Question about Broksonic SC20145 20 in. TV/VCR/DVD Combo
No sound on 1 channel
My TV has 1 channel (USA Cable channel 28) when I piut it on there is no sound whatsoever coming through. All other channels are fine.
  • rlarose3 Jan 06, 2009
    Thank You very much for your help. It did the trick.
  • 716 Answers
Check Your Audio Setting While On That Channel Access Your Tv Menu And Find Audio Change Between Sap Stereo And Mono Probably Will Fix It May Not.
Posted on Jan 05, 2009
  • Michael Fisher
    Michael Fisher Jan 06, 2009
    It Makes Me Happy To Help You.
I have two TVs, a Toshiba in my living room and a Sylvania in the bedroom, both of which are connected to Time Warner cable. They are both older version televisions, not flat screens or plasma. The Sy
You haven't specified here about the channel capacity or both of your Televisions. Is both of it can receive 100 channels. If not, the tuner to both will have the difference. There are sets with which can receive only 50 channels, 90 channels, 120 channels etc: Older versions of TVs will have only low channel capacity. Present ones are of channel receiving capacity up-to 320.
If the channel receiving capacity to your TV is low [as it is older models]; there is nothing more to do. Electro help
Nov 16, 2014 | Toshiba Televison & Video
Hello, My samsung ln82341w has sound problems. Two cable channels have no sound; 1 channel has crackling/static sound; and most of the other channels the sound will go out when the first one or two...
The problem isn't with your TV, its with the cable company.
Call the cable company, problem is most likely with your digital box or a signal problem.
Aug 22, 2011 | Televison & Video
Need to program channels
This is a LCD tv right?U want to hook up free air or pay cable tv.Go in ur tv menu goto setup,go down to CH.press than pick AIR or CABLE.Than just pick one press scan u will get all free air channels or get all ur pay cable channels
May 26, 2010 | Vizio L37 Television
SVA television. Have model # EV1703 Remote no
When you say the remote doesn't get the channels I have to assume the channel entry behavior changed. I am not to familiar with this brand but these are the basics for most tv's. If you have not removed the cable input to the tv or unhooked anything before the problem started here are a few thing you could try. Push the menu or setup button on the remote and under the channel or setup option on the tv make sure it is set to Cable and not Air or Antenna. Run the tv through the auto channel search to reprogram the cable channels. This process can take close to 1 hour on some tv's since it has to scan through the digital and analogue tuners. This will allow your tv to add the correct cable channels and remove the unwanted ones. You should be able to enter the channel number or move up and down with the channel buttons on your remote.
Dec 10, 2009 | SVA-USA EV-1703 17 in. LCD Television
I HAVE A SUMSUNG THAT IS HD, BUT IT'S NOT HDMI,i GET REGULAR CHANNELS, BUT WHEN I SWITH TO A HD CHANNEL, IT IS ALL SCRAMBLED? WHY?
I assume you have cable. The cable HD and digital channels are usually sent in Quadrature Amplitude Modulation (QAM). The cable companies are required to send local channels in the clear but not so for any others. Regular (basic) channels may be clear or scrambled. USA many not be but HBO will be.
So you have 1 of 2 problems: (1) your TV does not do QAM or (2) they have scrambled the channels you want to see. Questions: (1) Have tried direct Over-the-Air (OTA, ATSC) reception for your locals? (2) Can you see the HD local channels on cable? (3) Are you paying for an HD box from the cable company to have the channels decoded? If in doubt contact the cable company.
Current Samsung TVs do do QAM and OTA HD. Alternatives are Dish or Direct to get satellite with an HD receiver using HDMI or 5-cable RCA. Costs are comparable but OTA wins, hands down. -Ken
Aug 18, 2009 | Samsung Televison & Video
Digital channel 25 has no sound.
First make sure SAP or nothing similar is turned on.
After you triple check that just Contact ILO if it continues for more than 1month. This is a software error.
What state are you in?
What channel is this?NBC, ABC
Have you check this at different times of day?
What TV does your son have?
Jun 24, 2009 | iLO 2600 Television
Rca hd52w67 rear projection tv
MAY BE A GLITCH IN THE EPROM (MICRO) IN THE SET...HERE'S A QUICK FIX,,HOPE YOU ARE ON SATELLITE OR A CABLE BOX....TAKE SOME LONG AV CABLES AND TAKE THE SIGNAL "OUT" OF THE SAT OR CABLE BOX AND PUT THE OTHER END IN THE AV "IN" ON THE TV...NOW SELECT THE AV 1 (OR WHICHEVER ONE YOU USED) AND YOU WILL HAVE SOUND AND PICTURE AND YOU CHANGE CHANNELS USING THE SAT OR CABLE BOX---IF YOU DON'T HAVE THESE SIGNAL SOURCES ,,,YOU CAN ALSO USE A VCR AND CHANGE CHANNELS ON THE VCR--LEAVE THE TV ON AV1...TUNICA
Oct 07, 2008 | RCA P52926 52" Rear Projection Television
Symphonic 20" television will only get three local channels
I suspect your tv has gone back to air and should be in cable mode; you will have to go into menu where channel programming takes place. Select cable and autoprogram; it should pick up the missing channels.
Jul 16, 2008 | Symphonic ST420FF 20" TV
Not getting any channels on my tv
get digital channels but no analog
Mar 18, 2008 | RCA F35673MB 35" TV
TV doesn't receive higher channels
Depending on the chassis, it could be the OBT has a bad componet or a parts bad in it or if theres a standup tuner it has to be replaced. You should take the set into a repair place for an estimate good Luck
Jul 28, 2006 | GE 25GT511 25" TV
Broksonic SC20145 20 in. TV/VCR/DVD Combo Logo
257 people viewed this question
Top Broksonic Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
