Question about Dell Inspiron 1501 Notebook
Dell inspiron 1550
I need to see a step by step repair guide to disassemble and replace the screen inverter..do ya do it the same way as the thinkpad on laptop repair 101?
    Novelist:
  • 180 Answers
Http://support.dell.com/support/edocs/systems/ins1501/en/index.htm
However, if it's really a 5150 (since the 1550 is a server) use this link:
http://support.dell.com/support/edocs/systems/ins5100/en/sm/display.htm#1084976
This will give you the exploded view.
Good luck. If you have already handled a thinkpad, I foresee no problem with this one. They're all pretty much the same.
Please rate this accordingly and thanks for using Fixya.com
Posted on Jan 10, 2009
Dell d620 sCREEN GOES BLACK AFTER WINDOWS SCREEN COMES UP. None of the normal Fn keystrokes help. i never make it to the login screen. Help?
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Apr 05, 2013 | Dell Latitude D620 Laptop (Latitude-C620)...
How to restore Dell 1550 Inspiron to actual factory setting
Unless your using a email program such as thunder bird or if it is a Yahoo or Gmail account I would not even worry about having to delete anything. Just send it back they cannot access private information without the password anyway. So send it back get it fixed and move forward with a new machine when it comes back? John
Apr 19, 2012 | Dell Computers & Internet
No backlite thinkpad T43 i need free help....i am a pensioner R1000 PER month or 160 us dollars
Hi barrygarcia...
Your problem is a faulty lcd bulb, inverter board or lcd screen.
The only way to save money on your laptop repair is to do it yourself.
I could sit here and write a long procedure of how to check and replace your lcd bulb,lcd screen, or inverter board, but is is so much eaiser to view it in person.
If you are adventrous then I will send you to a youtube site to show you how to disassemble the
T-42...it disassembles like your T-43.
Please take time to rate me
T-42 disassembly
http://www.youtube.com/watch?v=YrGgXgSkiAo
If you need to replace your T-43 lcd bulb you can get one here...
http://www.yallstore.com/laptop-lcd-ccfl-backlight-lamp-for-ibm-thinkpad-t43-141-xga-p-11746.html
If you need to replace your T-43 inverter board:
http://www.machinaelectronics.com/store/buypart/IBM_Thinkpad_T43/39T0361
Jul 29, 2011 | Computers & Internet
Blank screen when turned on.sound is fine though.when i use external monitor it works on the external monitor.
Hi. I have 2 units of T23, 1 unit T22 and T30. All of them has the same problem as yours. 3 units has bad inverter and the other 1 has bad CFL. Inverters can be replaced but if you have bad CFL, it is better to replace LCD screen. If your problem is CFL, you will be able to see a very faint image on your LCD screen. If the LCD is completely black and you can't see anything, then it is an inverter problem.
Inverter is located below the LCD screen. You need to remove the LCD face plate to access the inverter. Please click here for the step-by-step instruction how to access the inverter or replace the LCD screen. Inverter and LCD are available at ebay.
Note: T23 has thin plastic parts that can be easily broken when disassembling.
Good Luck. Let me know further.
Jun 28, 2010 | IBM ThinkPad T23 2647 Notebook
How do you replace the LCD inverter
Follow the below guide :-
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/comment-page-5/
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 07, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 6000 Laptop Screen has Faint Image
It's a faulty backlight (screen).
Replace screen (same dell part number) with inverter, otherwise screen can be dark.
Here is how Dell part number looks (green):
Aug 19, 2009 | Dell Inspiron 6000 Notebook
Dropped my laptop- screen cracked
I would recommend locating a local computer repair shop that doesn't have a well known name around your town.
They tend to keep many extra parts of laptops lying around and it's as simple as finding a match and replacing the LCD panel.
The smaller shops may have better deals than the larger, but it might be smart to contact Dell as well on the same matter.
Jul 23, 2009 | Dell Inspiron 1525 Notebook
Have a dell latitude D610 and the screen is black, i can bearly see the icons but it will not light up.
The inverter (backlight) has gone or has come loose from the plug.
If the laptop is still under warrant i suggest you take advantage of that and send it in to be looked at.
If its out of warranty you have to options, take it to reputable PC repair store or disassemble the bezel (plastic screen surround) yourself.
The inverter is an elongated circuit board located right under the screen itself, check the connections to that, if all looks well then then the inverter itself has gone and needs replacing.
Don't worry too much about the cost as they are fairly inexpensive to replace.
If you need anymore advice please feel free to post back.
Good luck
Jun 12, 2009 | Dell Inspiron 6000 Notebook
Where is the LCD backlight inverter on an Inspiron
The inverter is in the LCD, below the actual screen. It controls the brightness and the contrast on the laptop. Here is a link where I purchase them:
http://www.smartmicrousa.com/dell-inspiron-e1705-laptop-inverter-board.aspx
It is easy to replace. Here is a link that will guide you:
http://www.ehow.com/how_4841734_dell-laptop-inspiron-e-backlight.html
Apr 21, 2009 | Dell Inspiron E1705 Notebook
Dell Inspiron 1501 Notebook Logo
2,222 people viewed this question
Alun Cox
