Question about Lexmark 2480 Matrix Printer
Lexmark 2480-100 stops printing after one page
After any printer job, printiner ceases and Led lights 1, 3, & 4 start flashing. is this a built in error code message?
    President:
  • 8,637 Answers
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
  • Weldon Dube'
    Weldon Dube' Jan 25, 2009
    Normal
    0
  • Weldon Dube'
    Weldon Dube' Jan 28, 2009
    Normal
    0
    Normal
    0
Why is the light flashing on the right side
If the light flashing is the "light bulb like button" or the "Ready/Light" button, it means that either the printer is:
• The printer is busy receiving and processing data or printing.
• The printer is printing a directory, font list, menu settings pages, or Print Quality Test Pages.
If it's Busy:
• Wait for the message to clear.
• Press and release Cancel to cancel the print job.
• Press and hold Cancel to reset the printer.
If it's printing a directory, a font list, menu settings pages, or Print Quality Test Pages:
• Wait for the pages to print. The Busy message is displayed as the pages print. The Ready light is on when the
printing stops.
• Press and release Cancel to cancel printing.
Jul 31, 2012 | Lexmark E250dn Laser Printer
LexMark e321 printer is printing blank pages. I changed out the ink toner, reinstalled the driver from the E321 disk, changed the USB cable and still get 2 blank pages and the LED button by error is...
Try to disconnect all cables from the printer and leave it off for about 30 seconds to clear the print job. Turn the printer back on and check the status lights, error light stop blinking then try connecting the printer back to the computer and try printing again.
For further assitance, please contact Lexmark Technical Support
Jul 20, 2011 | Lexmark E321 Laser Printer
Prints one or to pages then stops. Have to reset computer to get it to work. No test doesn't work. It is like it runs out of memory.
Try to run a test for continuous print test page in diagnostics mode. To enter the Diagnostics mode:
1. Turn off the printer.
2. Open the front access door.
3. Turn on the printer while pressing and holding Cancel .
4. Close the front access door once the Error light displays. Print the menu page by pressing and holding Continue until all of the lights flash. Follow the instructions on
the menu page to access the menu items.
Continuously print pages containing cross lines, printer information, and margin settings. Press and hold until the Continue button lights flash to begin. Press Cancel to stop.
Make sure he selects the "Cont Prt Simplex Tray 1" option
If problem persists, contact Lexmark at 1-800-LEXMARK()1-800-539-6275.
Apr 21, 2010 | Lexmark E260dn Laser Printer
I have a Lexmark 3350 and running Vista, I have a print job that will not delete and it's holding up other print jobs. How do I get rid of this print job. it says it deleting but it's just stuck.
Try this. Follow the instructions carefully:
First, you have to stop the Print Spooler. To do this:
1. Click on the Windows logo start button.
2. Go to Control Panel
3. Open Administrative Tools
4. Open Services
5. It will pop-up a Services window. Scroll through the list and look for Print Spooler.
6. Double-click on Print Spooler, and click on the Stop button. Click on Ok button. Set the window aside.
Second, you need to clear the print jobs in the Spool folder. To do this:
2. Type Spool in the Search bar.
3. Open Printers folder
4. Delete all the files in the Printers folder. Close the window.
Third, you have to enable the Print Spooler again. To do this:
1. Go back to Services window.
2. Double-click on Print Spooler, and click on the Start button. Click on Ok button. Close the Services window.
Click on the Windows logo start button. Go to Control Panel and open Printers folder. Refresh the page. That should clear the print queue now.
Apr 07, 2010 | Lexmark X3350 All-In-One InkJet Printer
Our lexmark e234 printer has all lights flashing. Last job was 30 page document which printed out fine, then all lights started flashing. We have not been able to print since. Thank you:)
Try resetting the printer to factory Defaults. First turn off the printer, then open the front cover like if you were to take the toner cartridge out. Once the front cover is open then push and hold the two buttons on the panel of the printer and turn the printer on. Make sure the front cover is open and that you are pushing the two buttons all the lights will flash and they will stop at the very bottom light and stay solid once that happens let go of the buttons and close the cover and that should reset the printer.
Jan 26, 2010 | Lexmark E234 Laser Printer
LexMark 3350 Printer often stops printing in mid multi-page
If printing is stopping in the middle its not the Problem with the driver
Check the Spooling Properties
Checked Printing Test Page
Jan 06, 2010 | Lexmark X3350 All-In-One InkJet Printer
Lexmark X2350 printer problem
Usually the light blinks if you have started a print job and run out of paper...it's trying to get your attention to insert more paper before it can continue. Check and see whether there are any print jobs that weren't able to conclude and delete them. Go to 1) Start, 2) Control Panel, 3) Printers and Other Hardware, 4) View Installed Printers, 5) Lexmark 2300 Series. When you double click on the Lexmark Printer Symbol, it will open up a smaller window which will show you whether there are any print jobs that are waiting to print. If there are any, delete them. Hopefully this will solve your problem.
May 08, 2008 | Lexmark X2350 All-In-One InkJet Printer
Slow printine
What memory dimms have been fitted.
Print status page see top right. May need more memory and a hard drive.
cheers
May 02, 2008 | Kyocera FS-C5030N Led Printer
Lexmark 2480 Matrix Printer Logo
143 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
