Question about Car Audio & Video
Troubleshooting amp setup
I have a 600w 4 channel bridgable amplifier which 2 front speakers are connected at 150w each plus a 300w subwoofer. The sub isnt producing much bass at all. The rear speakers are hooked up the stereo head & now not working at all.
What have I done wrong???
Also can i connect all 4 speakers by bridging them to the amp as well as run the sub?
Can any1 help me....driving me nuts....lol
  • 3 more comments
  • tanya_j Jan 06, 2009
    Thanx, it is a VG 640 Tenvox 600watt amp
    It worked in my previous car & produced good bass & ex sound from speakers. Using all the same equiptment just in a different car.
  • tanya_j Jan 08, 2009
    Hi thanx for that
    No thats a problem, the person that installed it in the first place must of thrown it out as i dont have it. I too have been to Tevox site! When I removed the amp from the old car I left all the wires on the amp, so thought it would be easy enough to install again myself....lol.
    I cant do it now as its almost 1.30 am but tomorrow i can write all the connections & crossovers etc down & post on here if it would help.
    Thanku.....
  • Jimmy Hall
    Jimmy Hall May 11, 2010
    tanya_i: any info would be helpful. having access to an install manual would point out any additional options that the diagram on the amp may not have the ability to demonstrate. is the tenvox VG 640 not a commonly found item in Australia? is there a car audio facility near-by? i know outside of the main cities, there are large distances between towns. we'll keep at it until we get this solved.
    peace-out
  • Jimmy Hall
    i'm not familar with tenvox, but most amps install about the same way. some have additional options vs others. bottom line i need to see a copy of the install manual. i visited tenvox's site but they don't have archived manuals on line. i've written them requesting some info. do you have a copy? if so, can you scan & send it to me? once i see the wiring diagrams i can help you.
    peace-out
  • Jimmy Hall
    I need the model # of the amp before I can help. respond with that info. Generally the purpose of bridging the amp is to drive a single speaker such as a sub-woofer.
    peace-out
You probably need your remote wire re-hooked and make sure the ground wire is good and the remote wire is connected to the right wire(the red wire).
Posted on Jan 12, 2009
I have a sound stream xta 600.2 what would be the best 12" subs to with it
match your total rms output at the resistance you will be running the amp at to the subs.
example:
if your amp puts out 300w RMS@ 4ohms, then it will produce 600w RMS@ 2ohms. half the resistance, double the power.
So now that you know your available power, you should get speakers that will be used to the fullest at that given resistance.
example:
If you have two 4 ohm subs that have a power handling of 300 watts, Then you can wire them in parallel ( + to + and - to -) to get a 2 ohm load (which will be 300w per sub with the above amp) or in series (+ to - to + to -) to get an 8 ohm load. (300w amp @ 4ohms = 150w amp @8ohms = 75 per sub).
Keep in mind: choose the speakers to fit the amp, not the amp to fit the speakers. If the amp has more power than the speakers can handle, you will blow them. and ALWAYS USE RMS WATTAGES.
May 06, 2011 | Soundstream Xstream XTA600.2 Car Audio...
I have a 1200watt amp that's only providing 300watt output with 8ohm Behringer B212 speakers. Is there a resolution and what would it be?
I'd need to know more about the amp, but don't forget, amps are rated as their max power...
So lets take a 300W/channel stereo amp at 8 ohms.
Ok, it's stereo, so there's 600W
But the amp is capable of 4 ohm loads...well, now you can deliver 600W/channel, for a total of 1200W
In this scenario, your amp is doing exactly what it was designed to do with those speakers.
If you wanted to get the full 1200W out of the amp, you'd have to hook up 2 more speakers in parallel to the ones already there. This drops the impedance to 4 ohms per channel = 600W / channel.
Yes, the power is split among the apeakers...300W per speaker into 4 speakers = 1200W
so any way you look at it, there's your 1200W
Feb 27, 2011 | Behringer B212 600watt, 2-Way PA Speaker
Total Power Bridged in 2 or 4 Ohms ?
Nice amp the specs say the following:
4 Channel 100W x 4 (4 Ohm)
4 Channel 150W x 4 (2 Ohm)
2ch Bridge 300W x 2 (4 Ohm)
But.... it tends to go into protection quite fast so i wouldn't go too low with speaker impedance.
Dec 28, 2010 | DHD NTX-3106 Car Audio Amplifier
Selecting an amplifier!
Buy a quality 2 channel amp. About 600 rms and set one channel as your highs using your crossover and then the second channel on "low" position for your sub. wire directly in to your low's channel with your sub at 2 ohms and then wire your speakers to the other channel.
