Question about X2Gen MG19MY 19" LCD Monitor
Moniter very lightly flashing
This morning I noticed my Samsung SyncMaster 932BW (LCD Moniter ) flashing very lightly, not real bad , but enough to hurt your eyes to look at it very long. I restarted my computer, I changed my refresh rate to 60 hertz,I unplugged both power and cables, checked for good connections, thought maybe had interference w/ another electrical item,turned these items off , even though nothing had changed in the office environment...not the problem, moved moniter around, still to no avail... Plugged up to another computer in another part of the house...same problem...tried to change cords out...nope...this moniter is probably not even a year old!! I`ve searched Samsungs website to troubleshoot, didn`t help. Drivers up to date! Any suggestions...Thanks, Melissa
Problem was not solved. I am returning to Samsung. Thanks.
Posted on Jan 06, 2009
Hello sir i have a broblm in my samsung synicmastr 19" blak, when i switch on the moniter, the moniter is with in 2 or 3 second automitically off the display light but moniter is still on and display...
this problem can occur cause of two cases 1 problem with LCD panel (replacement can solve) 2 power failure in side moniter (repairing moniter can solve)
thanx PLZ vote
Feb 22, 2011 | Samsung SyncMaster 931B 19" LCD Monitor
My Samsung SyncMaster 931BW monitor has been working fine for me. It was working fine last night turn it back on this morning and the screen is just black. Reset computer checked the cords and power outlet...
Try it with another PC to make sure is is not the PC video card problem, also chek the cable. If it still does not work, then you will have to open it up.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 05, 2010 | Samsung 19" LCD Syncmaster 931BW Monitor
I have a samsung Syncmaster 932bw and turned it on and noticed a real bad flicker ran all the tests i could find other then your flashlight test cause i dont think it pertains to my certain problem. after...
The flickering picture usually indicates that the power supply is failing. The most likely cause of the power supply failure like this is capacitors either drying out or bulging from over heating. We have a page on our web site at: http://www.ccl-la.com/blog/index.php/capacitors/ This article wexplains what capacitors are, what you will need to look for to identify the failures and which brand and series to get tof rht replacements. In most cases you can open the monitor and look over the power supply and see obvious bulging on the capacitors that are failing. If you replace them you should be back in business. If you have additional questions just let us know.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
May 01, 2010 | Samsung 932BW Monitor
I have owned a Samsung 932BW a couple of years. First symptom noticed was a blank screen and a blinking blue light around the on switch. From another desktop computer, I have swapped video cards,...
reynolds3d, Nothing new here. Happens a lot. 932BW will need to have some work done to the unit's SMPS probably. Read my fixya profile and make decision on what you will do based on info found there. 12fixlouie
Feb 20, 2010 | Samsung SyncMaster 932B LCD Monitor
I have a power light on my Samsung syncmaster 930b but no image at all is this just a lamp issue or is it a dead moniter.
The problem can be bad caps in the power supply, inverter circuits, or bad lamps. You need to open it up and see, report back what you find so we can help you further, see example of failed monitors due to bad caps, lamps here: http://s807.photobucket.com/home/budm/allalbums
Feb 02, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
When computer is starting up monitor goes blank. I have to turn it off and back on
Sent in for warranty repair to Samsung. Appears there has been some problems with 932B & 932BW.
Nov 30, 2009 | Samsung SyncMaster 932B LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
355 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
