Question about Zebra Z4M Printer
Configuration settings do not save in 'Permanent' mode
Hello - I have 2 issues with the configuration settings: 1) On 1 of my 8 Z4Ms, when I send a print job with 4"x2" labels (with a print width of 104 0/8MM set on printer config) the job prints at 50 6/8MM. The settings in the job are correct. When I send the same job to another Z4M it prints with the correct width (104MM). Resetting the print width in configuration with 'permanent' does not correct the printing. When the job comes to that printer, it prints at 50MM. 2) On all 8 of my Z4Ms the setting to calibrate on power on or head open does not save permanently. I have had these printers for 6 years and this has always been a problem. The settings may hold for a week, a month, or maybe more, but all 8 of the printers lose these 2 settings regularly. Thanks for all help offered - My priority is item #1, as I use this printer frequently. Item #2, while a pain, has been around for a long time - I could live with it if there is no solution. Thanks!
    Problem Solver:
  • 17 Answers
Q1# do you have printer driver? what kind of driver ur using? is your driver from www.zebra.com? Q2#what software u are using to print? Q3#ask the programmer of the software if there is a command that control the settings of the printer Q4# is the software DOS or windows program
Posted on Mar 20, 2009
  • 53 Answers
Q#1, is the DPI the same as the other printers? there is also an option in the menu to rescale DPI that could cause the issueprint out a setup label from the printer and compare it to one of the other printers.
Posted on Nov 09, 2007
If my 2700 nokie are not active in gprs how to activite thiis problem
check this
Go to Menu,Settings,Configuration settings,Personal configuration settings
Option
Add new
Select Web
i. Account name
ii. Homepage
iii. User name
iv. Password
v. Access point settings
1. Proxy Enable
2. Proxy address
3. Proxy port
4. Data bearer
5. Bearer settings
a. access point
b. Authentication type Normal
c. Username
d. Password
Activation: Menu,Web,Settings,Configuration Settings
Configuration = Personal config
Account =
The blanks need to be filled with settings from your service provider. Give them a call and ask them for your settings. If they offer to send a setting to you, accept it because the update will be automatic and you can save the hassle of going through this tedious process
Apr 17, 2014 | Nokia Classic 2700 Cell Phone
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
Jun 18, 2013 | Computers & Internet
I want internet settings for my phone
Hi
The phone internet setting is depend of your service provider. so its not possible to give the handset configuration, you get the answer to your service provider make a call to ISP customer care office and tell him/her to send the handset configuration. a few second you get the configuration.
1) Now open the incoming SMS to you ISP
2) And click the option and select the Save option,
3) For save setting it will take few setting, after you get the pop up " Do you want this setting as a
default" select the "yes" option
4) Now start to web you get the internet.
God luck
Sep 03, 2011 | Samsung SGH-A877 Impression Cell Phone
Gprs setting
Go to Menu?Settings?Configuration settings?Personal configuration settings
Option
Add new
Select Web
i. Account name =
ii. Homepage =
iii. User name =
iv. Password =
v. Access point settings:
1. Proxy = Enable
2. Proxy address =
3. Proxy port =
4. Data bearer = GPRS (or Packet Data)
5. Bearer settings:
a. GPRS access point =
b. Authentication type = Normal
c. Username =
d. Password =
Activation: Menu?Web?Settings?Configuration Settings
Account =
The blanks need to be filled with settings from your service provider. Give them a call and ask them for your settings. If they offer to send an OTA setting to you, accept it because the update will be automatic and you can save the hassle of going through this tedious process
Aug 26, 2011 | Nokia Classic 2700 Cell Phone
They cannot deliver the mms picture via nokia C3.but i already set the configuration by smart communication office.
Make sure you have received the MMS settings on your phone from the Network Service provider.Please contact your Network Service provider to receive the settings.
1.They will send the settings via a configuration message.
2.Open the configuration message from the inbox.
3.Save the settings from Options>Save.
4.Restart your phone and choose the correct access point to send and receive MMS on your phone.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jul 03, 2011 | Nokia N70 Smartphone
Panu ako makakapag internet sa fone??? nagtry aq kea lang may kailangan pa atang configuration... manual daw??
