Question about Maytag PAV2300 Top Load Washer
Warm water temp Maytag PAV1000aww washer
The two warm water setting deliver tepid water temp. Hot & cold work fine.
Whats wrong
  • Maytag Master
  • 8,205 Answers
Perhaps you need to simply open the hot and cold water faucets all the way.
Posted on Jan 21, 2009
HOT and COLD blending
my last two washing machines, totally different brands and types, did the exact same thing. It must be a new way of setting them up, I don't understand either. I can't get straight hot water. My new one does seem hotter than the old one I had which was very distinctly hot then cold then hot then cold even on hot hot water.
Nov 09, 2013 | Maytag Washing Machines
HOT and COLD not blending correctly
The explanation I have in my file is that powder detergent does not dissolve properly in cool and warm wash cycles unless there is some hot water flow. However, I agree with your assessment.
Nov 09, 2013 | Maytag Legacy Series Top Load Washer
Getting hot water only into the tub. Is that a bad mixing valve? Where can I get one for a VERY old Maytag Washer?
The cold water valve could be faulty. It's quite possible that the valves haven't changed. If you don't need hot water put the HOT hose on the COLD tap and wash on 'hot' or 'warm' you'll need to rinse on hot or warm or the machine wont open the 'hot' valve which is now delivering cold water!!!! Enjoy.........Nomess
Apr 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 27, 2009 | Maytag Performa PAV2200
On the warm setting only get cold water. on the hot setting i do get hot water. please help
You might not be able to do much about this. It seems most manufacturer are concerned with reducing energy usage on washers. To that end, the biggest user of energy for a washer is not the motor, but the energy used to heat your water. Reducing the temp's will allow them to lower the energy used rating.
As an example, let's say you measure your cold water at a faucet and it's 55 degrees (of course this varies with the part of the country you live in. It is basically the average year round temp. Here where I am in Minnesota, that's about 44, but in Texas or Florida, it might be close to 70) Measure the hot at your faucet also, and let's say you get 125.
Now, if you measure the incomming water on your washer, the cold might be close to the cold measured at the faucet, say 60 in your area, but the warm might only be 70. Maybe not enough of a difference that your hand would even notice. Checking the hot, you might see not much over 100.
As I've said, the energy guidlines your government set forth are driving companies to make these type of adjustments. There is not much you can do about it short of re-wirering and possibly replacing the multi selenoid thermostatically controled water valve to make it into an older style washer fill system. The temp settings now are actually set to deliver temps which more accurately hit the ranges clothing manufacturers want when they say COLD, or WARM wash, in spite of your incomming water temps to the machine.
Sep 27, 2009 | GE WBSR3140DW Top Load Washer
Automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Aug 17, 2009 | Kenmore 22422 Top Load Washer
Warm Water settings
Open up both hot and cold water valves all the way.
Jan 05, 2009 | Maytag PAV2300 Top Load Washer
Washer's warm setting alternately fills hot and cold
Call for wty svc- the temp switch is bad; they had many of these built like that Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
New WTW5700SW clothes washer. 1 week old. Worked great for 1 week. Temperature control problem. The cold setting provides hot water. The warm and hot setting provide cold water. The warm setting...
the temp thermister in the control panel is bad, lowes has a 30 day return policy if they delivered it have them bring you a new one, if you picked it up take it back, get a new one no need in starting out with an new almost out of the box washe with problems
Apr 13, 2008 | Washing Machines
Maytag PAV2300 Top Load Washer Logo
108 people viewed this question
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
