Question about Samsung HT-Z310T Theater System
Installing Samsung HT-Z510 wireless speakers
Trying to solve two problems - 1) cannot get wireless base to link to the receiver. Tried every sequence in instructions. 2) Only get home theater sound when playing DVDs. Using the composite connection between TV and receiver.
I was able to solve the wireless speaker problem through unplugging all of the units and starting over. I need to have the signal go from the satelite box to the recioever then the TV in order to get home theater to work.
Posted on Jan 08, 2009
SAMSUNG SWA5000 Wireless Receiver Module stopped working **help help**
HiI have the same problem, have you found the solution?
cheers,
Dec 29, 2011 | Samsung SWA5000 Wireless Receiver
How to I get my surround sound speakers to work with the cable box?
One way would be to connect one of the the digital audio outputs to the HT as an input (HDMI or optical digital audio).
Another would be to select one of the DSP modes that uses surround speakers. They work with all input modes.
http://downloadcenter.samsung.com/content/UM/200802/20080203110035031_HT-Z510-XAA-0125.pdf
Jan 28, 2011 | Samsung HT-TZ512T Theater System with...
How do you fix rear check fault on samsung htc5550w blueray
It means that your wireless rear speakers can not be detected by the 'radio' on the bluray player. Move your wireless receiver (the one the rear speakers connect to) closer to the player or put it in a place where it has a 'clear line of sight' with the player. Should solve it!
Oct 06, 2010 | Samsung HT-WP38 Home Theater System System
Hi, Ive tried to set up my samsung blue ray
It seems as though the HT works fine, so to get the TV itself to play through the HT setup, take the audio out from the TV and hook it up to a separate channel on the HT receiver. Turn on TV and receiver and put the receiver on the respective channel of the receiver. I hope this helps.
Oct 26, 2009 | Samsung Audio Players & Recorders
Hi, I have Samsung HT-X50 connected with SWA-4000. It was working fine, then for somereason I had to remove and reinsert Tx card. After doing that SWA-4000 is not connecting to HT-X50. Blue light blinks...
You have to reset the connection:
With the home theater system off, press the 0-1-3-5 buttons in that order on the home theater's remote control.
Power on the home theater system.
With the wireless module on, press the [ID SET] button on the back of the wireless module for five seconds.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Hope this helps!
Jun 09, 2009 | Samsung HT-TZ515T Theater System with...
My main unit will not connect to the rear unit
I had a similar problem but mine cut out intermittently.
First, check to make sure the speakers are plugged in solidly. I was plugged into an outlet with a fancy cover and it caused the connection to short out intermittently.
2. Make sure all your wires are securely attached to the receiver unit.
3. If that doesn't work, try turning off the wirless speakers and the Home Theater system and then turn on both of them.
If one of these doesn't work, Samsung has chat support available onlline.
Good Luck!
Mar 13, 2009 | Samsung HT-TZ512T Theater System with...
Fan check
From what I can gather the problem is caused by a faulty sensor. I don't know where the sensor is yet. But I have eliminated everything else associated with the fan which is the fan lol.
I have taken the fan out of my HT-Z510 and hooked it up to my computer and it worked flawlessly.. I am awaiting an email from Samsung as we speak. I will keep you posted
Dec 27, 2008 | Samsung HT-Z310T Theater System
Speakers won't connect
Here is a link to Samsung's HT-Z510 Home Theater rear speaker troubleshooting guide.
http://www.samsung.com/us/support/popup/howToGuidePopup.do?howto_guide_seq=629&type=hometheater&subtype=hometheatersystems
It has worked for me after a couple tries. Good Luck!
Dec 27, 2008 | Samsung SWA-4000
I have a Samsung HT-z510 home audio and the wireless receiver for the back speakers stays in standby mode. I have set the mode to cinema but it still stays in standby. What can I check next?
Here is how I reset. Key terms to identify: Main unit, remote unit, transmission card, reset button on remote unit. 1. Unplug both units and remove transmission card from rear of Main unit. 2. Wait five minutes. Insert transmission card in rear of Main. 3. Turn on both units. If units do not communicate, there will be a solid red indicator on remote unit...In this case continue with 4. Use remote and turn off main. 5. Point remote at main and enter the following four digits, holding each down for about a second:  0   1   3   5 6. The main unit should turn on. 7. With remote unit on, press and hold down the reset button for 5 seconds.
Nov 29, 2008 | Audio Players & Recorders
Rear Wirelss speaker do not work
With the main unit turned off, press and hold [REMAIN] on the home theater's remote for 4 seconds. (The REMAIN button is directly under the 7 button). Once held down for 4 seconds, the Volume Indicator on the main unit will turn on for 1 second. Release the [REMAIN].
Press the [RESET] on the back of the Wireless Receiver 2-3 times. The Standby/On LED on the front of the Wireless Receiver will blink 3 times
Turn on the main unit. The Link LED on the wireless receiver will light up if process is done correctly. The front of the main unit will no longer say REAR CHK and the rear speakers should now function correctly.
Feb 24, 2008 | Samsung HT-WX70 Theater System
Samsung HT-Z310T Theater System Logo
401 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
