Question about Dell Latitude D600 Notebook
Alps touchpad, eraser tip, and internal mouse buttons not working
Dear Sir: I've read your solution of 24 July 2008 on a similar problem. I have downloaded the drivers from your link in your help to that individual, and although the machine told me it already had the same driver I installed it anyway). I then went into F2 setup and changed the settings as indicated to activate the internal mouse, re-booting after each setting change, all to no avail. An external USB mouse works, however. Any further suggestions very much appreciated. Regards, D. Spencer
  • 1 more comment
  • DDS55 Jan 06, 2009
    Thank you very much. I tried this solution but none of the Fn plus F1 to F12 solved the problem. More details: Neither the pointer nor the touchpad is working (or the associated mouse buttons)on this D600. An external mouse works. Bios is set to use both, as are the mouse properties in Control Panel. The Touch Pad icon appears in the tray, but does not flash with a blue dot when I touch the pad, as it does on my other D600s. I've updated the driver, I've tried to uninstall and re-install the Touch Pad, all to no avail. The Alps pointing device is plugged into PS/2 mouse port. The devise is by Alps Electrick Co., Ltd 1998-2005, Version is 5.4.104.4. Thanks for any assistance.
    Thanks you very much. Here is my report:
    Device Manager shows the Alps Touch Pad with no yellow triangle; properties shows it is "working properly".
  • DDS55 Jan 07, 2009
    We tried a system restore when the problem first occurred, without positive result. I've already updated the drivers (the machine tells me I have the current driver). So is re-installing the operating system my last resort now? Thanks to all of you for your suggestions!
    Sergeant:
  • 183 Answers
Reinstall your OS . And if still remains same problem even after doing this then last option left is replacement of touch pad.
thank you for posting on fixYa
Posted on Jan 07, 2009
    President:
  • Dell Master
  • 1,314 Answers
The touchpad itself is faulty and needs to be replaced.
  • Dell Master
  • 19,396 Answers
To start you need to test the touchpad on a different computer, to verify it is not faulty.
Then, as suggested you check that the touchpad is installed on device manager, if it is not, or if there is a yellow mark or a red cross on the device, then there is a driver problem.
In that case drivers are not correctly installed or are not the right ones for your system.
If that looks Ok, go to control panel, switch to classic view and open the mouse menu, there on top click the last tab that is hardware.
In there check that the touchpad is present and enabled.
If that still does not work got to Bios, and disable the laptop buit in pad, even if they are supposed to work at the same time.
If the built in pad is faulty it may send a bad data to Bios, and the new pad may not work because of this or a different hardware conflict. That is a remote possibility, but when it happens it is difficult to fix.
The most likely is that you are using wrong drivers.
Posted on Jan 06, 2009
  • 15,935 Answers
You or another program may have disabled the service running...
From start>run> type: services.msc
click on the Alps service, enable from the drop down menu.
Reboot to see if it starts.
  • blueextc3221
    blueextc3221 Jan 06, 2009
    sorry, i believe the proper way to enable is double click on the service. That will bring up the service info. Right in the middle there should be a pulldown menu. If it says disabled... choose enable. then select OK or Apply and reboot.
    President:
  • 2,110 Answers
Ftp://ftp.us.dell.com/input/R113813.EXE
download and install this driver..
    Sergeant:
    Scholar:
  • 199 Answers
Do a system restore to a point date when your pad and mouse where working. If this does not work go to the manufacturers website and download the drivers for your notebooks keypad on another pc. Load them on a thumb drive and install them. You can limp navigate with the tab key. If restoring to an earlier date and reloading the drivers does not help back up all your critical files and reload your entire operating system. If it still does not work there is a hardware problem, but I highly doubt it. I hope this gets you going.
ok.
  • 51 Answers
I think you're referring to a different expert, but I'll take a shot at it.
You say an external mouse works. If that's the case, (and I'm sorry if the previous expert already covered this), use it for the following steps.
1. Right-click on My Computer, and select "Manage"
2. Click on "Device Manager"
3. Click on "Mice and other pointing devices"
4. You should see your touchpad listed there. If you don't, the driver is missing. If it is, but has a yellow triangle on it, the driver is corrupt. Delete it, and re-install the driver, and restart. If the pad is listed, with no yellow triangle, then there are two possibilities: either the pad itself is non-functional, or the BIOS is not relating proper information to the CPU.
