Question about LG Jabra A210 Bluetooth Adapter for Headset
Charging the LG Bluetooth
As simple as this should be I can not find how to plug in my bluetooth device to the charger. All the instructions say is to remove the cover.....what cover????? How do you remove the cover???? Thanks
The cover is a little rubber covering on the side you lift with your fingernail, and the charger port in underneath.
Posted on May 03, 2008
Manual for ilive bluetooth receiver and adapter lAB13
Have you actually checked the charger is actually working with power coming out of plug that plugs into device.. THe actual charger unit may not be connecting properly into wall socket...
Dec 09, 2013 | GPS
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Bluetooth is plugged into charger but keeps flashing red light, dont know if its charging or not
I had the same issue -- charged it for days and still red light flashing. I was ready to break it open and see if I could replace battery. Then I looked on the opposite end of the charger and seen a little round hole thingy. I put the end of a pen in there and pushed it twice and -- the red light went away . Plugged the charge in and steady red then purple and now blue. Looks like that is a reset ..Try it -- it worked for mine.
Sep 22, 2011 | Motorola Mobility H721 Bluetooth Headset
My bluetooth is not charging. the ligth on the charger comes on but on the actual bluetooth the light doesnt come on. Is this fixable or do i need to buy a new one?
Try and find a similar charger and test the device on that. if you have the same results than either the battery in the device is completely dead, or the device itself has malfunctioned and needs to be repaired/replaced. if the device is still under warranty you can try and contact the manufacturer for help or a repair/replacement.
Feb 28, 2011 | LG HBM-760 Bluetooth Headset
My headset will not turn on
Hello
Your bluetooth headset is powered by an internal battery. If the battery is not charged,it just won't turn on. Fully charge your battery before use.
Make sure that the power outlet you're using is working and that the cord is fitted correctly into the wall, PC or Car outlet and the Jabra Bluetooth device.
Try unplugging the Jabra Bluetooth device and see if it turns on. If so, use the Jabra Bluetooth device until the battery is completely exhausted. The next time you charge it, check that it is charging properly
If the Jabra Bluetooth device is still not charging, check what happens when you initially plug the Bluetooth device into its charger. If the light on the Bluetooth device flashes on and then off again quickly, it is likely that the battery is no longer working. Batteries cannot be replaced or covered warranty
Dec 30, 2010 | Jabra BT150 Wireless Headset
How do i charge my lg bluetooth headset with AC charger. I cannot find an adapter insert on the headset.
HI. You will need to remove the concealment cover on the charging port before you can connect the charger. The cover is on the opposite side of the volume button. It will have the initials "PWR" on the cover. Pull that off to expose the charging port.
Aug 20, 2010 | LG HBM 730 Bluetooth Headset Wireless...
I just bought a LG HBM 210 bluetooth and it doesn't appear to be charging... no LED light, and I can't pair it with my cell phone.
You need to work out if the charger or the device is faulty. The faulty item will have to be replaced by the shop where you bought it.
Apr 25, 2010 | LG HBM 730 Bluetooth Headset Wireless...
Does the LG HBM-210 have to be on to charge
According to the instructions provided by the operator manual...
"Connect the charger to the charging port.
- When the charger is connected, with the power on or off,
the Headset will turn off automatically, and cannot be used.
While charging, the LED indicator will show a solid blue light.
- The buttons will not function while the device is charging.
- It takes 2 hours to fully charge the Headset.
- When charging is complete, the LED indicator will turn off.
Jan 20, 2010 | LG HBM 730 Bluetooth Headset Wireless...
Charging problem
cant connect to hands free bluetooth when i search for a bluetooth its says it has not found a bluetooth handsfree
Jul 14, 2008 | Sony Ericsson W900i Cellular Phone
Car charging Bluetooth Motorola h-500
Yes, the car charger will work fine, just make sure that any time you use a car charger, remove your device when it is finished charging. If you leave your phone or bluetooth headset on the car charger, it will continually force power into it and over time reduce battery life.
Dec 27, 2007 | Motorola Mobility Bluetooth Hands Free...
Radio Communications Logo
151 people viewed this question
Top LG Radio Communications Experts
Damen Wong
Damen Wong
iPhone Technicians
iPhone Technicians
Level 1 Expert
coolboyjitu
Level 1 Expert
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
