Question about ASUS Eee 4G Notebook
My computer won't respond, can't open anything.
I can't open anything apart from games on my Eee PC 4G. Anything I click on has the hourglass appear for a few seconds and then nothing. I have tried the System Recovery (restore factory settings) but still no change. Any help appreciated!
  • 1 more comment
  • sclifford Jan 05, 2009
    Thanks for the tip leekom72. Could you please explain how I could do that, I'm a bit of a novice. Thanks.
  • sclifford Jan 06, 2009
    Thanks again. I should have said that my Eee Pc runs Linux with Firefox, Open Office etc. If it was Windows I might be better off, but this seems a bit harder. Any help appreciated still!
  • ASUS Master
  • 4,806 Answers
Hi there
check the hard drive for bad sectors and recover them if you can, this could be the reason for the system hanging
Good luck and kind regards
Posted on Jan 05, 2009
  • Lee Hodgson
    Lee Hodgson Jan 05, 2009
    Ok, what you have to do is go to "my computer" or "computer" if you use Vista, right click on "local Disk C" and select "properties" then select the "tools" tab and check the volume for errors, make sure you check both boxes that say "automatically fix file system errors" and "Scan for and attempt recovery of bad sectors"
    This process takes about half an hour so please be patient, if it finds any errors it will fix them.
    Any problems post back
    Good luck
  • Lee Hodgson
    Lee Hodgson Jan 06, 2009
    Hi again
    Because you use Linux its quite hard for you to perform a surface scan on the drive. What you could do is go to the Linux forum and download a disk check program which will allow you to check the HDD for any problems, there are plenty of open source software out there just check on the forums for the best one and make sure it is compatible with the Linux version you are using
    good luck
Trying to install mozilla on a eee pc 4g ;for chat with facebook.found the download?? but, it won't install e.g. thank's
It might not install unless you have admin privleges right click on the down load and select run as adminstrator and see if will install then
Aug 17, 2011 | ASUS Eee 4G Notebook
I launched my Eee PC 4G PC and then showed me the screen and carry name appears on a blue screen with the letters, but did not have time to read anything and then again from the same, please help
A blue screen is most commonly caused by faulty hardware, either faulty RAM or Hard drive but it can sometimes be software related, if you got any restore discs with the wee laptop boot up with them and try repairing, if that fails, take it to a computer engineer and he/she should be able to tell you what it is. If it is RAM you should be able to get it replaced for around £20 if it is the HDD around £40-50, although I think those Eee PCs have built in memory so I would sway towards the RAM.
Hope this helped and if you have any more problems or if you get it sorted let me know
Mar 20, 2011 | ASUS Eee 4G Notebook
When i open scanner and camera on the eee pc it tells me it cannot detect anything
are the correct drivers installed? go to devices and printers in control panel and check
Mar 13, 2010 | ASUS Eee 4G Notebook
Eee PC does not turn on!!
there could be a variety of problems....first off try a simple power cycle..remove the battery and keep poewr adapter in...then push power button down for 1 minute...then push the power button normally and might correct problem....if not check the brick the power adapter box for lights or warmth...if not warm it could be bad power adapter....if it has warmth and lights then it could be the battery...if you have a warranty on hte computer now would be a good time to call the warranty companie...but try those steps first...they are simple troubleshooting steps...
Apr 16, 2009 | ASUS Eee 4G Notebook
Long time to open eee pc from switch on it until desktop appear
when u powqer up the computer press F8 key theh login in safe mode.
then scan your computer with antivirus
Also remove temp files from computer
Also type in run "chkdsk /r"
then press enter "y"
then restart the computer then it auto matic fix eror on harddisk.
Apr 10, 2009 | ASUS Eee 4G Notebook
Cant get the eee pc built in webcam to work
I assume you have windows VISTA remove the dRiver;'s and reinstal them.
Jan 14, 2009 | ASUS Eee 4G Notebook
ASUS Eee 4G Notebook Logo
184 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
