Question about Brother CS-80
I now have diminished eye sight but still enjoy sewing. Is there a machine that has an automatic threading system, and will also wind a bobbin without having to remove the bobbin?
    Problem Solver:
  • 19 Answers
Try janome uk 0161 666 6011 they will be able to help they do some machines that have a threader
they are very helpful. mary h
Posted on Jan 06, 2009
HOW DO YOU WIND A BOBBIN ON A PFAFF 2022 SEWING MACHINE
Bobbin winding
1. Place the thread spool on the spool pin in
against the spool.
back to front. Pull the thread clockwise around
the inside to the outside.
4. Place an empty bobbin on the bobbin spindle.
5. Push the bobbin lever to the right to wind.
A pop-up appears on the screen to inform
you that bobbin winding is on. Press the
foot control or the start/stop button to start
winding the bobbin.
When the bobbin is full, the bobbin winding
will slow down and stop automatically. The
pop-up closes. Remove the bobbin and cut the thread
Sep 14, 2016 | PfaFF Sewing Machines
My endless automatic bobbin winding for embroidery doesn't work?
Are you using the bobbin especially designed for that function? Did you use the plastic template? Setting up for endless bobbin winding is quite involved, and it's easy to skip a step and make a mistake. It took me several tries to set mine up.. Frankly, once I finally got it set up, I wasn't thrilled. It doesn't hold a lot of thread, and it was quite frequently interrupting the project to wind more thread on the bobbin.
Jan 10, 2016 | Singer Quantum XL-5000 Computerized Sewing...
I only want to know if the wheel must be loosened to wind the bobbin and if so with direction, to the front or backwards and press and turn or pull and turn.thanks
Which make and model sewing machine do you have?
None of my sewing machines need the wheel to be loosened for bobbin winding. The Singer Touch & Sew bobbins are filled in place. Use the handwheel to get the needle into the highest position (just turn the wheel). Wrap the top thread around the screw that holds the presser foot; open the slide plate part way and press the bobbin wind button. Hold the top thread and then begin winding by stepping on the foot pedal.. The thread should break after a few winds.
The Kenmore and the Husqvarna Vikings both get wound at the top. Place bobbin on winding pin. With the needle up and metal presser foot in place thread the top thread up to the bobbin (through the guides) and up through the hole in the bobbin. Slide the bobbin winding switch over towards the bobbin. Hold the thread tightly and begin winding (step on the foot control). After a few winds are on the bobbin, cut the thread that you were holding flush with the top of the bobbin. Continue winding the bobbin. (The newest Viking in the group has a computer screen; on that one, do not press OK until done winding the bobbin.)
However, if the handwheel is not turning and the needle is down, first find out why it isn't turning properly. This could indicate a tangle of thread somewhere in the system. (The older Husqvarna sewing machine in my home has a non-functional handwheel. The machine will still sew but you have to use the needle up/down switch that forces the needle to stop in the up position before you run out of bobbin.)
Please add a comment with the specifics of your sewing machine and I'll be glad to add additional information.
I hope this helps.
Feb 28, 2012 | Sewing Machines
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Feb 16, 2010 | Singer Sewing Machines
Where can i find a threading diagram for a brother vx560 sewing machine
how do I wind the bobbin?
Maybe a diagram to thred it as well?
melba
I Borrowed a machine
for a project
Jul 09, 2009 | Brother Sewing Machines
Bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Aug 17, 2008 | Sewing Machines
Sewing machine: Problem getting bobbin to automatically wind with thread from spool
You ought to have a 3 mth warantee with this used machine, take it back to the dealer and have them fix this problem...in Australia, consumer law provides that the sale of goods requires that they are "fit for their intended purpose".....there is almost certainly a similar provision where you are........get it remedied soon, as a feature that has not worked since you purchased ....perhaps calling first to ensure you are able to meet with the service person to explain.
I would not recommend you open it yourself until the dealer has looked at it.
If they cannot fix it, ask for replacement or money back.
Mar 08, 2008 | Sewing Machines
My bobbin keeps getting tangled up when I sew
Take the thread out of the top and bottom and turn the handwheel by hand to see if the machine will rotate smoothly.
Rethread, making sure that the thread is in the bobbin tension slot and that the upper thread is in the tension and the take up lever.
Sorry for the delay in response. I just found the sight this evening.
Apr 20, 2007 | White Sewing 1740 Mechanical Sewing...
Brother CS-80 Logo
35 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
