Question about Samsung ML 1710 Laser Printer
Can I use a samsung ML 1710 laser printer with a Mac G-5 with OS 10.4.11? I can't seen to get it to recognize a request to print. I get a message that "unable to connect to printer".
  • rw_johnson Jan 05, 2009
    It is connected via a USB cable. thanks
  • word2thewhys
    word2thewhys May 11, 2010
    Is the computer plugged in with a USB cable or is this a networked printer?
Solved the problem by connecting it to a Windows machine. Thanks.
Posted on Jan 06, 2009
Samsung ml-1710 printer does not always print
you need to reinstall printer with samsung printer driver specific for this model that can be downloaded from samsung website
Oct 04, 2009 | Samsung ML 1710 Laser Printer
I have a samsung ml-1710 laser printer. Was wrking
Power off the printer, disconnect/reconnect the printer cable, power on the printer, reboot your workstation.
If that doesn't work, in Control Panel - Printers, delete the icon for your printer. Disconnect the printer cable. Reboot your workstation and log in. Reconnect the printer cable and see if the printer is recognized. Install the printer driver.
Jun 12, 2009 | Samsung ML 1710 Laser Printer
Cannot print on new Macbook with Leopard Mac OS - need driver
I just upgraded to snow leopard and my previous driver was erased, so I did some digging around and found the right driver (it is not included even in the most recent GutenPrint software).
Look at the Global Samsung website - the US Samsung site does not support MacOS drivers.
http://www.samsung.com/download/FileView.aspx?cttfileid=213919&type=Printer&typecode=15&subtype=Laser+Printer&subtypecode=1501&model=ML-1430&filetype=DR&language=
Your OS should ask to install Rosetta to read the file (Zip), but then the install is quick and easy. The printer driver immediately showed up in the printer>setup>driver menu. Prints without a hitch.
Haven't booted my laptop into 64bit kernel, so I don't know if the driver is 64bit compatible - I expect not. Hope this helps.
May 31, 2009 | Samsung ML 1430 Laser Printer
Samsung ML-1710 Printer: Online/Error (red) lite ON: won't print
It is not a computer problem, when your printer won't come to ready. The lights flashing are due to a failure of some sort - electronic, or perhaps a fuser warm up problem. The fact is, whatever the fault, it is cheaper to replace this printer than have it repaired.
Mar 16, 2009 | Samsung ML 1710 Laser Printer
Printer prints too light
dust in the LSU (laser unit), you have to clean LSU.
Nov 25, 2008 | Samsung ML 1710 Laser Printer
Samsung ML 2010 under mac os X 10.5
I found a solution that worked for me by prowling around various Apple discussion forums. The two keys to the solution for me were numbers 3 and 5 below.
1. Opened print/fax preferences
2. Opened Add printer by clicking the +
3. For protocol, select HP jetdirect-socket (not IPP or LDP)
4. Determined the IP address for my Belkin wired print server and typed this into the Address line of printer setup
5. Manually selected the printer driver as ML-2010. It is in the list of drivers but is in the M's, not under the Samsung drivers.
6. This worked for me. I've seen reports from people who had to power cycle their print server and/or printer as well.
Jun 22, 2008 | Samsung ML 2010 Laser Printer
Samsung ML-1710 Laser Printer
Hi, On another posting of a similar problem, I proposed this solution: In some instances, the PC switches off a USB port. You may have to un-check "Allow the computer to turn off this device to save power." This is in your Device Manager/Universal Serial Bus Controllers/USB Root Hub. Hope this be of some help/idea. Pls post back how things turn up or should you need further information. Good luck and kind regards.
Apr 24, 2007 | Samsung ML 1710 Laser Printer
Samsung ML 1710 Laser Printer Logo
65 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
