Question about Saeco Vienna De Luxe Espresso Machine
Grinder starts, but doesn't wet coffee before red light comes on
Dry coffee appears in the out-basket
Water is running out.  Check the tank.  If not clean filter.
Posted on Jan 17, 2009
Ground coffee does not get wet
try to fill the reservoir with the water to the top, when the water starts "brewing" the water is transfer from this reservoir to the basket where there is loose coffee placed over the paper bag that will filter the coffee to the jar.
Check if anything is blocking the canal, that is transferring the water from the reservoir to the basket.
Mar 01, 2015 | Cuisinart DGB-550BK Grind-and-Brew 12-Cup...
Why are my coffee pucks (dregs) coming out unformed and very wet
Bad grind, worn burrs in grinder (so a mixture of coffee particle sizes); not enough ground coffee for the size of filter basket.
- Adjust grinder so your brew time is in the 20-25seconds window, then take it from there.
Jul 24, 2014 | Gaggia Titanium Espresso Machine
Breville Die Cast 800ESXL Espresso Machine: Problem... Watery espresso. My machine worked great for a year, then all the sudden, the espresso is watery and the basket where the grinds are is full of water...
Personnaly, when I use the big filter, the grinds are dry after the extraction, but for the small filter, it's all soggy. If you look at the documentation, ( http://kitchen.manualsonline.com/manuals/mfg/breville/breville_coffeemaker_product_list.html) they say wet coffee grind after extraction is normal.
But did you change the coffee brand ? Or the grinding level ? How do you grind your coffee ? I had big troubbles once with a commercial grinder at my grocery store, it's when I decided to buy my own Breville grinder.
Good luck,
JF
Oct 16, 2009 | Breville Die Cast 800ESXL Espresso Machine
How do i clean my cuisinart grind and brew coffee maker? i can't find my instruction booklet and it needs to be cleaned. thanks!
From the manual I found online here.
CLEANING AND MAINTENANCE COMPLETELY CLEAN AND DRY ALL PARTS AFTER EVERY USE. Always turn coffeemaker OFF and remove the plug from the electrical outlet before cleaning. Open the reservoir lid*. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use. Do not put any water in the unit once the grinder basket has been removed. Wipe the area under the grinder basket with a damp cloth. If water gets into the grinder motor, the motor may become damaged and may malfunction.
DECALCIFICATION Decalcification refers to removing the calcium deposits which form over time on the metal parts of the coffeemaker. For best performance from your coffeemaker, decalcify the base unit from time to time. The frequency depends upon the hardness of your tap water and how often you use the coffeemaker. To clean, fill the water reservoir to capacity with a mixture of 1/3 white vinegar and 2/3 water. Turn the coffeemaker on by pressing the ON button. One cycle should be sufficient to adequately clean the coffeemaker. When the cycle is completed and the five beeps sound, turn coffeemaker off. Repeat operation, this time using fresh cold water.
Sep 09, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a grind and brew and can't get the grinding basket out to wash.
Open the reservoir lid. Remove the grinder basket lid by using the recessed area on each side of the lid. Then remove Grinder Basket. Open Filter Basket Door. Remove Filter Basket Cover, Filter Basket and Filter Basket holder. The grinder basket, grinder basket lid, filter basket and filter basket cover can be washed in warm soapy water and rinsed thoroughly, or cleaned in the upper rack of the dishwasher. Dry all parts after every use.
Sep 01, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Grinder starts, but doesn't wet coffe before red light comes on
This is a duplicate, here's the answer
I have the same problem but it's easy to fix. Turn the machine off. Open the front panel. Remove the dump box on the side. Pull the grinder unit out.
Look at the thing you just pulled out. You'll see a little ramp going from where everything slides down from the top. That ramp gets damp and the freshly ground coffee starts sticking on it. Take your finger and wipe it off.
Next, is kinda hard to describe. If you put your fingers inside, along the top, center edge of the machine you'll feel a ridge. It's a spring loaded door. Pull it down and clean the grounds out.
Slap it back together and you're good to go. Only takes about a minute when you get the hang of it.
Jan 05, 2009 | Saeco Vienna De Luxe Espresso Machine
Filter basket door opens during coffee making.
sounds like there is a bad relay, that is shorting out, and releasing the filter basket accidentally. Also, check to make sure that there is nothing blocking the latch that holds the filter basket in place.
Feb 05, 2008 | Cuisinart Thermal DGB-600 Grinder
Cuisinart Grind & Brew Thermal Coffeemaker DGB-600
I suffered with a stuck grider unti for a long time and just solved the problem..... Remove the filter basket and through the front door look up twords the back left. You can see where the grinder unit sits. There is a slot area where you can stick a screw driver under the grinder unit and pry it up. Do this in a jiggling motion and make sure you are well under the grinding unit, doing so on the edge of the grinder unit underneath will not give you enough suface to work with, in fact you will just bend or crack the edge. Looking in from low on the front (kneeling on floor with unit on counter, worked for me) will let you locate where the screw driver or smal pry tool needs to go. Mine was stuck for a very long time and No amount of pulling or prying from the top would work, I made it pop out in a matter of seconds using this technique from the bottom! Good luck, I'm going to finish my cup of coffee now! :-) Steve
Nov 19, 2007 | Cuisinart Thermal DGB-600 Grinder
Grinder blades dull
I may be having the same problem. My coffee grinder has had more leftover beans in it more and more this week, until finally today, possibly a quarter teaspoon passed through to the filter basket and the remaining beans were still very much beans. My first assumption was the blades.
Sep 24, 2007 | Cuisinart Thermal DGB-600 Grinder
Saeco Vienna De Luxe Espresso Machine Logo
50 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
