Question about Mitsubishi WT-42311 42" Rear Projection Television
Mitsubishi WS 65513 turns itself off
TV turns itself off after about 45 minutes (green light remains on). I can turn off the TV and turn it back on immediately, however, the TV turns itself back off after a few minutes (possible heat/overheat problem with an electronic component). The TV turns itself off right after I turn it on. Anyone know what that could be?
  • 608 Answers
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
2 Suggested Answers
  • 1694 Answers
SOURCE: Mitsubishi WS 65513 turns itself off
Probable four bad caps in DM module = 1000mf/25v
Common repair for qualified Mits tech...........T.
Posted on Nov 22, 2007
TV turns itself off after about 5 minutes (green light remains on). I can turn off the TV and turn it back on immediately, however, the TV turns itself back off after a few minutes. It started turning off...
Check and make sure your fans are working and there is sufficiant cooling to the back of the set. Sounds like it is overheating and going into protection mode.
May 04, 2011 | Mitsubishi WS-65513 65" Rear Projection...
Tv will not turn on green light blinking
Unplug the tv, and plug it back in. Wait a minute and it should come up.
Jan 12, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Mitsu 65513
I also have the blinking green light problem with my WS-65513 Mitsubishi TV. I would appreciate any information you could send to help fix this problem. Thank you, Keith. elitemachine @netnitco.net
Nov 04, 2008 | Mitsubishi WS-65513 65" Rear Projection...
WS-65513 Blinking Green Light
I have a Mitsubishi MITWS-65813.
The green led light constantly blinks. I tried the reset button and green light is still blinking. I unplug the tv, waited a few days, then plugged the tv back in, the green light still blinks. I have a lot of experience with soldering. Do you have any suggestions or can send repair directions/protocol for the DM board.
via email? Thank you in advance for your help. Your help is much appreciated!
Sep 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi TV WS-65713
Please send me the instructions on how to remove and repair the dm board in my mitsubishi ws-65513 tv. The green light keeps blinking. thanks
samzlades@yahoo.com
May 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsugishi WS-65513 turns off
press the input and the menu button togeather and let me know what the led flashes? it should be a two digit code
May 15, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513
if you changed the energy mode from standard to low that is normal, anytime you turn the set on it will do the same,
plug set green light will blink one minute.
turn it on it will blink onother minute and then turn on(make sure that you dont keep pressing power key) once on you can change your settings again.
hdtvman.
Apr 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513
I have a fix for that Dan if you are handy and can solder. You will be able to save about 1000 bucks or so at least. Leave an e-mail address and I will send the repair documents for that model of set. Good Luck
Mar 21, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Flashing green button, won't reset or turn on
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
Dec 18, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Nov 11, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WT-42311 42" Rear Projection Television Logo
225 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
