My truck will not start just cranks but will not fire
Air - not likely the problem ! mechanical cable controlled throttle body
Fuel- make sure there is gas in tank! fuel pressure test at the throttle body or rails, if no fuel check power to fuel pump: ignition power to breaker or fuse, relay , power to pump at 3 pin connector near tank/frame rail on drivers side, - if pump is runniig but insufficient pressure, check for mechanical restriction: plugged filter broken or pinched line, plugged pickup tube in tank. if good pressure to rail or body, check ecm : diagnostic codes, fused power, ecm tells injectors when to open, dependent upon several sensor parameter inputs.
Spark- ignition - coil-distributor-ignition module (or coil packs)- wires-plugs-ignition module (signals coil to discharge, mounted beneath distr cap) work backwards from plugs.