Try those, and report back, and maybe we can rule out a few more possibilities.
Posted on Jan 05, 2009
  • Dell Master
  • 13,433 Answers
The touchpad mouse is not working? The mouse maybe disabled to enable or disable the touchpad hold down FN key and look at the F1-F12 keys one of those buttons will enable and disable the touchpad.
Touch pad not working
It is possible that the micro switch underneath the button is defective. If this is the case, then the laptop ,(if still under warranty),should be returned to the manufacturer for repair. Otherwise, a new motherboard will be required as the micro switches cannot be replaced.
Dec 18, 2013 | Acer Aspire 7520-5185 Laptop
Tip
Jumping Cursor on ALPS Touchpad?
If you experience a jumping cursor where it jumps from one line to another, go to this link and download the driver for ALPS pointing device. This is from Toshiba (thanks to them for having the most updated touchpad driver) but regardless of your computer, IT WORKS!!!
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/download.jsp?ct=DL&soid=2475604&ref=EV
After downloading the driver
>Go to Control Panel
>Open Mouse icon
>Go to Advanced Tab
>Click on the Advance Configuration Button
>Mark the following options with a check:
•disable tapping
•disable pointer movement
•disable scroll function
>Click Apply
>Try typing on a word pad
on Oct 03, 2010 | Computers & Internet
I used to have a touchpad settings program but can't find it any more
Usually all dell system are provided with ALPS touchpad. First check whether ALPS is installed or not from (control panel -> programs). If installed go to (control panel -> mouse) then you will see a tab called "dell touchpad". click on the image, you will see touchpad window settings. There check the checkbox (Display icon in taskbar).
If the ALPS touchpad is not installed please go to dell driver download site and download and install that.
Oct 10, 2013 | Dell VOSTRO 3700 CI5 226G 3GB...
My Dell Vostro 1014 laptop's touch pad does not work!! The buttons work fine but I'm having problems with the pad. The drivers are up to date and the application used to control the touchpad c
If you have a external mouse, or you can borrow, go into device manager to see if the pad is enabled, if okay! try a system restore bringing the computer back in time before this happened, if still no luck the sensor pad maybe defective, the last option a complete recovery of the operational system to factory setting, this will prove if the sensor pad is defective, or wire ribbon might have come loose from the motherboard.
Apr 01, 2012 | Dell Vostro 1014 Laptop Computer
Dead dell touchpad x(
Have you tried System Restore? If not familiar... Start Button ---> Help ---> System Restore ---> "Restore my computer to an earlier date" --> choose an appropriate date, maybe a few days earlier than the problem.
Re-boot and see if works! If you are ceratin that the problem arose simply from hibernating, then restoring should do the trick!
Hope this helps!
-- RT
PS - Don't forget to vote!
Sep 07, 2009 | Dell Latitude D610 Notebook
Touchpad & lower 'mouse' buttons do not work
There is a button on the laptop which re-enables the touchpad. It's either next to the touchpad, or you must hold down the Fn button and press one of the function keys at the top.
Jul 07, 2009 | Lenovo ThinkPad R60 with Wireless Wide...
Touchpad not working
First check: Control Panel -> Mouse -> TouchPad On/Off
Second check for a button near the mouse pad, often there are buttons that will enable/disable the touchpad
Thrid use the shortcut key FN+F9(or what ever F key that is used by your laptop) to disable/enable the TouchPad.
Fourth try this software: http://www.kingzm.com/eng/files/download/MouseManager.zip
Fith
- Select Start, Settings, Control panel.
- Open System, click on Hardware, and Device Manager.
- Expand "Mice and other pointing devices", and double click on the entry below, that may be called "HID-Compliant mouse", or "Alps Pointing Device".
- Under "Device usage", choose "Do not use this device in the current hardware profile (disable)", and click OK.
Jan 20, 2009 | Toshiba Satellite A205-S4617 Notebook
Hello
go here and download the touchpad driver and install it
that should solve your problem.
Oct 15, 2008 | Computers & Internet
Dell Inspiron 6000 Alps Touchpad not working
Try unistalling the touchpad driver, and reboot. The machine will find the touchpad and reinstall the driver automatically. These have a tenancy to glitch when using an external mouse, and this should clear it up. Let me know.
Aug 28, 2008 | Computers & Internet
Dell Latitude D600 Notebook Logo
66 people viewed this question
Alun Cox