Ano po bang model ang gamit ninyo? maaari po kayo mag internet sa phone sa papapagitan ng wi-fi o GPRS. Kung may wi-fi po ang phone ninyo,i-on lang po ito at pwede na kayo dumiretso sa browser. kung wala namang wi-fi ang phone ninyo eh kailangang ma-activate ang GPRS ninyo upang makapag internet po kayo.
sa pag activate ng GPRS, kung GLOBE po ang gamit ninyo eh automatic na pong matatanggap ang configuration settings ng nasabing GPRS,i-save lang po ito at ang may code pong hinihingi,ipasok lang po ang 1234 at pagkatapos i-save eh pwede napo kayong mag internet,basta may load po ang sim ninyo ok na po ito.
In SMART :
Here's a quick tip on how to activate your phone's Smart MMS and Smart GPRS settings if you're with the Smart network:
Download MMS and GPRS settings from Smart:
To download SMART MMS phone settings:
Key in SET MMS and send to 211.
To download SMART GPRS phone settings:
Key in SET GPRS and send to 211.
Example: If you have a Nokia 6230, that's "SET MMS N6230"
To activate SMART GPRS:
Key in "GPRS ON" and send to "333?
To activate SMART MMS:
Key in "MMS ON" and send to "333?
Note :
The configuration settings will be sent to your phone. You will need to select "Save All" to save the settings in the phone. Some MMS and GPRS handsets already have pre-loaded phone settings.
Activation of MMS and GPRS will require a confirmation message from SMART. A message will be sent to the sub once the feature has been activated.
In SUN CELLULAR
Activate your GPRS
Two ways to activate your GPRS:
1. Text ACTIVATE to 2300
2. Call 200 using your Sun phone or 395-8000 via landline, and a customer service representative
will assist you
Configure your Handset
Two ways to configure your phone:
1. Text SUN GPRS to 1200.
2. Manually configure your handset : CLICK MO AKO
Sana po makatungong...
Jun 23, 2011 | Cell Phones
On my hand set l was not save internet configaration when i was saved it call only 70 set allowed save disscarded .now what was my solution
hello bro
Just Follow the following steps to save your configuration settings.
1: Download & install OxyCube.
2: Connect your phone with USB cable. (USB Cable drivers must be installed)
3: Run OxyCube.
4: Select C: (Your phone memory).
5: In folders tree select Omadm Folder.
6: There will be 70 Numbered folders under Omadm.
7: Delete all folders accept first 5 & the folder named PRECFG.
8: Disconnect your phone.
9: Reboot your phone.
10: Either request you provider to send you settings. or insert it manually.
11: This time the settings will save normally.
Mar 07, 2011 | Nokia 6300 Cellular Phone
Enable RAID system
use this guide, this is fo the embedded sata raid controller that comes standar with the ml150 g5.
Enabling SATA RAID functionality in the BIOS Setup Utility: 1.Boot the server, and then press F10 to enter the ROM-Based Setup Utility (RBSU).
2.Go to the advanced tab.
3.Enter the IDE configuration or hard disk configuration.
4.Change the ATA/IDE configuration to enhanced or SATA controller 2 enhanced (if not available then use enabled mode).
5.Configure SATA as RAID or configure controller 1 as RAID.
6.F10 to save and exit.
7.Reboot the server.
8.During post f8 will now show up for the embedded SATA set up.
•Creating the RAID volume.
1.Enter the embedded SATA setup by pressing f8 during post.
2.Enter the array configuration utility.
3.Enter create array.
4.Create the raid volume as desired.
5.Save and exit.
i hope it helps you!!!
Aug 11, 2010 | HP ProLiant ML150 G5 Server
My hp laserjet P4014n is giving an error message 68.2 permanent storage write fail what can i do to clear this massage?
Hi! I will be glad to assist you in this issue.
Usually all you have to do is initialize hard disk even if you do not have one. Just turn off the printer. Turn the printer back on and when the memory starts to count hold down the menu key until all three lights come on. When all three lights are on solid release the menu button and press the arrow back button and initialize disk should appear in the menu. Just hit the check mark button again and it should take care of the problem.
Here is the link just incase you need more solution:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=bpl12422&jumpid=reg_R1002_USEN#A46
Oct 26, 2009 | HP LaserJet P4014n Printer
Can't save the printer darkness in the printer
go to printer driver properties.. 1.click printing preferences set it to USE PRINTER CONFIGURATION 2.go to advance click Printing Defaults set it to USE PRINTER CONFIGURATION
you must set this two configuration note: fresh installed driver defaulth to software control
Oct 14, 2008 | Zebra Z4Mplus Label Printer
Zebra Z4M Printer Logo
1,063 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
Computer Links
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