May 23, 2010 | JBL GTO937 Car Speaker
Kicker 8 inch 4 ohm subwoofer 200 watts rms?
Max 200 W. You could bridge 2 channels of a 4 channel amp (or get a 2 ch amp and bridge it) and connect the sub. Bridging = connect + of sub to + of one channel, and connect - of sub to - of *other* channel. Check amp manual for instructions.
Don't get a mono - most are 300W or more - might burn the coil during loud passages.
Jun 22, 2009 | Car Audio & Video
How to wire 2 ohm 2 12ich alpine type r's to box terminals?
Dual 4 ohm subwoofers can only be wired @ 1 ohm, 4 ohm or 8 ohm.
2 ohm mono load is not possible.
You will need to use (1) subwoofer to get the 1000W out of the amp.
Wire both positives on one sub to + on amplifier and both - on the same sub to - on amplifier to give the amplifier a 2 Ohm load.
Add a second amplifier, or buy an amplifier that is 1 ohm mono stable.
You can wire both to the amplifier at 4 ohms 600W, but they will share the power and only see 300W ea.
Jan 12, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
Subwoofers
This will depend on the amplifiers capabilities.
I will give 2 different scenarios.
#1 Stereo configuration
If the amplifier supports an RMS power output close to the RMS input power of the subwoofers then run the amplifier in stereo mode. For example 150 watts RMS X 4 channels driven at 20-20khz. (If you can provide a model # for the subs and the amp your looking at I can help you further with this decision.
Wiring for this is easy and simply involves matching the connectors for 2 of the channels (Front or Rear) to each of the subwoofers.
#2 Mono Bridged mode.
If the amplifier is lower power but mono bridgable you can bridge two Pairs of channels and power each of the subwoofers this way.
Generally speaking a 2 channel bridgable amplifier will be able to at least combine the wattage of each channel into a single monural channel and in many cases its actually higher.
So you would bridge the front 2 channels into a single bridged mode for one subwoofer. and then you could bridge the read 2 channels into another bridged mono channel for your other sub woofer.
For example if you had bridgable amplifier thats 50 watts RMS X 4 you coudl very likely (Generalization based on quality of amplifier) send 150 watts RMS to each subwoofer.
Again I would need to know what amp you're refering to to provide specific wiring instructions. Many Bridging amplifiers either have a single switch that will send them to bridged mode or you would use the positive + terminal from one channel and the negative - terminal from the other channel or a combination of both.
Sep 17, 2008 | Kenwood 12" 4-Ohm Single-Voice-Coil...
MRV - 1507 Question ...
The MRV-1507 is a two channel amplifier, below I've pasted important info from the manual:
Battery Lead (Sold Separately)
Be sure to add a 80 amp fuse as close as possible
to the battery’s positive (+) terminal. This fuse will
protect your vehicle’s electrical system in case of a
short circuit. If you need to extend this lead, the wire
gauge should be AWG8 or larger.
MRV-1507 ... 80A amp fuse
Power Output: RMS Continuous Power (at 12.0V, 20 Hz to 20
kHz)
MRV-1507
Per channel into 4 ohms ......................... 150W, 0.08% THD
Per channel into 2 ohms .......................... 300W, 0.3% THD
Bridged into 4 ohms ................................ 600W, 0.3% THD
You can find a manual for this amp here:
http://www.alpine-usa.com/US-en/support/support_search.php?modelname=mrv-1507
Jul 07, 2008 | Alpine MRV-1507 Car Audio Amplifier
Planet audio vx3002
Sorry wayne2953 but this amplifier isn't stable @ 1ohm loads. This amplifier would be better suited running a pair of 12's, 4 12" subs could run if configured correctly but the subs would be underpowered and probably not sound very good.
Features of Planet Audio VX3002:
  • Max Power (2 Ohms) : 300W x 2
  • RMS Power (4 Ohms) : 150W x 2
  • Bridged Power (4 Ohms) : 600W x 1
  • Signal-to-Noise Ratio : 102dB
  • Frequency Response : 20Hz-20kHz
  • Dimensions : 10-5/8"W x 2-7/16"H x 16"L
Mar 31, 2008 | Planet Audio VX3002 Car Audio Amplifier
Jl audio 12w1v2-4
500watts sounds about right to me,i wouldnt go any higher as you risk popping the sub and haveing a melt down in the coil section of the subwoofer.
Feb 18, 2007 | Jl Audio 12W3 Car Subwoofer
Car Audio & Video Logo
166 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
