Question about Electrolux Epic 6500 Vacuum
Electrolux Epic 6000 SR Owners Manual?
Got an Epic 6000SR and need a manual so I can figure out what the top dial does (I would imagine suction strength), what the lights are for and general care of the vacuum.
Also is there a secondary filter on this machine?
  • 2 more comments
  • Anonymous Jan 10, 2009
    kepps shutting off for no reason
  • Walt Darson
    Walt Darson Mar 08, 2009
    i too would like to know what - exactly - that dial on the top of the machine does. thanks...
  • Don Cooke Mar 14, 2015
    From the manual: "Adjust the control dial for type of cleaning required. For normal cleaning conditions the dial should be set in center position (T). When vacuuming fine dust, rotate the dial counterclockwise. When vacuuming larger particles, rotate the dial clockwise."
  • AerusGuy
    AerusGuy Mar 12, 2018
    Here is a link to the Epic 6500SR's users manaul. It was the successor of your Epic 6000SR and differed only in that it had electric wands instead of the standard ones.
    http://www.aerushome.com/Warranty/Manual...
    Fyi, Electrolux Corporation, the manufacturer of your Epic 6000SR cleaner, changed its name to Aerus LLC in 2000 when it sold back the Electrolux trademark and brand to its original parent company, AB Electrolux of Sweden.
    Go to aerushome.com to locate an Aerus dealer for assistance, sales, parts, literature, and service.
    Best.
    New Friend:
Yes, there is a secondary carbon filter under the accessories tray.
  • Slide accessories of of clip
  • Gently press latch (on rear of tray) and lift off the cover.
  • Lift air filter out and replace.
Posted on Mar 14, 2015
    Problem Solver:
  • 9 Answers
Oh, and as far as i know there's no secondary filter on this machine. or at least if there is, ours hasn't needed any tending to in at least ten years or so...
Posted on Mar 08, 2009
There are 4 Symbols, next to the suction dial, on the Electrolux Epic 6000 SR vacuum cleaner . . . what does each symbol refer to ? J P Mac D
the dials refer to types of dirt.The higher the dial the heavier the dirt.This is for the auto shut off when the bag is full.The best setting is in the middle.If you are vacuuming up fine dust suck in some Kleenex before this will coat the bag and prevent premature shu toff.
Apr 29, 2015 | Electrolux Vacuums
How do I get reverse suction with the electrolux epic 6000?
I have no idea just what reverse suction would be or how to get it from ANY vac. If you're looking at getting the blowing air from the vac instead of suction, then simply move the hose from the suction end to the exhaust end.
May 25, 2014 | Electrolux Vacuums
Why does my Electrolux epic 6000 sr shut off with suction?
If this Epic 6000 is shutting off when you either just turn it on or while vacuuming with it...it\'s one of several things...1. Change the bag if you\'ve been picking up a lot of "fine" dust such as drywall dust or carpet freshener powder. That\'s ******* them. 2. Being the machine is over 22 yrs. old, the suction control valve inside either needs to be replaced or just cleaned well. This is the usual cause of the vac shutting off especially if you\'ve tried the dial in several different settings. Hope that helps!
May 20, 2014 | Electrolux UltraLux 2000 Bagged Canister...
Light on 6000sr canister electrolux wont turn back on??turned dial whats it for?
The dial on the top of the unit sets the carpet height. The bulb needs replaced.
Sep 17, 2013 | Electrolux Epic 6500 Vacuum
I need a service manual for a Electrolux Epic 3500 Sr
They aren't available, except to authorized Aerus Electrolux store owners and service techs.
Jan 30, 2011 | Electrolux Vacuums
I have the electrolux vacuum epic series 6000 SR and bought it used therefore I dont have a manual. I have had it for about a yr and it worked great..it looked like it should have a filter but I didnt...
1. A manual can be downloaded from:
http://www.aerusvacuums.com/support/manuals/.
The Epic 60006500 is located under "Older Models". Download the Epic 6500 manual
2. Check for clogs in the hose and the power nozzle inlet.
3. Disconnect hose. Turn on vacuum. Does it run? If so, place hand over intake? Did it shut off? If it did, the problem is a worn out or broken component inside the vacuum. Generally a result of using generic "made to fit" Electrolux bags. This is a part that needs to be replaced in an authorized Aerus (Electrolux) shop.
Sep 15, 2010 | Electrolux Epic 6500 Vacuum
We have an Electrolux 6500 SR Model C102G. We
yes it wears out it is a common problem i eliminated several of them for people its a job that takes alot of patience i opt to just eliminate the part its sort of useless and causes your machine to act contrary if you want to replace the part here is the place Electrolux Aerus 4526 Maccorkle Avenue
South Charleston, WV 25309-1409
(304) 768-2158.. if you cant fix it contact me and i will repair it for $35.00 plus parts or no parts either way it can be fixed the above contact is the dealer i use for parts
Jun 13, 2010 | Electrolux Epic 6500 Vacuum
I have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
Dec 05, 2009 | Electrolux Epic 6500 Vacuum
How to check the belt?
I have listed a link to the manual for your model and a link to the replacement belt you need. Hope it helps!
Manual
Electrolux Epic 3500 Replacement Belt
Oct 29, 2009 | Electrolux Epic 3500 Vacuum
I am looking for an owners manual for my Epic Series 6500 SR.
Owners manual in pdf-format Electrolux Epic Series 6500 SR:
http://homeappliance.manualsonline.com/ex/thread/view/idThread/1424472
Clicking "Epic6500.pdf" will pop up a registration shortly,
but the manual appears directly after that.
Aug 09, 2009 | Electrolux Epic 6500 Vacuum
Vacuums Logo
1,894 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
