Question about Olympus FE-140 Digital Camera
Card cover wil not close
I do not know the reason what is wrong or what broke off my camera but i have an Fe-140 olmpus camera and the card cover will not close.
i dont know why its like or how its suposed to look
    President:
  • 919 Answers
Unfortunately this is a repair issue with the camera. There is a sensor on that card cover door that may now be missing and needs to be replaced. You may want to call Olympus Customer Service to discuss their repair policies and procedures. Their telephone number is 800-622-6372 option 2 and then option 3
Posted on Jan 13, 2009
I accidentally drop my camera and the card cover cracked and i cannot closed it beacause the cover broke. i tried duplicating a cover but it always says Card-Cover Open. Is there a parts for this so i can...
It may be more trouble than it's worth to purchase a replacement. Simply use the duplicate cover that you fabricated. But to get your camera to work, you'll need to find some way to push in the door's safety pin switch seen in the lower left corner of the below picture. Try wedging a small piece of paper (spitball) in there to close the switch. That should allow the camera to work with your duplicate cover.
Mar 23, 2011 | Olympus FE-320 Digital Camera
How to unlock pictures for olmpus fe-360 as cannot delete photos ,there is a green key on it ...and its lock...how to unlock it.tks
Your memory is probably locked (write protected), There is a switch on the back of the memory card. simply switch it in the opposite direction to unlock it.
Feb 28, 2011 | Olympus FE-360 Digital Camera
Fe 5020 digital camera plastic tab that holds battery in broke off and now receive an error message that the card cover is open
The base is working as a complete circuit when it is closed completely. Now as the plastic tab which holds battery is broken so the circuit is not getting completed and the software of your camera is not getting message that all parts are functioning accurately. You need that plastic tab or similar tab to fix this problem. Please show your camera in a repair shop and they will get it fixed at very low prize as they normally have such parts with them.
May 29, 2010 | Olympus FE-140 Digital Camera
My camera is olympus fe-140 so it connect tecnical proplem which says write protect so what can i do
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, write-protecting it. The position nearest the contacts unlocks it.
If that doesn't solve the problem, try a different card.
Feb 02, 2010 | Olympus FE-140 Digital Camera
FE-140 Battery compartment door broken
battery cover has small and minute parts so it breaks easily. getting a spare is difficult. only easy solution will be to take it to service center and fix it
Jul 29, 2009 | Olympus FE-140 Digital Camera
Broken battery compartment door switch
The switch is a micro switch that is depressed(and not sad :)) by a plastic tag moulded on the battery cover. Once the cover is moved into position and closed, the tag presses on the micro switch closing the switch and thus removing the error message. As with any switch, a switch is simply open or closed, Open = high resistance or O/L, while closed = 0 ohms reistance. You can use a small wire to overcome the switch by soldering the wire to both tags of the switch so it is permenantly 0 ohms. This will send a message to the microprocessor that cover is closed and camera ready for use. Hope this helps.
Twitcha
Sep 28, 2008 | Olympus FE-140 Digital Camera
Olympus FE-140
Yes I had the same problem, however, where is says "push to eject," it means to push the the memory card down and it will eject. You pushed down the latch for the plastic door cover. Try pushing something into the hole so the camera thinks the door is closed. I am still having trouble with mine. Hope this helps alittle.
Sep 16, 2007 | Olympus FE-140 Digital Camera
Card-Cover Open
YOU HAVE A BROKE SWITCH
THERE IS A VERY SMALL SWITCH BEHIDE A BATERY DOOR, JUST ABOVE A SIGN "PUSH TO EJECT" THIS SWITCH IS VERY SMALL AND YOU CAN NOT REPLACE SO WHAT YOU CAN DO IS, TAKE THE VERY SMALL SWITCH OFF (YOU WILL NEED TO USE A NAIL OR A NEEDLE TO REMOVE A SMALL PLASTIC SWITCH ) AND THEN STICK A SMALL PEACE OF METAL INSIDE OF THE HOLE (METAL TAPE WORKS GREAT) IT WILL BY PASS A SWITCH.
I USED TO BUY BAD CAMERAS ON EBAY FIX AND RESELL, ANY PROBLEM CONTACT ME KUNGLAO007@HOTMAIL.COM
TKX
Jan 05, 2007 | Olympus FE-140 Digital Camera
Card cover open
The problem is a broken micro switch. If you are familiar with soldering on micro circuits you can get the part from Olympus it is called a card cover switch. Otherwise, send it into an authorized Olympus shop.
Oct 10, 2006 | Olympus FE-140 Digital Camera
Olympus FE-140 Digital Camera Logo
94 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
