your browser type http://192.168.0.2 enable either WEP or WPA security and tell it what security key or pass phrase to use.
Then on your computer when you try to connect to your wireless routers signal it will ask you to put in the security key or pass phrase you selected and thats that. You are secure.
Sep 30, 2010 | D-Link DIR-615 Wireless Router
What is wpa pass phrase while setting wireless printer
WPA with a Pre-Shared Key (PSK), also known as personal. PSK is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
WPA pass phrase is a password for the wireless network to make it secured. You can obtain the WPA pass phrase when you access your router. Check the manual of your router for the address, username and password of your router. Go to wireless settings, you will see ther the SSID or Network Name, Network Key or the Pass Phrase and Authentication (WPA/WPA2/WEP). You can personalize the SSID,Network Key and Authentication. Remeber that for you to connect wirelessly the Authentication and Network Key on the router should match the Network Key and Authentication of the Printer or Computer.
Thanks for using Fixya,
Aug 06, 2010 | Computers & Internet
My daughter set the router up and then moved out with the setup disc and she doesn't remember the pass code. My signal is not secure and my neighbors all use it. How can I make it secure? It always wants...
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Aug 04, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Need a security pass for wireless router
HI Friend
please follow the steps
1. Click the start menu on the desktop after connecting your desktop or laptop to your router.
2. Click RUN and type cmd and hit enter
3. In the black box type ipconfig/all and hiot enter
4. Note down the default gateway and exit from the black box
5. Open internet explorer and type the default gateway number and hit enter
6. If you have changed the default password and username then enter that or else leave blank the username and in password type admin and hit enter
7. Now in the setup page click wireless and under wireless click wireless security
8. Now select whichever security option you need and enter the passphrase and save settings
9. Turn off the router for 30 seconds.
Now your network is secured.
Enjoy
Regards
Chiranjeet
Dec 27, 2009 | Linksys Wireless-G Broadband Router
How do I put security on my Belkin 54g router
You set your security by enabling WEP.
When you get in the interface to configure WEP, set a pass phrase. Write down the 3 numeric keys it generates. Then connect to the wireless using your laptop, etc. When it asks for your passkey, do not enter the pass-phrase; enter one of the three keys that were generated by the router. That's the biggest mistake people make when trying to get wireless to work.
Oct 06, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
My neighor stealing my signal
You need to encrypt your wireless signal. Here are some instructions for getting in to your router's control panel.
Once you manage to log in, find the firewall region or wireless security region. Make sure to encrypt your wireless connection with the WPA-PSK authentication method using the TKIP encryption. Make sure to write down your pass-phrase, as you will need it to connect to your wireless connection.
Jan 31, 2009 | NetGear WGR614 Wireless Router
Trendware TEW-432BRP 54Mbps Wireless Firewall Router Logo
348 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
