Question about Dyna-Glo D-E37 Wall Mounted Panel Heater
Replacing the wall heater thermocouple
The wire lead on the thermocouple is not a tube, it's two wires, copper & silver colored. There are three screw connections on the heater controller. I forgot which screws the thermocouple wires connected to. Two of the screw connections have wires from the burner connected, also copper & silver colored. Where do I connect the thermocouple?
  • Dyna-Glo Master
  • 3,077 Answers
If there are 3 go with the outer 2
Posted on Jan 10, 2009
  • 61 Answers
I'd go with the obvious.
Posted on Jan 07, 2009
How do i adjust or take out the thermocouple?
follow the copper wire to the gas valve undo the silver nut follow the thermocouple copper wire to the pilot undo the brass/ silver nut on the pilot replace thermocouple the same way.
Feb 21, 2012 | Procom MN300TBA Heater
How and where do I replace a thermocouple on a warm glo wall furnace? Help
There should be a thermocouple in front of the burners that has a copper colored wire that runs from the gas valve to the thermocouple. It is located in the pilot flame as it is a pilot proving switch that tells the gas valve the pilot is lit and its okay to open the gas valve to the main burner.
Mar 21, 2010 | Desa International Blower Glow Warm Wall...
Pilot won't stay lit
replace the thermocouple pretty easy looks like bare copper wire
Jan 21, 2010 | Imperial IFS40 Deep Fryer
Need parts: pilot assembly and thermocouple
THe thermocouple either has 2 wires or a coppr tube going to the gas valve. They can be bought at a good hardware store or a plumbing supply. The length of the wires or copper tube will be the determining factor as to which one you need. As these thermocouples, when heated generate a small electric charge tha keeps the gas valve open. Should cost no more than $10-15 USD
Oct 10, 2009 | Berkeley Forge G-PH001PSS Open Flame Patio...
I just bought a used amana dryer that is 1 year old. it has a 3 wire pigtail and i have a 4 wire plug in and need to change out the pigtail. need some direction on if possible to change it out or will i...
go to the local hardware store and buy the male plug for the female plug that you have in the wall just hook up the three plugh in place of the 4 wire plug. The 4 wire has a netural and a ground which is the same thing and two 110 hot wires that are 110 v each, hook up the copper colored wires to the copper colered wires and the one ground on silver. screw or white to silver wire. this is Ground you only need one ground and if the plug on the wall is three prong it is go to use a three wire plug the third wire is for a backup ground on new systems
Oct 04, 2009 | Amana NDE2330AY Electric Dryer
Pilot light on my heating is lighting but once i take my finger off it goes out
You likely have a bad thermocouple. Go to a hardware store and pick one up. You will need to shut off your furnace and remove the little copper wire that goes into your gas valve where you are holding down the button to light the pilot. Don't remove the larger silver tube that is for your pilot valve to supply the gas to the pilot.  Follow the copper line and try to pull straight down out of the pilot assembly and it may slide right out. If it doesn't you will need to remove the pilot assembly so go ahead and remove the larger silver tube from the gas valve as well. Take out the one or two screws mounting the pilot assembly usually a 1/4 inch or 5/16 nutdriver should be the proper tool.  Once removed unscrew the thermocouple and put in the new one. Reassemble. Careful not to bend your silver pilot tubing too much otherwise you will need to replace that as well. Always check for gas leaks around your pilot tube after reinstalling parts.
Nov 24, 2008 | Heating & Cooling
Pilot light lightin but going out once i take my finger off
How to replace the ac jack on a n610c
Dear Porque,
Try this: Get a standard wall plug from the store with three prongs. Cut off your AC jack at the end near the base of the jack. You will see two wire sets, one copper (brown) the other most probably silver in color. In your new plug, fasten the copper wire with the screw labled L, and the other wire in the screw labled N (neutral) or E (earth).
Replace the plug cover. Plug in your laptop and watch for battery charge indicator. If it discarges the battery in five minutes, your wires are crossed inthe plug. Check again.
If you go to the store with that plug, someone can install it for you at probably no charge at all. I hope there are such nice people in your country
Feb 17, 2008 | Computers & Internet
Williams wall furnace, top vent.
I've replaced a Williams wall gas heater non-electric. The thermostat is connected right and mounted on the wall. But, there's a thick black copper wire on the side of the furnace tagged thermostat. I don't know what to do with it? Where do you connect this wire? When it touches the top screw of the three screws running vertically(where the other wires are connected). The burner lights up and stays on, even if you play with the wall thermostat. Touching the other two screws doesn't do anything. Now, the manual talks about connecting it to the venting wires? Extra wires coming from the top or maybe somewhere else in the wall? I've left it connected to the first screw, ran the heater. But, it never turns off? Any suggestions? Thanks
Dec 13, 2007 | Heating & Cooling
Dyna-Glo D-E37 Wall Mounted Panel Heater Logo
440 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
