Question about Maytag Neptune MAH5500B Front Load Washer
My washer says LO and won't start
It say's LO and the start button flashes like if i paused my load
  • 640 Answers
Locked lid,,make sure nothing is in the way of your lid operation..
Posted on Jan 05, 2009
When pressing start on my frigidaire washer LTT2940FE1, It says pause and won't start.
Reset the unit at the household circuit breaker and retry. PAU means the unit is paused either by a blockage and the sensor won't let the unit continue, or it was manually paused by a button press.
Jul 26, 2012 | Frigidaire ATF6000ES Front Load Washer
How to adjust the top margin for epson lq-2190
Turn on the printer.
Load paper
Press the pause button until the pause light is flashes.
Press LF/FF button to move up or LOAD/EJECT button to move down.
Press the pause button to save.
This save is permanent until you change later.
May 09, 2012 | Epson Office Equipment & Supplies
Washers start button will only flash as in pause in stead start washing ? I unplugged wash to reset computer and still flashing in pause mode ? What's the next step in troubleshooting thanks nicole k in...
You need to get the diagnostic info. It should be located just inside the kickplate. Unplug the washer, and then remove the kickplate. Inside will be a packet of info that will help you diagnose your washing machine.
Nov 21, 2010 | GE WSXH208A Front Load Washer
We have a front load washer that I just started a load with, went back to check on it and found the power off, the door still locked and it flashing ''F 20'' while it is sucking out suds..any help!!
clean your filter out on the bottom of the washer... take off the front panel which has 3 t20 screws holding it on and than remove the filter which is right in front, you can do this by hand... clean that out, put it back in than hit the pause/clear button twice than start a new load than hit the pause/cancel button again to stop that cycle and unlock the door
Dec 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Ge washer wcvh6260 ...... start/pause button flashes, won't start
Does the 'door locked' light come on? If not, check the switch and it's actuator (a pin that is part of the door latch).
Aug 22, 2009 | GE WCVH6260F Front Load Washer
The start/pause button is flashing
timer is failed. replace the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Electrolux EW1000i Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
321 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
