Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loader. did a load of laundry and when i went to get it out the rubber seal is all twisted and the wire spring is off
  • nancylanier Jan 06, 2009
    It is ripped..
  • 530 Answers
Is it ripped?If not great all you need is to put the boot back on then reattach the band tighten with i believe eitther a 7 milimeter or 1/4 socket then put the hose slot back on and then the front of the boot following the otther band
Posted on Jan 06, 2009
  • erica graber Jan 06, 2009
    all you d is the model number. I don't know where you live but if there is a Sears located near you I would call there parts department, give them your model number and they will get you a boot delivered to you.
Rubber seal inside door came off-how do I replace it and where does the retaining wire/cable go?
Reinstalling that rubber seal is a lesson in patients. There is a metal lip on the machine opening and a cooresponding groove in the rubber seal. These two need to be mated together. That's the easy part. Once together, the retaining wire and spring go around the rubber seal just on top of where the rubber seal goes over the matching lip. It will take several tries, the spring may be small but it's very strong and difficult to stretch. Good luck.
Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Loading Duet Washing Machine Plastic at drum front shredding
i think your talking about the rubber door seal????
you can change this yourself,,,under the seal on the case is a wire spring unhook it and the door seal will fold inside the washer,,,on the inner drum you will find the other wire spring undo this as well and pull the old door seal out through the hole in the door,,,the new seal is fitted to the iner drun first so you need to turn the new seal inside out to fit it,,,push the seal into the washer and fit the inner wire first then unfold the seal and fit it over the outer door so you can fit the wire spring,,,
easy after you have fitted a fuw 100?
Aug 21, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
What do I do when the big spring that is seemingly behind the rubber bladder of the the door opeing keeps popping out on my Whirlpool washer Duet?
that spring is for the door water seal if it "pops" off when you have a load of washing being washed you will flood your kitchen floor with water,,,fit a new door seal and a new spring fast!
Jun 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
After washing a load of jeans I went in my laundry room and found a flood of water on floor. All the hoses looked fine could it be something under the washer??? Never had a problem with washer before.
The following link explains how to investigate a leak on a front loader:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
In many cases, the door bellow (rubber door seal) can also become ripped or torn due to normal wear and tear and begin to leak. Perform a thorough inspection of the bellow by pulling the rubber folds back and check the entire perimeter of the door. This is where the majority of leaks come from in a front loader. If the bellow requires replacement, the following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites offer great service with competitive pricing so shop and compare.
If you have any questions about this repair, please post back and let me know. I hope you find this information helpful.
Dec 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Rubber door seal has disconnected
if the wire in the seal is propely positioned and not slightly askew it should work OK But if it looks correct and leaks you will need a njew seal as it may have been bent or stretched
Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My front loader gas Duet dryer has left brownish stains
Sounds like bad drum seals. Check all the way around the drum at the wall for sections of seals missing or an uneven gap around the drum at the wall.
Hope this helps.
Aug 14, 2009 | Whirlpool Dryers
Seal on fron loader
there is a wire clamp and spring that holds the gasket on, loosen the spring and reset the gasket then refit the gasket and spring.
Dec 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loader washer
Mold and bacteria in your door seal is a symptom of problems deeper inside the unit. All washers - not just Whirlpool, have this problem. The area of worst buildup is always on the inside of the plastic outer tub just above the normal waterline where suds and soiled water splash up and don't get rinsed out. To clean this problem area add 1 or 2 caps of smelly washer cleaner to a full load of laundry. The added bulk of the laundry will raise the water level to include the "splash area". Intermittently pause to soak more extreme cases.
Aug 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW 9400PL0
I just had the very same problem - HELP!
Dec 09, 2007 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
247 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
