I hooked up my Viewsonic Q71-9 monitor to an old computer (Windows ME). I cannot run the setup prog off the disc.. it says "This application cannot run with the current monitor depth". I cannot change the setting off of 16 colors.
  • 4,806 Answers
Hi there
You need to install the graphics drivers for the monitor to work properly, as soon as you have done this the monitor should work depending that the graphics card itself supports 32bit
Good luck and kind regards
Posted on Jan 05, 2009
I had my ViewSonic VX1935M-3 Lcd Monitor shut off for 2 years, I tried turning it on now and the power button flashes blue but the screen stays black. How do I fix this?
The absolute worst thing you can do with a piece of electronic equipment is to let it set. If as you stated the laptop registered it OK then it could be that it has lost it's memory and needs the drivers updated. The laptop will only tell you that it is connected it does not run a diagnosis on it. If you have the disc for the drivers try running it while hooked to the monitor. Other than that you may have internal problems with the monitor. It could be the inverters. logic controls and numerous other things that just seem to die of neglect I guess you could say. I have found about every kind of problem with TV's and Computers that have been mothballed for a length of time. I would think it is the drivers though. If you do not have the disc go on line to the Mfg. of the monitor and enter the model # etc. and try to find a download for the drivers. Most Mfg. have free downloads of the drivers for their equipment. Hope this gets it going and if I can be of any other assistance please feel free to contact me.
Col. Dana Gillespie
Mar 24, 2014 | ViewSonic VX1935wm LCD Monitor
Monitor
have you tried if the monitor on another computer?
otherwise it must be bad configuration.. try right clicking on the desktop, click on properties, configuration, and then you will see 2 monitors.. if you go in advanced you can also play there to tell wich one will be the firts monitor..
you could also reinstall the video drivers of your laptop and there will appear an icon on the task bar so you can configure how will the screen be working..
Dec 19, 2007 | ViewSonic VX910 19" LCD Monitor
Have just upgraded to windows 7 and my Viewsonic vx715 is only recognised as a generic PnP monitor and I can't load drivers from disc supplied. monitor is approx 6yrs old and still going fine!
In most cases you don't need the drivers for a monitor to work completely fine. In order to obtain your drivers you can always check the manufacturers website and they should have drivers listed, in your case they do. Although I couldn't locate VX715 i found many VX models in the driver search. There should be one that works fine, just make sure you download the right right IE: windows 7 x32/86 if your running a 32-bit operating system, or windows 7 x64 if you are running a 64 bit operating system. Here is the website I located http://www.viewsonic.com/support/downloads/drivers/
Jan 09, 2011 | ViewSonic VX715 17" LCD Monitor
How to hook it to an old dell comp
Just use the VGA cable (15-pin).
Monitor VGA port on the PC to the monitor VGA port.
http://www.viewsonic.com/products/va1912wb.htm
Dec 01, 2010 | ViewSonic VA1912wb Monitor
Display out of range monitor not working
try to hook up your old monitor to use temp. go to display options and reintall drivers for the vx922. power down and switch monitors. windows should recognize the vx as monitor 2, click it and will cchange to a 1
Oct 09, 2010 | ViewSonic VX922 19" Monitor Flat Panel
ViewSonic VX2235WM turns on than screen goes blank changed power cords cable cords viedo card cpu still same problem
The problem is most likely the monitor itself. Hook up an old monitor (usually someone has an old monitor laying around) if the computer works with another monitor you'll know for sure.
Look at your monitor using a flash light at an angle, if you can see a picture in the background you have a bad inverter.
Nov 28, 2009 | ViewSonic VX2235WM Monitor
Viewsonic monitor
Pixel Ratio is just a parameter Measured to Produce Good Quality Display with Fine details so Do not Mix up with Resolution and Pixel ratio.
Use the Resolution that best sutes the Application you use(which may change with time to time based on applications you use)
Keep a standard Resolution 1024 x768,or which ever suits your Vision.
NViiDiA is a Grafix card and Monitor features are 2 differnt thigs so.
Dont be concerned about the Parameters and get mixed up.
just find the best possible Resolution and enjoy your Monitor with best Quality, :)
Jul 17, 2008 | ViewSonic VX924 19" LCD Monitor
No audio from lcd monitor (viewsonic) after disconnecting my speakers. (New monitor has built-in speakers)
make sure you hook up the third gree socket on back of monitor to PC that was my problem and solution to my model monitor LCD
Sep 17, 2007 | Liquid Video E15LCD1 15"
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
