Question about Samsung SC-D365 Mini DV Digital Camcorder
How do I get my videos from tape to my PC?
I want to record my videos that I have on tape on a DVD. I have a DVD recorder on my PC but I'm not sure how to get the videos onto my PC to record them.
    Scholar:
  • 125 Answers
Check what kind of interface that your camera have, these are the possiblities: Hardware powwibilities: 1. i-link or firewire or IEEE-1394: all three are the same depending on the brand. This is the common woth DV cameras. If you have this, you have to have the same interface in your PC. You have to install an interface card. 2. USB 2.0- it has to be 2.0, ver 1.1 is slow and will not be capable of hi res transfer. If you have this, your PC should have this interface as well. 3. Analog AV- Here you have to buy a video capture card, it may be via USB or PCI slot. In any of the setup you will be needing a video authoring software. There are a lot available in the net and it is also free when you buy a video capure card or module. After you capture the video, you have to burn it in the DVD, you can use Nero. There are plenty of discussions, problems and solution in www.videohelp.com
Posted on May 25, 2007
Can I transfer video tapes onto CD's
A lot depends on what type of video tape you use and where do you want to play the DVDs (CDs are for audio recording only). If tape is compact VHS then you can buy a simple DVD Recorder VHS VCR combo player and transfer across easily provided you have the compact VHS cassette module.
http://www.gumtree.com.au/s-ad/reservoir/tv-dvd-players/lg-v271-vcr-dvd-player-combo-recorder-6-head-hi-fi-stereo/1073556241
For other type of video camera tapes you will have to try other methods like connect camera with tape to a DVD recorder and directly burn the DVDs. You can buy attachments and software for PC but I have found these very cumbersome to work with.
Mar 16, 2015 | Video Cameras
Magnavox ZV450MW8A DVD/VCR Recorder Dubbing.
I bought a ;magnavox dvd disc and cassette recorder combo.
I am having trouble with setup items? I get nothing on the screen to select from?
Oct 24, 2009 | Televison & Video
How do I hook up my vcr to my dvd recorder so I
You will need one RCA video cable it will have a yellow, red and white plugs. On the back of your VCR locate where the color inputs are find where it says VIDEO OUT hook it up there. On the back of the DVD Recorder look for the same color input jacks NOW find where it says VIDEO IN hook it up there. You may have to turn on your TV,DVD recorder and VCR to get the right channel. your Recorder may have one or more video inputs if it does turn on all three. Use the channel on your TV you use to watch DVDs make sure you see your DVD screen. Now to record to a DVD. Change the channel on the DVD Recorder. Look for the input channels It may be Video 1 Video 2 etc... depends on the inputs you have. ( A great way to tune your DVD Recorder is to play a prerorded VCR tape. Turn the channel on your DVD Recorder unil you see the prereorded tape playing. )
Jul 21, 2009 | Toshiba Audio Players & Recorders
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
How to record a VHS tape to a DVD disc
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
Dec 30, 2008 | Samsung DVD-V4600 DVD Player/VCR
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
Sansui video/dvd player recorder
What is model number of unit? Are you sure it records dvds?
Feb 22, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Recording more than one VHS onto a DVD
Try pausing the dvd recorder inbetween tapes, this usually works, otherwise consult your owners manual
Jan 09, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Copying 8mm tapes to dvd
try taking your audio and video cables from the camcorder and plugging them into the line 1 inputs of the dvd recorder try playing the camcorder and if you can see the video from the camcorder on your tv when it's plugged into the line1 of your burner then hit the record and make sure teh dvd burner is set to accept a signel form the line 1 inputs then it should record. but remembermust selsct the line 1 inputs before you start to record, by defualt they are set to tv/cable.
Dec 27, 2007 | iLO DVDRH04 DVD Recorder
VCR to DVD Dub Out of Synch
FIRST THING YOU HAVE TO DO IS HAVE YOUR DVD RECORDERS LENS AND DRIVE CLEANED ALSO MAKE SURE THE VCR HEADS ARE CLEANED ALSO.
NEXT WHEN RECORDING make sure the format of the tape(speed like sp & lp are the same as the dvd recording speed(sp& lp are the same before starting recording.
Nov 20, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Samsung SC-D365 Mini DV Digital Camcorder Logo
167 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
