Question about Yamaha HTR-5830 Receiver
Volume control broken
My grandson broke the volume control knob off of the receiver. The plastic peg inside of the knob broke in half. Is there an easy way to fix this without replacing the potentiometer?
  • 32 Answers
You can purchase clear 2-part epoxy products at most home improvement stores. You will also need masking tape (or similar) a popsicle stick (or similar) a small piece of cardboard and a toothpick.
Mix the epoxy with the popsicle stick and apply a small amount to the exposed surface of the volume control's stem. Holding the knob in place, run a strip of tape from the top of the unit, across the knob and to the bottom.
These epoxies are very strong and fast setting. It's probably best to leave the tape for at least 8 hours but you should refer to the instructions for the epoxy you buy.
Good Luck,
Posted on Jan 05, 2009
Is the volume knob made of plastic or metal?
I checked my Yamaha receiver and the knob is plastic. A cheap plastic knob can be vacuum plated to resemble the metal knobs that were used many, many years ago.
Mar 07, 2014 | Yamaha A-s2000sl Natural Sound Stereo...
I have a Lexus es300, year 1993, the radio's volume control broke off, is there any way to fix it??
If it is a knob and you have the pieces, crazy glu will do it. If not you will have to get it replaced.
Mar 16, 2013 | Lexus 1993 ES300 Radio a1z101720 receiver,...
Kenwood VR-6070: Broken volume knob; will IR sensor still work?
Looks like you have several faults?
First try to fix the remote:
May 28, 2009 | Kenwood VR-6070 Receiver
880 universal remote volume button broke. little rubber botton on inside that pushes the volume button on inside broken.face plate cracked and arrow button on left right underneath face broken and missing...
My volume button also broke (actually, the VOLUME UP function stopped working). Rather than trying to get the remote fixed, I found a different solution...
I reprogrammed the + key (bottom left of the remote) to be my new Volume UP function. You can do this by going to any of the activities you've already defined, and adding a custom button to the activity.
Choose the + button (it will probably not have an existing function), and tell it to use the Volume Up function of the component you normally use for volume. In my case, it was the Home Theater Receiver.
I hope that helps.
Mar 02, 2009 | Logitech Harmony 880 Universal Remote...
Yamaha RX-V800 volume knob on receiver not working.
It sounds like the volume control pod has gone bad and needs replaced (The knob shaft connects to the pod main body and the inside of the volume pod is what controls the rate of volume,If the inside becomes worn ,broken or dirty the volume will become erratic) Replace volume pod ! ..You may try cleaning by taking off the volume knob and getting a can of pressure air and blowing the dust out!
Please rate response!!
Jan 06, 2009 | Yamaha RX-V800 Receiver
Broken volume knob
I located the remote control for the unit and it works fine. As the unit is not the primary amplifier for the home stereo system, I use the remote to control the volume. Thank you for your quick responce, and I will keep you in mind for any future needs.
George Keeler
Dec 31, 2008 | KLH R5100 Receiver
Volume Control
The volume control shaft lube, over time and heat exposure, will flow down and corrupt the contact between the volume twister and the spring loaded sensor. Pull the cover off the tuner, locate the volume control and take out the two screws holding it in. It looks like a small circuit board with the volume twister attached.
The base of the twister is hooked to the circuit panel by four metal tabs. Pry these guys gently away and pull the twister free. There will be a metal disk at the end of the volume control shaft, and will have a goopy lube residue on the face of it that can be cleaned with electric contact cleaner or some other kind of solvent. Wipe it clean,(do not immerse) reattach, and test. Worked perfect for me.
Good Luck,
Feb 25, 2008 | Pioneer VSX-D509S Receiver
Volume knob
Normal Aiwa compact shelf units use what is called a jog switch for the volume. Usually you can tell the difference if when you you turn the volume up or down. It goes a short distance and seems to spring back. In this case there are two momentary contact switches. One for up one for down. With a plastic lever on the back of the knob that bumps the approriate switch whether turning down or up. If the lever is broken it will bump up against one but not the other. If it is broken plastic you know how good gluing plastic goes it never seems to hold.
Aug 02, 2006 | Aiwa NSX-A777 Shelf System
Yamaha HTR-5830 Receiver Logo
463 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
