Question about Panasonic PT-AE700U Multimedia Projector
720p Trouble with PT-AE700U
Hello, I am having trouble getting the PT-AE700U to display a 720p image. Equipment used: Adcom GDV870 DVD Player: http://www.wildwestelectronics.net/gdv870-adcom-dvd-player.html Adcom GTP870HD Preamplifier Processor: http://www.wildwestelectronics.net/adcom-gtp870hd-preamplifier.html Monster Cables: HDMI Cables, connects from DVD player to preamplifier processor, then from HDMI out of processor to the PT-AE700U: M1000 HD-4 (4ft. length), M1000 HD-25 (25ft. length) http://www.wildwestelectronics.net/monster-cable-m1000-hd-4-feet-127672-hdmi-video-cable.html Component Video Cable, connects from DVD player to preamplifier processor, processor can scale 480i --> 720p, 1080i/p: M1000 CV-4 (4ft. length) http://www.wildwestelectronics.net/monster-cable-m1000-cv-4-feet-127681-component-video-cable.html Before I go further, you should know that I also have this same exact setup running at 720p with no problems connecting to a Marantz VP12S3 projector, but for some reason, with the same settings I cannot get 720p from the Panasonic. The way I have the system wired, I can get a signal to the projector two different ways, I can use the HDMI output on the DVD player to pass through a scaled 720p signal through the preamplifier processor. There are settings in the Adcom that allow you to simply pass through the signal. The Adcom DVD player also has an auto setting, when selected we get a picture but only 480, not 720P. The second way I can send a signal to the projector is with the component video output of the DVD player, 480i, then allowing the preamplifier processors scaler to scale the 480i signal to 720P, again no picture unless set to the auto setting. So based on this, is there a setting in the Panasonic projector that would prevent the display of a 720P signal via HDMI input? Cinema Reality Mode is set to "ON", according to the manual, Cinema Reality is not 720P compatible. But the unit will not let us turn this setting off as it is greyed out, could this be causing our problems? Or is there another possibility? I am not an electronics novice and like I said, the exact settings in the DVD player and processor have worked flawlessly on the Marantz projector? Any help would certainly be appreciated. Thank you in advanced. Sincerely, Doug Gillis
  • 192 Answers
SOURCE: Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Posted on Jun 24, 2007
Shuttle83
  • 1139 Answers
SOURCE: HDMI Signal gone
The HDMI interface may have suffered a malfunction, this offten happens due to stray voltages on the ground plane. If you do not have electronics experience I would suggest taking the set to the shop and having it repaired
Posted on Sep 24, 2007
  • 39 Answers
SOURCE: Picture, No Sound from HDTV Box
CON-YOU'VE DIAGNOSED YOUR OWN REPAIR.GET A NEW CABLE BOX.JOE TV
Posted on Dec 17, 2007
SOURCE: Panasonic PT-AE2000U All three HDMI Ports stoped
WOW. I just experienced the same thing. None of my HDMI ports are working, though component is fine. I've had my unit since November 2007 and had no problems until this. I think the HDMI board has gone bad and will require replacing.
Posted on Jun 21, 2010
AJIN G
  • 6694 Answers
SOURCE: Stuck on 480i with Panasonic HD Plasma
It sounds that a software update is necessary. Contact the service centre for Panasonic, to get the latest software to this model Plasma tv.
Posted on Jul 04, 2013
My Panasonic wont display picture only flashes. YPbPr
What type of input cable are you using. YPbPr is a three or five wire hookup red, green, and blue.
Dec 16, 2012 | Panasonic PT-AE700U Multimedia Projector
Picture won't display. YPbPr is flashing on screen
go to settings and select the computer mode instead of YPbPr
the image from the computer will be seen
No output in Right channel on my Adcom preamp GTP-450
Hi...
Have you tried swapping speakers to see if the trouble moves to the other speaker?
It could be a dirty selector switch .
It could be a broken solder contact on the input or output RCA jacks
Feb 07, 2009 | Adcom GTP-760 Amplifier
Panasonic PT-AE700U
may be a heat problem: check the psu unit for components getting too hot...use a laser thermometer and keep you fingers away from the psu ! other possible problem may be a bad capacitor or the thermal protection before the psu..but this would be a very uncommon problem.
Dec 13, 2008 | Panasonic PT-AE700U Multimedia Projector
Mainboard Replacement for PT AE700U
Hi CFP123
You will have to phone Panasonic for the part - do have the part number on the board handy when phoning in.
As for the pricing it depends on which country you are in , but it's normally between $100 - $150
May 13, 2008 | Panasonic PT-AE700U Multimedia Projector
PT-AE700U No Power
Hi ErnieN008
If there is no LED's flashing or even lighting up for that matter , then it could just be the fuse on the Poersupplyboard that has gone.
You can replace this fuse by opening up the top cover and looking for the board with the AC inlet on it.
If the problem however still exists , you will have to replace the powersupply.
May 04, 2008 | Panasonic PT-AE700U Multimedia Projector
How do i get 1080p
How did you get 720p? I have having trouble viewing anything above 480p. When using my directv HD DVR, the screen goes black when it tries to show anything above 480p. Is it the tv or the DVR?
Jan 04, 2008 | Mitsubishi WS-65905 65" Rear Projection...
Mustang projector mount required mounting projector upside down...
You may have figured it out by now... From the remote, you go into the menu and find the setting "Display Image" and the option is "Ceiling".
Dec 26, 2007 | Panasonic PT-AE700U Multimedia Projector
Panasonic PT-AE700U Multimedia Projector Logo
88 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
