Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Error code f-01
Hotpoint aquarius washer dryer odel 640, not spinning, but draining took out motor but it seems, to be sealed was going to change brushes but cannot see any help if you can
  • dennispennan Jan 10, 2009
    thanks most helpful
  • spc989 Jan 15, 2009
    how much would this cost
  • Hotpoint Master
  • 3,463 Answers
This motor does not have brushes fitted, the error code F01 indicates that the motor triac has shorted, this is part of the electronics that control the motor, it could possibly require a new main pcb, and/or new motor. If it is under 5 years old, then you are better off contacting Hotpoint, and getting it done under the 5 year part guarantee.
Plz rate my solution.
Thanks.
Posted on Jan 10, 2009
It says error code f-01. what does it mean
Triac motor faulty or faulty motor. I had the same thing, technician said it is triac motor (150 pound) turn out to be the motor it self (about half the price)
Feb 07, 2011 | Hotpoint Aquarius WD640 Front Load...
Display f-01 showing up
"Error F01" is indicating that the motor triac has short circuited on main PCB, this is part of the electronic speed control for the motor.You can do simple checks like motor connections/brushes etc.If the connections are seems to be perfect check the wiring whether it has continuity from motor to PCB. If there is no continuity then the PCB is faulty.
Hotpoint's advice is to call an engineer, it is not really a DIY repair, unless you have a good knowledge of electronics.
Thank you !!
May 25, 2010 | Hotpoint Aquarius WD640 Front Load...
My machine is a WD640 washer/dryer and is displaying in the led display F-01 ? The machine will also not fill with water but the countdown on the cycles are working
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} F01 on a Washer Dryer means you have a motor fault. Check the motor and associated wiring. You may just have a broken wire. Click on the link for more Hotpoint, Creda and Indesit error codes. Or use these links for WMA & WM workshop manuals.
Mar 11, 2010 | Hotpoint Aquarius WD640 Front Load...
Error code f-01
Error code F01 indicates a short circuit moTor triac.
This is part of the electronics that control the motor, it can be caused by worn brushes in the motor or a faulty pcb .
to check the motor brushes, remove the rear panel,, remove the belt and undo 2 screws that secure motor, lever motor back with a screwdriver or similar, unplug the motor leads , and remove the motor.
You will see the brushes at the armature end.
remove and inspect, you should see if they have shorted by discolouration of the armature.
If you clean the armature with emery paper and it looks o/k, then you can try fitting new brushes, but there is no guarantee that it will work,as the pcb may have shorted.
This being the case then it could be quite expensive to put right.
Thanks.
Jan 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Error code f-01 on hotpoint washer dryer aquarius model wd 640
f-01 means there is a motor problem.
may be the motor and/or the circuit board that controls it.
E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Thanks for using Fixya.
Dec 16, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint WF640
the f-01 error code on your hotpoint all in 1 washer/dryer is a short circuit code for the motor. the only way to clear the code is to have a service tech come and inspect the reason for the error.
May 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Aquarius Hotpoint WD440. 1400 Spin
The next step should be the pump out. If it is not pumping check your pump filter for obstructions. Check the drain hose and also your drain in the wall. If all are clear you may have a bad pump. You should have an error code coming up when the machine stops also, please let me know what it is. Thanks and I hope I can FixYa.
Mike
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
229 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
