Question about Kenmore 62602 Electric Dryer
Kenmore electric dryer throwing breaker
It will run for 10 minutes and throw the breaker, it heats fine, the timer works, and i just replaced the heating element.
  • 247 Answers
Might not be a dryer problem. Following assumes that the breaker that's going is an overcurrent device (something in place of a fuse - what we in the UK usually call an "MCB") rather than an earth leakage circuit breaker. MCBs often have two trip devices - an electromagnetic trip which protects against major faults, and a thermal backup which protects against chronic overload. It could be that you're cooking the thermal element. How much current is the dryer meant to take? (Calculate by dividing power consumption in watts by supply voltage). Is there anything else coming off the same circuit breaker at the same time? Calculate the current drawn by the other loads, and add them all up. If the total current is more than the rated current of the breaker, not only have you found the likely source of your problem but also you've identified that you are overloading your wiring (finding this out is a good thing, as it gives you the opportunity to stop before you set the place on fire). If the total current is below, but near the rated current of the breaker, then you may have a problem with the breaker itself. Possibilities include inadequate ventilation around it or location in a cabinet which is picking up external heat (both need sorting out urgently) - or it may be that the breaker is old and tired and has gone out of calibration. Investigating any of these needs more skill than it's wise to try to acquire from a stranger on the web. A.
Posted on May 24, 2007
My Kenmore HE4 electric dryer runs for 2 minutes and stops
follow this steps and fix it. God bless you
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replac it. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace it
Oct 01, 2013 | Kenmore Elite HE4 Electric Dryer
No electric come to electric coil
Check your breakers. Sometimes it will throw just one of the two breakers and it will spin, but not enough electricity to allow it to heat.
Jul 20, 2011 | Kenmore 62602 Electric Dryer
Clothes don't dry completely
Check your breaker. An electric dryer works on 220 volts, which is two 110 volts put together, but on separate lines. Those breakers have to be separated all the way from the transformer. So, if you have one breaker for the dryer, you will be okay, usually on a double pole, double throw breaker. Sometimes they are wired into two different breakers. The motor is on one breaker, and the heating element is on the other breaker. So, if they aren't on a breaker that is made as a double unit, the heating element can trip one breaker, and since they aren't made together as a unit where it will shut the whole dryer down, the motor in the dryer will still run, and the drum will still turn. It just won't dry clothes. Now, if you have made sure your power is ok, which i have no way of knowing if you just moved there, you had the dryer working in that spot for fifteen years, or what. So, if you have had it there for a while and it runs and it does not dry, and the breakers aren't tripped, then you need a new heating coil in the dryer. They burn out, just like toasters go bad, they work on the same principle. It is not that hard to replace one, just look at how the old one is before you remove it, and install the new one in the same way.
Jul 11, 2010 | Kenmore Dryers
My roper dryer will run for few minutes and throw a breaker.It gets hot and spins just throws breaker
check the vent i went on one that done that if vent is clear and no other signs replace breaker
Jun 08, 2010 | Roper RES7646KQ Electric Dryer
Dryer is flipping breaker after 10 minutes into dry cycle.
You have a weak circuit breaker . Should be a 30 amp or higher . If you have access to an amp meter , split the dryer cord , separating the 3 wires (do not remove the insulation ) . If you have a black round cord ( 4 prong ) , carefully slice into and remove the black insulation in a small portion only . Check the amps on both outer wires while running dryer . Make sure the amps being pulled are lower than the circuit breaker amps . On a black cord , test the black wire and the red wire amps . If the dryer has a short , it would not run for 10 min and then throw breaker . It would be almost imediate . A bad breaker will gradually get hot and then flip , but check the dryer amps anyway to be sure .
Aug 15, 2009 | Estate TEDX640JQ Electric Dryer
Dryer will stop about 10 to 15 minutes into heat cycle.
HI, The timer mech is malfunctioning. i would replace this defective timer mechanism asap.
Jun 20, 2009 | Kenmore Dryers
Kenmore Electric dryer runs on cool down forever.
Call the mfr and ask them about it. This problem may be pretty complicated. There may be a problem with your board that tells it to go to cool down. Can you set the timer for 45-60 minutes and it stay on heat for that long?
Feb 11, 2009 | Kenmore Dryers
Kenmore 110.64732400 Electric Dryer No Heat - Won't Shut Off
The stepper motor in those timers are prone to giving favorable readings when checked and go back to acting fruity when left to themselves. It's a sticking problem. Try taking the back off the control timer, usually you bend some tangs that hold it on straight, being careful not to overstress them and check the contact points. If they are burnt even slightly then take a file or emory cloth to them, making sure you keep them straight, don't round the corners. Then put the switch back on the head housing without the back on and plug back in. DO NOT TOUCH BACK OF TIMER WHILE PLUGGED IN. Run it through a cycle and see if the motor binds up. It may take a couple of times for it to do it if it's going to. If this doesn't work, then get back to me.
Jan 27, 2008 | Kenmore 64732 Electric Dryer
Kenmore 62602 Electric Dryer Logo
212 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
