Question about IBM Thinkpad 560 Series Laptop 20h4241 Keyboard
Unmountable_Boot_Volume when i open my computer, a blue screen appears which says unmountable boot volume what would i do?
  • 88 Answers
Blue Screen with this specific error is as mentioned usually an inaccessible boot file. Can be a corrupt/missing file OR a failed hard drive. Best option would be to run your manufacturer's diags disk to find if the drive failed. Else work a reinstallation of OS. (if you are in warranty, your friendly tech support guys can guide you thru this - pretty common issue)
Posted on Jan 11, 2009
    President:
  • 2,961 Answers
This refers to a hard drive fault or a system fault where windows cannot find the boot.ini file to boot into windows. You will need to get in the bios if possible F2 or Del on startup and see if you hardrive is listed in the standard cmos settings listing. If not there is normally an option to press enter to auto identify or press f12 depends on bios make and save settings and exit. if it then shows try booting again. If not then the drive or ide connection to motherboard is damaged. You can also set your CDROM as first boot device if you get into the bios in advanced cmos settings, insert your windows cd, save settings and exit for a reboot and when prompted press enter to start from cd and let windows find your hardrive and attempt to install the system files, if there is no Loding windows message at the end of the file installation its a sure bet that the hard drive is faulty.
Posted on May 24, 2007
Unmountable boot volume
Please boot from bootable disc and repair the OS.
Mar 19, 2012 | Dell Computers & Internet
Unmountable boot volume means your hard drive has gone out...You will need to replace it.There is no way to fix this this.
Apr 24, 2010 | IBM ThinkPad T22 2647 Notebook
When my gateway MT6705 tries to boot, blue screen
Many times this error occurs when I have swapped a hard drive and used the wrong IDE cable to connect it. If your computer uses an Ultra Direct Memory Access (UDMA) hard disk controller, and you use a standard 40-wire connector cable to connect the UDMA drive, you may experience this error. Make sure you are using the correct IDE cable.
Also, if your BIOS settings are configured to force the faster UDMA modes, this error may occur. In this situation, restart your computer and enter the BIOS and load the "fail-safe" default settings and reboot.
If neither of these issues are the cause for the Unmountable Boot Volume, then the issue most likely is caused by a damaged BOOT.INI file in the root directory of the boot drive or file system corruption.
Follow the steps below to correct these file system issues:
1) Start your computer with your Windows XP CD-ROM, or with Windows XP boot disks
2) When the Welcome to Setup screen appears, press R to Repair the installation using the Recovery Console
3) If you have a dual-boot or multiple-boot computer, select the Windows installation you want to access
4) Type the administrator password when you are prompted, if no administrator password is set then just press Enter
5) At the command prompt, type CHKDSK /R and then press Enter
6) Once CHKDSK has finished checking and repairing the hard drive, type EXIT and press Enter to restart your computer
Oct 18, 2009 | Gateway MT6705 Notebook
UNMOUNTABLE DISK VOLUME Message on ACER Aspire One.
Unmountable boot volume is most likely an indication of a failing hard drive. Boot to your Windows CD and run CHKDSK /R and see if issue resolves. If it doesn't then you are probably replacing the hard drive.
Sep 29, 2009 | Acer Aspire One Netbook 8.9" Notebook
Startup repair won't run
"Unmountable boot volume" this problem is your hard disk partition which is failure to recognize & identify the operating system running on the hard disk. Reformat your hard disk and put another operating system to run again your computer.
Jul 27, 2009 | Computers & Internet
Blue screen during booting
Yes, unmountable boot volume usually means you need a new hard drive. However, if you have a windows xp cd, you can boot to the recovery console (press R at the first prompt) and try running a chkdsk /f command. Sometimes that will help. Thanks and good luck! Oh and if you could remember to give this solution a rating of fixya. Thanks!
Jan 18, 2009 | HP Pavilion ze2000 Notebook
I have the same issue and my aspire is idle for last 4 years...
Jan 12, 2009 | HP Compaq nx7010 Notebook
have to re-install windows
to boot from CD, check your BIOS setting and have the computer to boot from the CD FIRST
Jan 11, 2009 | HP Compaq nx7010 Notebook
Averatec 3280 unmountable boot volume
You can install Windows XP from your CD drive, you may have to change the boot order so you can boot up from the CD first.
Nov 22, 2008 | Averatec 3200 Notebook
Hi everyone...my windows xp wouldn't start up at all..(unmountable boot volume).kept restarting with the blue screen...I had ** xp disk (came pre-installed)....finally was able to get to my files by downloading K**ppix to a CD and running that on my broken xp ...just downloaded it, ran it, and I was able to access all my folder/files that I didn't want to loose...**w I can use my recovery disks to get my computer running again..I would recommend this option to anyone with ** xp disk...it saved me from loosing important files that I needed...just thought I would share this with you since I k**w many pc's do NOT come with the windows disk these days....
Mar 02, 2008 | Casio QT-8000 Network Terminal
IBM Thinkpad 560 Series Laptop 20h4241 Keyboard Logo
166 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
