Question about Whirlpool Duet GHW9150P Front Load Washer
Inside of the dryer is cracking- huge holes!
I have only had my Whirlpool Duet Sport dryer a little over a year. I have been noticing that it takes 2 or 3 cycles for the clothes to dry. I looked inside and found that they entire inside is cracking and there are three large holes! I called Best Buy where I bought it but they said the warranty was only for 1 year and they could not help me unless I wanted to pay for a service call. Can the drum be replaced or do I need an entirely new dryer?
  • 115 Answers
The drum can be replaced but dont know if you want to pay for one they are probably expensive and 2nd if it is taking 2 to 3 times to dry clothes you have a vent problem which has caused the cracking of the drum probably cause so much heat build up in the machine your vent is stopped up and it isnt keeping the heat and moisture in the dryer which is a fire hazard please call a technician and please rate this
Posted on Jan 05, 2009
Switch the 3 prong cord to a 4 prong on my whirlpool duet sport, 9 cycle
Hi mybabycamero
Go to the following webpage and you can see how to convert your 3 wire to a 4 wire dryer.
Please take time to rate me
Bud
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Oct 17, 2012 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
I need to put my 4 prong cord onto my whirlpool duet dryer
Hi mybabycamero
Go to the following webpage and you will see how to change your 3 wire into a 4 wire dryer.
Bud
How do I clear error code F-28 on my Whirlpool Duet Sport electric dryer?
The tech sheet is located under the kick /service panel in a jacket. Suggetions and codes are in it. Duet sport service manual
Sep 30, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet sport dryer will not power on no lights nothing
check inside, white fuse should be near air flow . also near themo couplers, take volt meter ,place on continutee, first unplug unit. remove one ,of the two wire's. check to make sure circutt is closed ... if not rplace fuse.
Sep 15, 2012 | Whirlpool 279818 4Way Vent Kit for Duet...
How do i fix a duet dryer that takes too long to dry
I pulled apart the back of my dryer to access the heating element. I noticed I have a break in one of the coils. So, that means I need to buy a new one. The thing I noticed is that only of of the terminals at the bottom of the heating element has a plug on it. There are no additional wires inside the dryer that could have come off so I am a little confused as to if i new coil will work.
I watched a video online and it clear shows both terminals being connected. Anyone have any advice?
Feb 20, 2012 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool dryer duet sport MOD WED8300SW error message
I have a whirlpool duet sport electric dryer with an error code of F 26.
Mar 02, 2010 | Dryers
I need to get items out of blower area (collar stays fell in from the inside of the lint trap) of a Whirlpool Duet Sport Dryer wed8300sw0 - any suggestions? Also, does anyone know if this model has a one...
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/479b6231e5693a13852571650061e709/$FILE/8178559.pdf
Your dryer service manual.
Oct 30, 2009 | Whirlpool Dryers
Dryer keeps drying and getting too hot
Check the dryer vent .The vent is stopped up,in the vent,or in the inside of dryer,in the lint hopper.Clean it out and unstop the dryer,and the vent.
Oct 10, 2009 | Whirlpool LER5636P Electric Dryer
Water pours from detergent basin-Whirlpool Duet Sport
first remove dispenser pull out and make sure its not clogged inside,w/ hand fill around ,, on any frontload machine i perfer liquid soap,, are you using HE detergent
Jan 03, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
148 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
