Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
GE Profile DW keeps restarting PDW8200
The past couple of days our DW is possessed.  It keeps beeping and starting a new cycle.  Last night when I went to bed at 12, I started the DW.  This morning at 6:30, I heard it beep, and then began to fill with water.  This has happened on a few occasions so far.
5 Suggested Answers
SOURCE: start button on the HMI won't work
There is a ribbon cable that connects to the control panel. Mine was operating the same as yours. I opened up the front and reinserted the cable and its been fine ever since. you need to take all the screws out from the door panel inside the washer to geet to it.
Posted on Nov 17, 2007
MNTECH
  • 1543 Answers
SOURCE: i have a ge profile pdw8200 dishwasher. it go thru
Check the electrical connections where the power enters the dishwasher. (behind the lower kickplate, on the right side of the machine) Open the metal cover, hold on one of the twist on wire connectors, and firmly tug each wire to make sure none are loose. Check all the wires. There is a good chance one of the wires will come right out of the twist on wire connector when given a tug. Correct the poor connection, and you should be good to go.
Posted on Jan 23, 2011
SOURCE: GE Profile Dishwasher beeping
Mine was doing the same thing. It was eligible for a recall.
Free repair or rebate toward new purchase. 1-877-275-6840 or go to website geappliances.com
Posted on Jan 30, 2011
SOURCE: GE Profile Dishwasher PDW7300 Died on me!
Thanks for the pointer on the arcing. Funny thing is .. I did the electrical myself and I always make sure things are tight and connected properly. Was a little shocked to see the melted wires and caps. I soldered them this time .. if it happens again it was not arcing. Im going to check with GE and see if there was a recall or not. The wires to the washer seem a little too high gauge to me.
Posted on Jul 22, 2012
Model SHP65T55UC. Why is it beeping?
Hi. I will try to help you.
If what you saying is right, after you hit start. And after some time the dw should indicate a error. I need that error code to be able to help you.
Kind regards
Geir
Technical service enginer @ Bosch Siemens appliances
Feb 15, 2016 | Bosch Dishwashers
GE Adora dishwasher model ddt575smf0es leaking from condensation
Sounds like a poor install. If the hoses aren't collected correctly heat from water could cause expansion therefore looser doors and hinges. Make sure the water connections are tight and then check the screws at the bottom of the door. you shouldn't need a pro to fix.
Feb 25, 2014 | GE Adora GHDA654LBG Dishwasher
GE Profile 30" slided in range/oven. Ran standard
shut down the power to the machine,disconnect the touchpad ribbon,turn the power back on and let it sit for a day,if the code comes back you have a bad board,if it doesn't come back you have a bad touchpad
Apr 02, 2011 | GE Profile 30" Self-Cleaning Slide-In...
I have a ge profile pdw8200 dishwasher. it go thru a patial cycle then shuts off.
Jan 23, 2011 | GE PDW8200NWW / PDW8200NBB Dishwasher
Jul 01, 2008 | GE 24 in. Profile PDW9200J Built-in...
Keeps beeping and shows F3 but keypad not working
Ya what the ????
Not shure what to tell you, first I would see if leaving unplug for a day would solve your problem, to me sound like main board is defective, also try by opening the door a closing it a couple of time, just in cass a switch is jam open.
Regards
bob
Jan 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE DW beeps and won't start
look for parts for the unit. you indicate its defective. if you can't replace the parts yourself, then you will need to get a repairman in for that.
be careful regarding the cost. some home repairs cost more than a new unit, so if its a base level unit (low cost) you might want to consider a new unit. you can also save money by taking the unit in to the service center. call first and work out a deal in advance. this only makes sense if you have a lot of free time and do not value you time very much.
good luck
mark
Dec 02, 2007 | GE 24 in. Profile PDW7800 Built-in...
Start button on the HMI won't work
Nov 01, 2007 | GE 24 in. Profile PDW9800J Built-in...
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
133 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
