Question about Microsoft SQL Server 7.0 (upgrade from copetitive products) Upgrade Version for PC (1 Server/s, 5 Client/s)
When I hit the ''enter'' key, it always adda an ''/'' to the end.
How do I turn off the automatic / that gets added to the line every time I hit the enter key?
  • 21 Answers
GO TO START
CONTROL PANEL
SECURITY CENTRE
ON AUTOMATIC UPDATES CLICK TURN OFF AUTOMATIC UPDATES.
DONE
ENJOY
HAVE A GOOD DAY
Posted on Jan 06, 2009
When I hit "Enter" it always double spaces. What do I need to do to get single space?
Your word default is set to double space. You need to find your paragraph setting, depending on the version of Microsoft Office you are using. Once you find the paragraph settings, you need to set it to single spacing and set the "spacing before" and "spacing after" to zero as in the attached picture.
One way to set the option is to hit control-A to highlight the whole document and then right click, and then click on Paragraph.
25547294-44porhhyjuxju0hkakw43rbb-4-0.jpg Good luck.
Paul
Mar 10, 2015 | Microsoft Windows 7 Home Premium for PC
Rang in 3.50 customer gave $10-when you enter amt tend you get error
turn the key to program and enter (0) , cash, then subtotal . then hit 3 subtotal, (0) cash, subtotal. turn the key back to reg and the cash key should now function correctly
Jan 07, 2014 | Casio PCR-T2000 Cash Register
Problem with spacebar key
I don't quite understand why this would happen after pluggin in a USB mouse - but I've seen it numerous times after a liquid has been spilled on a keyboard.
Sounds like you need to replace the keyboard. Best way to test this is to plug in an external usb keyboard and see if you can type normally on it.
If the laptop keyboard exhibits this behavior, and the external keyboard doesn't - you should replace the laptop keyboard.
Dec 30, 2012 | Dell Computers & Internet
How do I find the log of e?
Press the diamond key (just below the 2ND key) and then the ENTER key. Diamond-ENTER will always convert symbolic results to numeric. If you want numeric results always, press MODE F2, move down to the Exact/Approx line, press right-arrow, select APPROXIMATE, and press ENTER twice.
May 31, 2012 | Texas Instruments TI-89 Calculator
I have been having trouble receiving faxes. It doesn't always happen, only occasionally. The printout says "no fax detected"; even though it has rung, it doesn't seem to connect....
!st thing that I do with intermittent fax problems is to call the phone carrier.
Tell them that you are having fax problems. Ask them to test your line. You could have a bad cable or noisy line.
Jun 27, 2011 | HP LaserJet 3050 All-In-One Printer
I keep trying to simply print to this printer via usb and I get this error, the printer then goes into offline mode. I can scan to the computer, so the connection must be fine. What's the deal smee? The...
There could be few reasons for this. One of then is the Printer Spooler that much be corrupted and another would be the actual printer printing drivers
Click on START button and Click on Run
Type the word CMD ( or COMMAND ) and hit enter key
You will find a new black window on screen.
Execute the following commands,
net start spooler ( hit enter key )
net stop spooler ( hit enter key )
follow the same Start and stop command for 4-5 times. End the Command with NET START SPOOLER ( hit enter key )
Disconnect the Printer USB Cable and re-connect.
It should start printing.
Dec 07, 2010 | Samsung SCX-4720FN All-In-One Laser...
Date and time reset
To set the time: First set to Rate to "SET" then say for example the time is now 1:33 p.m. enter 13 then hit the decimal then enter 33 hit the decimal then hit the time key and you are set.
Jan 22, 2010 | Sharp EL-1750PIII Calculator
INSTRUCTIONS FOR THE KEYS ON THE CALCULATOR
To get a subtotal when adding, finish entering the last number before the subtotal, hit the +, then hit the diamond/pound sign key (just above the 7)
To get a grand total when adding, finish entering the last number in your list, hit the +, then hit the *.
Jan 14, 2009 | Casio HR-100TMPlus Calculator
Key won't turn in ignition on a 2003 Trailblazer
You are going to laugh at this but it works, believe me, get a hammer or rubber mallet, with your key inserted in the ignition, hit the end of it, not hard to bend the key but just a little wack. A couple of times if you need to, Walla, your key will turn, I have had issues like this with my town and country. I always keep something handy to give the key a wack so the ignition will work.
Dec 06, 2008 | 2002 Chevrolet TrailBlazer
Hi i have photo copier minolta dialta di183
Enter the admin mode (U-5) by holding down the Panel Reset key for 3 seconds (until "U- " appears in the display), entering the number 5 from the keypad, and pressing the start key. Enter the 6 digit administrator code and press the start key again. The display should show "Ad-". Enter 1 from the keypad and again press the start key. The display should read "0". Hit the clear key, enter "1" and hit the start key yet again. Hit Panel Reset several times (or turn the machine off and back on) to return to normal operation.
The default administrator code is 000000.
If you do not know the administrator code, it will be necessary to reset it using the tech rep mode. Enter the tech rep mode by pressing the Meter Count key and hitting "Stop - 0 - 0 - Stop - 0 - 1" quickly. Then hit 7 and the start key. The administrator code will flash. You can write it down and use it, or hit the clear key and enter a new code, then the start key. Exit as above.
Jul 03, 2008 | Minolta DiALTA Di183 Copier
Microsoft SQL Server 7.0 (upgrade from copetitive products) Upgrade Version for PC (1 Server/s, 5 Client/s) Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
